Question about Drills
Hilti tp800 do you know if the part is availible, the part number, or where to find this part.. it screws in to the to top of the piston, it supposedly its a pressure relief valve or something like that. the hammer was made prior to 1993
shadytree
  • 25 Answers
SOURCE: rear brakes 05 merc montego
Try turning again clockwise with a little more pressure. If the brakes were worn badly the piston is just stuck from being adjusted out so far.
Posted on Jul 28, 2009
BRADLEYFRANC
  • 104 Answers
SOURCE: looking for oil pressure relief valve on my 95 cabrio
The oil pressure relief valve should be on the oil pump.If your oil pressure is ok,have the wiring tested to theswitches or try another set of clocks
Posted on Sep 16, 2009
  • 123 Answers
SOURCE: hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Posted on Oct 09, 2009
  • 61 Answers
SOURCE: hilti 76 p atc
Hi . The solution offered by rowdy (pull the trigger and hold it until light goes out) will only work on older machines, the newer machines have more complex electronics that need reseting using an optical reader which plugs into a PC , you will also need the Hilti ODA Software. this is not available to the general public. you may have to send it back to hilti for service and reset. this is free if the machine is less than 2 years old.
Posted on Oct 11, 2009
  • 61 Answers
SOURCE: HAVING A PROBLEM WITH MY HILTI TE5 HAMMER
the bearing in the chuck is probly missing. replace the ball baering.
Where can I find a conecting rod for a Hilti TP-400
Try calling Hilti Customer service (toll-free), or look for a nearby Hilti service center. Contact info for the United States is linked below.
Results for My preferred Hilti Centers
Aug 03, 2015 | Hilti Drills
I have a Hilti TP800 with a worn cord. Any tips on getting the two nuts off so the handle can be taken apart....
Just take a flat head screw driver and put it in on one side of the slot. Tap on the screwdriver in a counter clockwise motion. It usually does not take much to get the nut started after that you just spin the nut off. the rod will then just slide out the other side.
Nov 23, 2011 | Hilti Drills
The transformer/control pack housed within the handle of the TP800 Hilti is suspect. This item has one side aluminium coated, and this housing incorporates a PCB. When the drill is energised it runs at a...
Billy-
Replacement parts are no easily found without going through one of Hilti's authorized repair service centers. Visit www.Hilti.com to find one near you - you may be able to purchase the part directly from the service center. Maybe its worth it you you to have them do the work as well - Hilti tools have a great lifetime warranty and service repair policy: Link
Hope this helps.
Regards,
DIYpro
May 09, 2011 | Hilti Hammering
Need to get a new piston where can i get one from
Since you don't specify the model number, I can;t provide specifics. Use the link below and enter the model number in the upper right hand corner or select the category to find the part you need.
Dan
Link: http://www.us.hilti.com/holus/page/module/product/prca_catnavigation.jsf;jsessionid=EEE6A44B2C043FD466974115009CBC71.node4?lang=en&nodeId=-71302
Mar 24, 2011 | Hilti Tools & Hardware - Others
We have a Hilti TE72 Hammer Drill.... We have taken it to fix but they say they can't find parts... We think it is the piston and a rubber gasket that goes with the piston.... Do you have this?
Parts are no longer available for the TE72. You may find some used parts on EBAY. If the tool is not hammering it would need more than the piston and oring that goes on the pistion. Without all the proper seals and gaskets I would not even attempt to repair. If you do attempt to repair it do not put more than 70cc of lube in the drill. Too much oil will distroy the gears.
Aug 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 17. Hammer doesnt work. Rotary does.
Most likely the O-rings are worn - tool has no compression to move the hammers inside.
Less likely: the connecting rod for the piston is broken so piston isn't moving - or 2nd hammer is broken into pieces.
I would open it up & check the orings first
Jul 31, 2010 | Hilti Drills
I have a hilti TP800 that will not hammer. no polunging action for the chisels
TP800 are that takes me back. right hear we go...
as over people have sugested remove the 4 screws and the black plastic cap from the top of the machine. you should be able to see the con rod and the crank gear, and in front of the crank gear you should see the small gear which is the top of thr armature, you may have to scoop out some grease in order to see it. Check that the con rod is not broken. earlier machines had aluminium cod rods but the later models have plastic ones which were prone to breaking. this isn't to say that the aluminium ones never broke because they did and wow what a mess may made when they did. if your con rod looks ok, try this... keep your hands clear of the open gears, and put some glasses on. turn the machine on and make sure that the crank is turning. look at the small gear on the armature to see is it is wobbly. the small roller bearing at the top of the armature use to callapse causing them to wobble. this would strip both the gears. a good sign of this is metalic parlicles in the grease. this fault is very expensive as you will have to replace the armature, bearing, seal, and the crankshaft. ouch...BUT DONT DESPARE. if this looks ok, it must be the piston rings these are cheap, fairly easy to change and available, as they are still used on more current models. the part number for these piston rings (o-rings) is 13772. want to know how to change them?.. read on...The hardest part is removing the chuck as you must remove the retaining clip at the tip of the chuck. hilti make a special tool for this, but it is possible with a good set of circlip pliers, 2 flat screw drivers and 4 hands. top tip...Remove the rear handle assembly, just remove the 4 screws and pull it off, now the machine can be stood upright on a workbench. Wear safaty goggles and put a chisel in the chuck, this will help you not to loose the clip when it flies across the workshop, I hate it when that happens. once you have the clip off its easy from now on. and don't worry, there is an easy way to get it back on. ok, the clip is off. remove the washer and the plastic chuck cover. remove the circlip, remove the chuck sleeves, dont loose the 6 balls or the roller. now there is another large circlip which holds on the black plastic cover. remove them both. now you can see the 6 bolts which hold the machine together. remove them. remove the chuck.you will see a large o-ring around the cylinder, remove it. Now with a screw driver carfully split the cylinder at the point where the o-ring was sitting. carefully pull out the inner cylinder. dont loose the small plastic balls. if they fall out dont worry. put them to one side. inside this cylinder you will find the follower piston, just tap the clyinder on the workbench and it will fall out. replace the o-ring, smaer with grease and replace. The drive piston is probably still inside the red casing. Simply pull the con rod off the crank and tip it out of the casing. on early models this piston had 2 seals. 1 teflon ring over a green rubber O-Ring. on later models these were replaced with an o-ring, the same as the follower piston, the earier type may not be available in which case you may have to replace the pison as well in order to fit the newer o-ring system. once the seals have been replaced, smear with grease. place the piton inside the cylinder just far enough so the conector pin cant fall out of the drive piston. Replace the plastic balls into the detents in the cylinder. use grease to hold them in place. Replace the cylinder into the caseing but make sure that the cut out at the end of the cylider is facing down. This is where the armature gear sits. as you push the cylinder in ensure that the con rod is hooked onto the crankshaft. reassemble in reverse order. use grease to hold the chuck balls and roller in place. dont fit the rear handle yet..now for that clip that caused all the pain at the start of the job. PuT YOUR GOGGLES ON. stand the machine upright on the workbench and get somone to hold it. place the clip on top of the chuck body tube. get a block of wood and place it on top of the ring, and hit it with a hammer. this will knock the ring on 80% of the way, now tap it on with the hammer. refit the rear handle. your done,,,if you removed all the grease replace with a similar type. 70 grams (3 oz) in the crank case under that black plastic cover..
Well I hope that helps, its not as bad as it sounds.
good luck.
please leave feedback .
if you have any more questions please email me.
if you want a parts diagram i can email you a drawing of a TE804 which is virtually the same machine with a slightly different chuck.
paul@wysehire.gi
www.wysehire.gi
Oct 08, 2009 | Hammering
How to strip down a hilti dx450 nail gun
I suggest calling 1-800-879-8000 or going to the Hilti.com website and downloading a schematic for this tool. Let me know if you need more help
Sep 10, 2009 | Tools & Hardware - Others
DX 36 hilti drill's little metal piece got broken, I don't the exact name , can I see pictures to determine what part it is?
If you have the powder actuated tool it is the piston position #6. Go to Hilti.com and after going thru the prompts you can download a copy of the schematic. Let me know if you need more help. If I have helped you on this would you please rate the response accordingly and Thank you.
Jul 04, 2009 | Hilti Drills
Problem with Hilti JackHammer TE76
Yes there is but it is somewhat confusing to navigate. It is Hilti.com. If you can give me some idea what parts you are looking for I have that breakdown at work and will help you. It is the TE76. Let me know and I will do what I can or you can call their toll free number in the US at 1-800-879-8000 and ask them for help also
Jan 25, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Drills Logo
161 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
