Crosleyradio In a Crosley model # ITRR-501 Ihave a small black rubber belt that broke. Where do I find a replacement?
4 Suggested Answers
  • 8457 Answers
SOURCE: BELT BROKE
Just replaced another DVD player,it very cheap these day.It about $40 u could buy a new dvd player.
Posted on Mar 14, 2010
  • 6771 Answers
SOURCE: turntable drive belt for model ITTRR-501
It is very difficult to hunt down a turntable belt, take the belt to a TV service shop, he should have a belt gauge to measure the belt in hopes he has that size in stock.
Posted on Mar 08, 2012
  • 39415 Answers
SOURCE: Innovative Technology ITRR-501 music center turn table for records is slow
The motor may be weak or there could be a dry bearing.
Posted on Jun 07, 2017
Record player doesn't move when I pick up the needle but it sounds like the motor starts. I hear a clicking noise when I move the needle to the record. Model ITRR-501
You can use a small screwdriver to remove the C clip in the center of the platter. Then remove the platter and reinstall the belt. It can be a little tricky to get the belt back on. If that fixes the problem, then I would look online and order a new belt as yours may have stretched out and will keep falling off. Here is a link to purchase the belt if needed.
NEW INNOVATIVE TECHNOLOGIES ITRR 501 ITRR 700 ITVS750 TURNTABLE BELT D001RX
Dec 14, 2017 | The Audio Players & Recorders
My crosley portable turn table will start but half way into a record it stops spinning; please advise
There is a small motor under the turntable that either uses a belt to turn it or has a rubber tired roller that sets up against it and spins. You will probably be able to find a belt or rubber wheel at a TV repair shop. Some models had an adjustment on them and can be adjusted but more than likely you will need a new belt or rubber tire. The tires looj like a big square :O: Ring
Mar 12, 2014 | Crosley Audio Players & Recorders
Itrr-501 user manual
You may download a copy of the manual here.
Dec 19, 2012 | Innovative Technology Elect IT 5-in-1...
ITRR-501 NO SOUND DIAGNOSE
I was asked to further clarify problem, but not much to add when there is absolutly no sound it is called silence from the speakers when unit is plugged in, turned on (sounds like speakers engage) one of the five choices is chosen to listen to and no sound comes forth to hear. How can I get inside the unit and check to see the speaker connections?
Sep 30, 2012 | Innovative Technology Elect IT 5-in-1...
NEED operators manual for ITRR-501 retro 5 in 1. lost mamual. NEED TO KNOW how to record to CD Disc. Also will it record fro records to disc and record cassett to disk. PLEASE SEND me a manual. OR a zerox...
The unit will record to CD from the turntable, cassette or the AUX port. Place a blank CD-R or CD-RW in the CD tray. (Note: CD-RW discs may not play on other CD players.) Press the Phono, Tape or Aux button to select your audio source for recording. (For Aux, you will need to connect the source device to the AUX port in the back of the ITRR-501.) Wait for the CD disc to load and check for any indicator lights (you should see the "NO TOC" and "CD" or "CD-RW" lights lit). Select your Track increment (or Auto Manual for unattended track formation).Press Record button and the up arrow to adjust the recording level.
If you are recording from an LP, put the tone arm down on the record. For all sources, press Play. Press Stop to end recording or Pause to temporarily break the recording. Press the Track Increment button to advance the track number if you are doing so.
To finalize your CD-R to make it readable on all players: after stopping the recording, press the Finalize button.
The manuals for Innovative Technology products are available here: http://www.ithomeproducts.com/support . The products are listed in alphabetical order. The direct link to the ITRR-501 manual in English is http://www.ithomeproducts.com/sites/default/files/pdf/ITRR-501.pdf .
I hope this helps.
Sep 19, 2011 | Innovative Technology ITRR501 Audio Shelf...
Need a user manuel for a Crosley#CR247 where can I find one?
If you have the Crosley Composer CR247 CD recorder and turntable, the manual is available from the product page from Crosley: http://www.crosleyradio.com/Product.aspx?pid=1791 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR247_Manual.pdf .
I hope this helps.
Jun 04, 2011 | Crosley Audio Players & Recorders
Have Crosley CR245 the CD drawer does not open. H...
it sounds like the unit has a broken open door belt take the lid of and look for a black broken belt you can replace it with a rubber band of the same size
May 13, 2010 | Audio Players & Recorders
96 people viewed this question
 Grubhead
Grubhead
