Question about HP Hewlett Packard CE399A 75-sheet Envelope Feeder For Accs Laserjet -
My HP CE399A does not automatically feed the envelopes
  • 21 Answers
SOURCE: HP 4L Envelope Feed Problem
check the internal roller ( central ) easy to remove . clean with alcohol's dry put it back ... (robber couvred)
Posted on Mar 13, 2008
Ranglo
  • 1194 Answers
SOURCE: envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Posted on Feb 20, 2010
seeker5211
  • 1089 Answers
SOURCE: HP Laserjet 4200 with optional
Use a damp lint free cloth and clean the feeder rollers.
Print out a configuration page to make sure that the printer recognizes that the feeder is installed.
Usually the envelope feeder problems stem from age and/or dirty rollers.
Make sure that your software app sees that the feeder is attached.
Posted on Feb 08, 2011
SOURCE: My HP laserjet 5p manual feed/ envelope tray
Solved
Posted on Feb 09, 2011
Salim Baig
  • 283 Answers
SOURCE: my hp J4680 won't feed
Hi
The envelopes are standard in size hence do not use any odd sizes. And also do remember that you make the required alignment and also the feeding directions and positions. If you print in Landscape then the paper is too short for the printer to pick. Hence use Portrait so your printer can sense the presence of the envelope
Posted on Jul 16, 2011
Paper feed will not stop
I suggest You Go to Official HP Printer Page For You HP Printer Problem On Below HP forum URL Link: Out of Paper Error Message and the Printer Does Not Pick Up or Feed... In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :http://www.techsupportprinter.com/hp/
Mar 04, 2014 | HP Office Equipment & Supplies
My hp J4680 won't feed envelopes, the envelopes goes part of the way in and then fails to print
Hi
Jul 16, 2011 | HP J4680 Office Jet All-In-One Printer
Envelope jam HP Officejet 8500
Steps:-
3) Click Options .
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Envelopes won't feed into my hp 6310 all in one. What can I do?
Hello db,
Try this...Place the envelope to the right side of the feeder. Position the envelope with the flap facing up and to the left. I use Microsoft Office Word software for feeding and printing envelopes with good results. You can also go to the HP website and download their envelope printing software for free.
Hope this is helpful for you. If it is, please leave positive feedback for me. Good luck! NormanZ
Jul 11, 2009 | HP Officejet 6310 All-In-One InkJet...
My HP 1350 will not print cards/envelopes from the right side of the printer. They have to be loaded on the right but the printer keeps printing in the center.
Printing envelopes with an HP 1350:
If you use MS Word, select ENVELOPES. When address window appears, select OPTIONS on right > select PRINTING OPTIONS > select FEED METHOD option on far right (envelope placed on right of tray face down); select FACE DOWN; select FEED FROM UPPER TRAY. The only problem I have with this is that the address prints off in the lower quarter of the envelope rather than in the center of the envelope as we would write it manually. I am currently working on solving that problem.
Mar 02, 2009 | HP PSC 1350 All-In-One Thermal Printer
Printing envelopes 4" x 91/2"
when you print envelopes you will have to select the paper size in the print options. There should be a pull down menu with every paper size and envelope size. Select the appropriate one, and be sure the envelopes are placed the right way when you feed them in. Most home printers work best when you manually feed the envelopes in. Its a tricky process, and you may have a few jams.
Feb 10, 2009 | HP DeskJet 9800 InkJet Printer
Envelope printing
With the address highlighted go to Tools, Envelopes, Custom
Enter the custom envelope size
Pick #4 feed method
click OK
Set the feed tray to hold the envelope along the right side.
Insert the envelope with the flap up - push it all the way in.
Print it
Dec 18, 2008 | HP DeskJet 6122 InkJet Printer
Printing envelopes
you can replace the paper in the main tray with the envelopes. this is the only way unless you have a secondary paper tray or manual paper feed that does not override the main paper feed
Oct 03, 2008 | Lexmark Optra T610 Laser Printer
Mar 13, 2008 | HP LaserJet 4L Printer
HP Hewlett Packard CE399A 75-sheet Envelope Feeder For Accs Laserjet - Logo
46 people viewed this question
Seeker5211
Seeker5211
