Question about Hino 2006 268
Oil capacity for h06 ctl gh1h hino engine - Hino 2006 268
Hino ec100 the engine is runing fine but the brakes is hard and the oil is leaking through a pipe on the brake booster
Clean out the pipe start engine and feel for vacuum from pipe if vacuum ok booster is faulty
Dec 19, 2015 | Cars & Trucks
Hcan i obtain an electrical wiring diagram for a hino bus modelrc3274a thank you
contact the manufacturer if it is a genuine Hino make. Most busses are just chassisis ( in this case Hino truck) on which a coach builder builds the cabin.In that case contact Hino on google ---technical division or customer service and quote the model and ask for the schematics. If it is a custom built by a coach builder ( plate somewhere near the door -dash -engine bay etc contact them and see if they can supply the schematics for the wiring that they do.
Jan 16, 2015 | Cars & Trucks
What is the oil capacity of a 1988 Hino 6.1Litre engine?
call a dealer to find out or call any auto parts place and ask them as they can tell you over the phone
Nov 20, 2014 | Cars & Trucks
How much oil in a 2012 fat boy low ?
2013 Softail
a. Use 3.5 quarts (3.31 liters) of engine oil for a wet
capacity refill.
b. Use 4.0 quarts (3.79 liters) for a dry capacity refill.
NOTE
Use wet capacity values for engines that have just had
the oil drained. Use dry capacity values for engines that
have been disassembled, cleaned in solvent and dried.
2013 DYNA
a. Use 2.5 qt (2.4 L) of engine oil for a wet capacity refill.
b. Use 3.0 qt (2.7 L) for a dry capacity refill.
2013 Touring
Initially add 3.0 quarts (2.8 liters) of engine oil
2013 VRSC
Oil capacity with filter 5.0 qt 4.7 L
2013 SPORTSTER
Oil tank with filter 2.8 qt 2.6 L 2.8 qt 2.6 L 2.8 qt 2.6 L
Sep 04, 2014 | Motorcycles
What is the hino jo5dt engine valve clearance
http://www.hino.com/trucks/story_810.php
Jo5DT diesel engine. (no year?)
second ever too ask an not one answer ever
even google , shows, ZERO.
well , time to buy the FSM book and read it up.
or go to hino and ask.?
May 08, 2014 | Cars & Trucks
Hino 2006 268 Logo
24 people viewed this question
Top Hino Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Hino Home Fencing Expert? Answer questions, earn points and help others
