Question about MumboJumbo 7 Wonders of the Ancient World for DS
Check device type: direct3d device does not support the queried technique for 7 wonders
D3d drivers 95
D3d is an abbreviated way of saying Direct3d. The 95 could possibly mean that it wants version 9.5, but I'm not really sure what else to make of it. Direct3d is something like a framework/library for rendering 3D objects on Windows operating systems. It's part of DirectX, but you can download direct3d alone from Microsoft; though I would advise against downloading it from any place but Microsoft or MSDN for several reasons. You can try grabbing the latest version (I think it's 11) first, and if that doesn't work, go ahead and look for 9.5.
Lastly, there's a possibility that this message means that your drivers are not compatible with Direct3d. There are a number of reasons this could happen. First off, your laptop may not be able to run Direct3d. However, I find this unlikely; it's pretty rare to see a Windows 7 laptop with absolutely no graphics capabilities whatsoever. If you ever re-installed Windows, that could be an issue, as the driver software is erased when you do this. It might be possible to ascertain additional information with a more verbose description of the problem you are encountering. ;-)
Oct 25, 2013 | Lenovo G570 43349EU 15.6" Windows 7 Home...
Tip
4 Proven Techniques to Reset HP Windows 7 password
<span>Forgot HP Windows 7 password? Don't be scared. You can follow these four proven techniques below to<span> </span><b><a href="http://www.passwordunlocker.com/knowledge/reset-windows-7-password.html">reset Windows 7 password</a></b><span> </span>on your own. Certainly, these four HP password reset methods will work in all versions of Windows 7/Vista/ XP and Server 2000/2003/2008.<br /> Technique 1: Reset HP Windows 7 password with Windows Password Reset DiskThis is an easy-to-use method to<span> </span><b>reset HP Windows 7 password</b>, however you need created a disk before<span> </span><a href="http://www.passwordunlocker.com/knowledge/forgot-windows-7-password.html">forgot HP Windows 7 password</a><span> </span>. And the HP Windows 7 password reset disk will only work for the account that have created another ones.<br />To create a password reset disk, you can log on HP PC and enter User Accounts by clicking Start button, Control Panel, User and Family Safety, and User Accounts. Then you can click Create a password reset disk on the left pane (Just as shown on the below picture). A password reset disk wizard will come up, and then you can follow it to<span> </span><b>create a Windows 7 password reset disk</b><span> </span>for your HP PC.<br />When you forgot HP Windows 7 password , your need boot computer to enter Windows logon screen. You'll view the reset password option when you type an wrong password on the logon screen and press Enter. Click on the option and the password reset wizard will pop up to guide you to reset HP Windows 7 password.<br /> Technique 2: Reset HP Windows 7 password with Windows Password HintWhenever you create or change Windows password, there will be an opportunity to type a password hint to prevent forgetting password. When type a wrong password, you will see the password hint be displayed to remind you what login password is. This is the easiest way to reset your<b><span> </span>forgotten windows 7 password</b><span> </span>for HP.<br /> Technique 3: Reset HP Windows 7 password with Windows System Recovery OptionsApart from Create a password reset disk and password hint, the OS Recovery Options can also help you to<span> </span><b>reset HP Windows 7 password</b>. Apart from Windows installation disc or the recovery options provided by your HP PC manufacturer to access the System Recovery Options. You also can create a system repair disc by yourself.<br /> <ul> <li>1. Input the word of" system repair disc" into the search box in the Start menu and press Enter.</li> <li>2. Insert a CD/DVD into the optical drive and hit Create disc.</li></ul>This guide will help to create your HP PC system repair disc. Hence, if you want to reset HP Windows 7 password by this technique, please insert the system repair disc into the optical drive and reboot the PC via this disc. And then choose the System Recovery option that will displayed on the prompt list of Windows installation.<br /> Technique 4: Reset HP Windows 7 password with Windows Password UnlockerIf those three methods that I mentioned above can't help you out. Maybe you need try this proven Windows password recovery tool named<span> </span><b>Windows Password Unlocker<span> </span></b>which can reset any windows password safely and instantly.<br /> <ul> <li>1. Download<span> </span><a href="http://www.passwordunlocker.com/windows-password-recovery.html"><b>Windows Password Unlocker</b></a><span> </span>and install it in any unlocked computer.</li> <li>2. Create a bootable CD/DVD or USB flash drive with the software.</li> <li>3. Set CD-ROM or USB device as the first boot device in BIOS for your PC.</li> <li>4. Boot your lock PC from the created CD/DVD or USB flash drive and then<span> </span><b>reset HP Windows 7 password</b>.</li></ul>Are you relaxed on HP Windows 7 password reset? Next time, you can do it yourself if meet with the similar issue.<br /></span>
on Apr 02, 2011 | Computers & Internet
What is the basic technique in welding
Hi:
Well don't know were to start, basic technique goes according with the type of metal to weld and type of wire to use.
I think if will be better if you read the basics of welding with MIG machines with an owner's manual. Check the link and go to section B-7.
http://www.lincolnelectric.com/assets/servicenavigator-public/lincoln3/im564.pdf
Sep 13, 2011 | Welding Tools
Direct3d device initialization failed
your video card doesn't support direct3d, or check out if your video card driver is properly installed on your device manager...
Jul 28, 2011 | Intel Video Game Consoles & Games
No hardware-accelerated Direct3D device were found . this the problem appears when I open my game. help me to solve this problem. or give me this kind of device.
depending on the windows you are using, the accelerators should install automatically, or else the system does not support or you can download the accelerators form microsoft and install them.
Jun 22, 2011 | Computers & Internet
My pc was not supported with my new o.s windows 7 the driver could not support wddm driver
The WDDM specification requires at least Direct3D 9-capable video card and the display driver must implement the device driver interfaces for the Direct3D 9Ex runtime in order to run legacy Direct3D applications
May 13, 2011 | Microsoft Windows 7 Ultimate for PC
I have ATI RAGE128 video card on windows 7. My computer tells me the driver is up to date, but Direct3D is listed as "not available" in dxdiag. Supposedly my card is supposed to be able to run...
go to microsofts website and download direct x9 and or 10 and that should do it also UPDATE your drivers on your video card that is huge. let me know if this helps.
Mar 17, 2011 | Dell VID ATI RAGE128 ULTRA 32MB LOW...
Rainbow six vegas 2 running slow? This game is running really sloooooooooooooooow on my desktop computer. These are my sistem specifications with updated videocard. I already tried changing to best...
i had the same problem. First, try downloading any patches that maybe be new, they can help.
then once in the game menu, go to the options and decrease the visual effects and graphics. they made this 2nd game to run in defalt mode with HIGH graphic computers, but if you just lower things to 800x600 and then set things to low, the gaame should run better, wont be perfect, but you will be able to play it with out getting mad at it..lol
Sep 23, 2010 | Rainbow Six Vegas - PC Games
No hardware-accelerated Direct3D devices were found swithiching to the reference rasterizer a software device that implements the entire direct3D feature set but runs very slowly.
more info please
But basically your machine is not detected a 3D video card.
It could be that a proper video driver has not been installed (Windows is using a default) so this maybe cured by simply downloading the driver for your machines GPU.
This machine might be using integrated "onboard" graphics, in which case don't expect very good performance especially with any recent game.
May 14, 2010 | Computers & Internet
MumboJumbo 7 Wonders of the Ancient World for DS Logo
57 people viewed this question
Top MumboJumbo Video Game Consoles & Games Experts
ray gallant
Tom Chichester
Are you a MumboJumbo Video Game Console and Game Expert? Answer questions, earn points and help others
