Ripspeed bad card error
Bad card eorror always.. is there a certain format needed for the ripspeed
My Canon says Memory Card error even with a new Memory card..what to do?
Some older cameras will only accept certain size memory cards and types. Some faster new memory cards may not work with your canera - check your manual
May 21, 2014 | Canon PowerShot SX120 IS Digital Camera
What formatting is necessary to play videos on the SD card slot of my Magnavox NB500MG1F Blu Ray Player?
The SD card is mainly for photos, but you can do video.
The SD card needs to be formatted as fat 16
The video has to be profile 1.1
If you use the larger SDHC cards, they can be formatted fat 32.
It works best if you format it with the player and not your computer.
May 17, 2014 | Magnavox NB500MG1F Player
Magnavox NB500MG1F Blu Ray Player: I've been having trouble getting the SD card slot to read the videos I put onto the SD card. I've tried everything from converting all the video files to AVCHD file types...
It is obvious to me that the player can't read the video off an SD drive. In my experience that card slot is for installing updated firmware not video material.
Mar 23, 2017 | Audio Players & Recorders
Ripspeed dvd 730b settings
Description is too vague. If you are certain the speakers, power connections, and all wiring is proper, the radio is bad.
Dec 16, 2013 | Car Audio & Video
Hi don't have a vid i have a ripspeed dv720 it will play CDs but not DVDs it keeps coneing up bad disc any ideas
ripspeed are prone to problems, just a cheap equivelent for an in car dvd, most likely the laser is goosed
Feb 05, 2013 | Car Audio & Video
Mine memory card is always showing a error msdc error.....even am unable to format it by means of of mobile or cpmputer.what should i do.....\??????????
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DAta.......
Your memory card has a bad file on it.
Copy contents using a mem card reader onto a pc.
then format the card in the pc.
then put the card in your phone and format it there.
After that see how the card is and add files a few at a time to see what is wrong.
If it is sandisk you have a five year warranty on the card.
Aug 28, 2010 | Cell Phones
Card error
Due to the broadness of this issue, I can only give you information based on what I know.
Cameras made within the last few years usually always have card problems. They supply you with a 16Mb card just enough to get a few pictures on. When the user buys a different card, the usual error is either card read error, card error, or simply just not reading the card.
First, if you can buy the brand of card supplied with the camera it's highly suggested you do so. As much sense as it doesn't make, certain cards only work with certain cameras. To avoid costly purchases consult the sales rep at the store. If they seem like they think they know but have an uncertain tone don't trust them because they're just trying to get you to spend money. Take your camera in and ask them to literally check to see if their recommended card works.
If you continue to get this error you may have a defective unit in which case you should consult the camera company regarding your waranty.
Overall it's a great camera and you shouldn't have any other issues with it. From personal experience Samsung makes great products and they're built pretty sturdy and with excellent detail in enhancing their product's performance.
Good luck and please rate my solution accordingly.
V/r,
Don
Jan 25, 2010 | Samsung Digimax S730 Digital Camera
PC saiy card needs formatting before use. When the
Always format the card in the camera, never in the computer. Use a separate card reader to download to the computer.
Dec 05, 2009 | HP Photosmart 320 Digital Camera
Can not format a 8 gb memory card into my phone my phone is a sgh-e900
i think the memory card is corrupted or there is bad sector formation in it ...
so you just have to do is insert the memory card in a card reader & just format that you will surely able to do that from card reader before giving to format just check for the errors by right clicking on the memory card drive which you will get when you connect from the card reader
first perform this task before you do the format
right click on the drive >properties >tools tab>check for errors
after this if there is any bad sector formation in the memory card then it will be fixed then after this you will surely be able to do the format easily and fix your memory card which is corrupted ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 13, 2008 | Cell Phones
Memory card is locked
if you still persist the same problem then the firmware might have got corrupted give restore factory settings in your phone ....
if you still persist the problem then there may be some problem in the memory card slot .... you need visit the technician ...
thank you
bye
rate my solution
Jul 13, 2008 | Nokia 6300 Cellular Phone
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
