Question about Kenmore Refrigerators
CAN YOU USE A BYPASS PLUG FOR KENMORE 10650023210? If so which one?
Need to bypass lid lock Kenmore 2002 white red blue yellow which ones
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
Kenmore Lid Safety Switch ( Temporarily Fix ) - YouTube
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
how can I disable the lock on my new top load Kenmore ...
www.shopyourway.com > Manage My Life > Questions
Jan 08, 2016 | Kenmore Washing Machines
I changed the thermal fuse but my kenmore dryer still wont work what else can i do
Check the door switch.
Check to make sure your are getting 220 volts from your outlet.
Check terminal block for burned wires.
Less common causes: bad timer, bad motor.
May 28, 2014 | Kenmore 63942 Dryer
I have a Kenmore top load washer, it filled with wather, however, will not do anything after that? Lid is closed and still won't agigtate, or drain
Your lid switch is bad. You should open the control panel, unhook the switch, cut and splice the 2 outside wires together (usually tan and grey colored - NOT THE GREEN ONE). Reinsert the plug, close the control panel and you'll be all set. Don't listen to anyone who tells you that you can't splice the wires - also known as bypassing the lid switch. I refurbish and repair appliances for a living and I warranty for life - I bypass these switches all the time. If you need help opening the control panel and/or doing the bypassing, you can reach me via email on yahoo - smms6776.
Jun 07, 2012 | Kenmore 24032\24036 Top Load Washer
How to bypass a lid switch on 26002010
You first un plug machine. Front panel has screws in the four corners. Trace lid switch to the back of panel. Cut the two wires and strip wire and put together , use **** connectors and put all back together. As you now, when washer is on high spin, make sure no kids open lids, as you just bypassed safety feature.
Jun 06, 2011 | Kenmore 20172 Top Load Washer
How to install filter bypass plug (SmartWater)
the smart water filter twist out lik a oil filter on a car . and the bypas ( cap ) trun back on just like the filter that you just removed . .open both doors . when changing filter . filter cap ( bypass comes with instructions .. mm
Jul 03, 2010 | Kenmore 57029 Side by Side Refrigerator
Washer will not turn on. the door is closed and it is plugged in but nothing happens.i have bypassed the door switch
If you bypassed the door switch already then you need to try and pull the back off and make sure the plug it's self has not come out from the wires inside it sounds like alot but it's really not it's all there and pretty much self explainatory.. If you need further help just let me know :) Hope this helped
Jan 07, 2010 | Kenmore Washing Machines
Kenmore series 80 power cord melted
This is extremely distressing to me. If someone advised you to jump acoss (bypass) the thermal fuse on the dryer then I am in disagreement. My advise is to trip the breaker at the house power center, remove and replace the dryer main power cord, and replace the thermal fuse. Something is causing the dryer to pull more amperage than it should be, which is what resulted in the melted cord to begin with. You may want to contact a qualified appliance technician to assist in throughly checking the electrical system on the dryer. Until this condition is properly addressed there is a very real safety issue. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 27, 2009 | Kenmore 63942 Dryer
Is there a way to bypass the water level switch on Kenmore HE5t
No - it is vacuum operated. Just replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 10, 2009 | Kenmore Washing Machines
Kenmore Lid Switch Bypass Test
put a jumper wire from blue to pink
Jul 07, 2008 | Kenmore 20722
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
