Question about Samsung Washing Machines
Vibrating and banging - Samsung Washing Machines
How to fix error Uc samsung automatic
Posted on Feb 13, 2014
Washer bangs from side to side when on spin . Why
Several potential reasons for this:
  1. Unbalanced load;
  2. Washer is not on a concrete subfloor. This may sound a little silly, but washers situated on a wooden subfloor will vibrate the floor below (much like a person jumping up and down in a rising elevator) so they need to be balanced and anchored to the floor to prevent the vibration and banging.
  3. Loose tumbler--make sure it is properly seated on the drive shaft (less common issue);
  4. Bearings worn out in the shaft that extends up into the barrel (the thing into which you load the clothes). This is unlikely unless you your washer is older (maybe 10 years or so) or is used a lot.
Feb 11, 2015 | Washing Machines
WMA30 Front loader
when a machine gets old it is always normal for the vibration and banging to occur, then, after the vibration it settled down smoothly.this is due to worn fan belt .bearings worn out and the preasure on the spindle.so dont get alarm .but you will soon have to replace the washer as the banging and the vibration will get worse eventually.or change the fan belt.and replace bearings.which can be done by a qualified personel.good luck.
Jun 09, 2007 | Hotpoint WMA30 Front Load Washer
Vibration and banging into gear
does the vibration stop when you push in the clutch? if so you have a clutch problem. If ot then you have a transmission problem.
Jun 24, 2012 | 1999 Isuzu Amigo
Drum is making a loud banging noise during spin, it is brand new
Some banging or knocking during the ramp up to spin speed in this washer is normal. It is difficult to determine whether your washer has a problem or not based on your description. This banging lasts for varying amounts of time until the load is balanced and the washer ramps up to the full spin speed. If the load can not be balanced on the first attempt, the washer will ramp down and then tumble and attempt again to ramp up to speed. This may be the same thing that you are hearing when your washer ramps up to spin speed. Since the washer does spin at the full speed, there is not likely a problem with the washer. The components are designed to withstand repeated vibration and reasonable banging or knocking. The washer will vibrate to some extent at high speed. If you feel that the vibration is excessive, I recommend that you check the stability of the leveling feet. Press down on the diagonally opposing corners of the washer to check for play. If the washer rocks at all when conducting this test, I recommend that you adjust the leveling feet to eliminate this play even is the washer is not perfectly level after making this adjustment. This may help reduce the banging and vibration. Other than that if it is brand new call the people who you purchased it from so you don't void any warranties by taking it apart.
Sep 08, 2011 | Washing Machines
When washer spins it seems to be off kilter the drum bangs the sides
Check the vibration damper rods for firm mount, and also the springs at the bottom of the basin.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Washing Machines
Can not run spin cycle bang bang bang
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
May 04, 2009 | Washing Machines
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Mar 17, 2009 | Kenmore Washing Machines
Dryer banging
Check the vibration damper rods. It is detecting an uneven load and stopping.
Mar 17, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Heard loud bang my volkswagogan passat 1.9 tdi 2003 reg.
it is probally the hose from the turbo outlet that has split,they are dead common.remove the undertray and look and feel the pipe that drops down from the turbo and goes to the connecting pipe that runs along the front of the car.
Feb 19, 2009 | 2003 Volkswagen Passat
Loud noise
The vibrating sound you hear could be due to "water hammer" when the fill valve tries to close against high water line pressure. I had that problem and solved it by putting a small valve in the line to the ice maker and closing it little by little until the vibrating went away. You know, the banging could also be water hammer. It only happens at night when the entire neighborhood is asleep and the water pressure is at its highest. You need to check this out because water hammer can be very destructive to the plumbing and the valve.
Tom
Sep 08, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Washing Machines Logo
57 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
