Question about Saws
On and off switch
Model number E105115
W6444
make this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 25, 2013 | Washing Machines
Stat button
see this steps and fix it. GOD BLESS YOU
User Control and Display Board
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse
If the washer won't start the line fuse might have blown.
Thermal Fuse
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Jul 21, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine wont turn on
see this instructions and fix it. God bless you
Timer
Line Fuse
Thermal Fuse
Main Control Board
Power Cord
Jul 21, 2013 | Washing Machines
The washer work but stop along the way,ie unable to complete the circle
see this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Affinity stops in the middle of a cycle a just shuts off no signal or anything?
use the following steps. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
May 23, 2013 | Frigidaire ATF6000ES Front Load Washer
Isnt gettin power but cord work outlet works
Timer
Line Fuse
Thermal Fuse
Main Control Board
Power Cord
God bless you3958e768-3a49-432b-8096-35c2e90be05f.gifbf55c0bf-2b61-4cdd-8831-a6dc82140f68.jpg
May 23, 2013 | Maytag MAV7600 Top Load Washer
Maytag washer mav7600aww doesnt get power
Timer
Line Fuse
Thermal Fuse
Main Control Board
Power Cord
God bless you938a0a02-c262-417d-a982-3a081cef735f.jpg2b39c595-65d9-457a-8ed4-d3bb6d2facd8.giff6783cbc-852f-47b4-98d7-bd94a664080e.gif
May 23, 2013 | Washing Machines
Washer heavy duty cycle issue
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
Refrigerator in-door water dispenser fails to work
First ... your model number is missing some on the end. please check your model number on the machine for the correct lookup of parts.
For your situation I found this model number # FRS22ZRHD1. Take a look at this picture of this models dispensor.
there are 3 switches # QT 2 -- 38a & 38b
this should be close to your model of fridge but you will half to make sure.
and yes you should just replace the bad switch.
Part numbers for the switches for this model # are 218479900 & 241689101
Jan 08, 2010 | Refrigerators
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
