Question about Black and Decker USA Black & Decker 1900psi at 1.5gpm Electric Pressure Washer
My pressure washer hose conection broken, where fix?
The intake rod came loose from the machine. where to fix.
2002 chevy tahoa 5.3 codes p0171 0174
Trouble Code: P0171
Fuel Trim System Lean (Bank 1)
Possible Causes:
Air leaks in intake manifold, exhaust pipes or exhaust manifoldFuel control sensor is out of calibration (ECT, IAT or MAF)Low fuel pressure (fuel filter clogged, pressure regulator failure)One or more injectors restricted or pressure regulator has failedHO2S element is contaminated, deteriorated or has failedVacuum hose is disconnected, broken, leaking or loose.Trouble Code: P0174
Fuel Trim System Lean (Bank 2)
Possible Causes:
Dec 27, 2012 | Cars & Trucks
FH error on display
An FH error usually means low water flow into the washer. This can be caused by debris in the filters between the intake hoses and the washer, closed water valves, low water pressure or a problem with the system that checks the water flow.
Some intake hoses when they detect a leak will seal themselves. So you may want to replace them. Shut off the water valves and remove the hoses from the washer. Check the filters for debris. With a bucket under the hoses, open the valves and check the rate of water flow. You may want to check the filters on the valve side of the intake hoses after turning the valves to off again. If water flows into the washer and then into the drain, reset the drain hose. The outlet of the hose should be above the water level in the washer. Otherwise, the water will suction out of the unit.
If these parts are fine and there is still no water flowing into the machine, the intake valve is faulty.
If you are getting the error when the washer is full of water, it's the pressure switch or the flow meter. In a few cases, the cause is actually damage to the air hoses connected to the pressure switch. If one of these thin tubes is leaking, the pressure switch will not work properly.
I hope this helps.
Dec 12, 2012 | Kenmore Elite 45986 Front Load Washer
P0171 AND P0174B WHAT DOES IT MEAN?
Trouble Code: P0171
Possible Causes:
Air leaks in intake manifold, exhaust pipes or exhaust manifold.Fuel control sensor is out of calibration (ECT, IAT or MAF.)Low fuel pressure (fuel filter clogged, pressure regulator failure).One or more injectors restricted or pressure regulator has failed.HO2S element is contaminated, deteriorated or has failed.Vacuum hose is disconnected, broken, leaking or loose.Trouble Code: P0174
Possible Causes:
Air leaks in intake manifold, exhaust pipes or exhaust manifold.Fuel control sensor is out of calibration (ECT, IAT or MAF).Low fuel pressure (fuel filter clogged, pressure regulator failure).One or more injectors restricted or pressure regulator has failed.HO2S element is contaminated, deteriorated or has failed.Vacuum hose is disconnected, broken, leaking or loose.
Oct 24, 2012 | 1999 Chevrolet Express
E 02 Error Message
There is a problem with the water supply. This could be a symptom of kinked hoses, clogged filters in the intake valve or low water pressure.
Turn off the water shut-off valves and disconnect the hoses from the washer and then the shut-off valves. Place a bucket under the hoses to catch any water that drains out of the hoses. Check the filters both on the washer and at the shut-off side of the hoses. Sometimes, you need to use needle-nose pliers to pull out the filters from the intake on the washer. Make sure that the hoses are not kinked when you reinstall them. You may want to replace the hoses. There are some hoses that will seal themselves if they detect a leak. This will slow the water flow to the washer.
While you have the hoses off the washer's intake, test the water pressure by measuring the water flow into your bucket when you open the valves.
Also make sure that the washer discharge hose is not below the washer's water level for your load size. This leads to the water flowing in and then out of the washer before it fills the machine.
I hope this helps.
May 05, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Our washing machine was not daring fully. My partner had examined for a blockage in the drainage pipe and found two semi circular steel rods. After taking them out the plug fuses on the mains shortage when...
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Tools Needed
  • Screwdrivers,Flashlight,Voltmeter,Wrenches,Bucket,Rags or mo.
  1. A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  4. Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
Hope this help?
Thanks.
Dec 04, 2010 | Hoover Washing Machines
IS THERE A REPAIR KIT FOR A BROKEN PLASTIC NIPPLE
You can TRY eponxy .(Have to let it settle and get hard for a day or so.) This is a low pressure area10 - 15 psi. it may work NO guarantees. I've done it once that was on a 2000. . This car is still on the road. I have not touched the heater hoses since. Good luck
Apr 14, 2010 | 2003 Lincoln Town Car
My Kenmore washer model 110.2 had a broken (lidswitch?) replaced part but now water overflows i checked the clear hose but it doesn't seem to be loose or torn what else could it be Thank you -Fonz
You may have inadvertently knocked the air hose loose on your pressure switch inside the control panel. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
Remove the back of the control panel, or lift the console and inspect the pressure switch to make sure the clear plastic air hose is still attached. The pressure switch will be located behind the load level selector knob. With the hose removed, the water will not shut off.
If you have questions, please let me know. I hope this helps you.
Nov 17, 2009 | Washing Machines
Washer inside banging on the sides of the whasher and is loose ?
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 03, 2009 | Kenmore 22422 Top Load Washer
Over flowing
Read through the following link for advice on overflow problem with a washer:
A good majority of the problems I experienced in the field were caused by a simple loose air hose. Start by checking to make sure the air hose is still attached to the pressure switch. If the air hose is intact and NOT leaking, check the electrical connections to the switch for corrosion and or broken/loose wires. If all preliminary indications are good, replace the pressure switch. Read throught the link provided, thoroughly, and let me know if you require addtional assistance. I hope this helps you.
Nov 03, 2008 | Kenmore 22422 Top Load Washer
Black and Decker USA Black & Decker 1900psi at 1.5gpm Electric Pressure Washer Logo
661 people viewed this question
Top Black and Decker USA Garden Experts
James
richie46
Ruth summersides
Are you a Black and Decker USA Garden Expert? Answer questions, earn points and help others
