Question about Proscan PLT7223G-K 7in Android 4GB Tablet With Keyboard And Case
While trying to navigate through the menu all these lines pop onto the screen like some sort of interfearance then the screen and the entire tablet freezes up, what is causing this and whats the solution?
  • Connie Hyde
    Connie Hyde Feb 12, 2014
    Already did a factory restore, worked great for about 5 min. then did it again.
    Sergeant:
  • 281 Answers
Those systems seem like a hardware problem. You may notice it happens more after the tablet warms up.
It maybe time for a new tablet
Posted on Feb 13, 2014
What do I have to do to download from tablet to SD card
Insert SD card into your tab and make sure it is detected and accessible.
Download your files.
Open file manager on your tab and navigate to Download folder. Click to open.
Hold on the file(s) downloaded one after the other to select.
Top right of your screen or bottom right of your screen you will observe a set of 3 dots aligned on top of each other (i.e. if an options menu has not popped open); click on these.
Options to copy, share or a symbol like a Y turned on its side will become visible; select and navigate your way to SD card (still within file manager); click to open and then Paste/copy here.
A video tutorial would have been appropriate. Working on this please
Oct 11, 2017 | Tablets & eReaders
How do i reset my hkc tablet model number p771a
This should do the trick,
1)
Make sure the tablet is NOT connected to the charger
2) Power off the tablet by holding down the power button for about 10 seconds
3) Once it is off, hold down the HOME button and connect the charger while the button's being held down.
4) When you see the HKC logo come up, let go of the HOME button.
5) Eventually, you'll see an Android logo with a red exclamation mark. If you don't, repeat step 3-5.
6) If you do see the Android logo, hold down the POWER and HOME at the same time for one second and just let go of the HOME which should bring up a "Recovery mode" menu with blue letters. Make sure you let go of the POWER button as soon as you see the menu pop up, otherwise your tablet will just shut itself again.
7) Navigate to "wipe data/factory reset" using the HOME button and select with the POWER button.
8) Navigate to "Yes - delete all user data" and select it.
9) Once it's done, you should see the menu come up again. Navigate to "Wipe Cache" and press the POWER button
10) It should take you back to the recovery menu. Simply press the POWER button while highlighted on the "Reboot system now"
Dave
Dec 03, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
Forgot password to get in tablet how do you reset it
RTM. Read the Manual. If you need a manual, google the make and model and manual and you should find a .pdf file you can download. Or go to the manufacture's website and contact them.
Nov 23, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
The icon on my iPad used to flip the netflix picture onto my tv has disappeared from my iPad consequently I can only watch the movie on my iPad rather than my tv.
Touch the bottom of the screen: the navigation menu will appear with the full screen at the far right down of the iPad and next to the left the little square box with a triangle of airplay to send to your apple Tv. you can watch directly from your apple TV also.
Nov 10, 2014 | Apple iPad Tablets & eReaders
How to reset tablet
Try this: Switch OFF the tablet. Now, push and hold VOLUME UP. Push POWER button. Will start with a menu. Keep holding VOLUME UP until that menu appear. After this, use VOLUME UP and DOWN to navigate in menu.Choose factory reset. Be adviced, that will be delete al of your data.
Alternately, use RESET SWITCH on the back side.
Aug 18, 2014 | AGPtek TP714AQ-A 4 GB Tablet - 7" -...
HOW DO I ACCESS ANDROID SYSTEM RECOVERY MENU?
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
May 11, 2014 | HP Slate 7 2800 8GB 7" Multitouch Android...
Tablet is stuck on the screen that says android
You may have to reset the tablet to factory settings. This may be the only way. It will wipe all the data on it.
To factory reset:
1. Press and hold power plus volume up until an android menu appear 2. Use the volume keys to navigate and option key or power to select. 3. look for factory reset and wipe data 5. restart the device and it should be back to factory settings.
Feb 04, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
I have a PANIMAGE media tablet 7'' 2GB/GO, model numberR79RT2W5.. it turns on and thats it, it shows a constant blue line centered at the bottom of the screen, i can press the menu button on the top of the...
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
Oct 26, 2013 | Generic PanImage Android MM Tablet eReader...
I just bought Samsung Galaxy Tab GT-P100 last month, but now somehow Camera feature is not working. There's message says: "Warning: Camera failed" pops up on screen whenever I want to use camera...
do one thing Turn Off Your Tablet
-> Hold Volume Button and Power button for 3 to 5 Secs -> You will see a screen with android and triangle with exclamation mark -> you will also see 4 lines of writing in blue. -> use volume buttons to navigate to 3rd option, use home to select it ( warning this will erase your system data if need please take backup) (memory card is not affected) -> now navigate to 1st option saying " reboot to system" use home key to select it.
I hope this will fix things
Apr 03, 2011 | Samsung Galaxy Tab Tablet PC
My tablet keeps stopping unexpectedly at the home screen and there is no way to stop it. can you reset this unit?
Are you trying to wipe the data with the reset? This will get you back to factory settings. It is entirely possible that there are apps on the tab that need to come off and have caused a problem.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
The Galaxy Tab should then go through the hard reset process.
Mar 04, 2011 | Samsung Galaxy BBSPHP1 Tablet PC
Proscan PLT7223G-K 7in Android 4GB Tablet With Keyboard And Case Logo
56 people viewed this question
Top Proscan Tablets & eReaders Experts
tosin_christ
David Payne
David Payne
EE Eddie
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
