Question about DreamGear Dgps3-3812 Power Up Rechargeable Battery Pack For Ps3
Not charging and charging lights are very dim
Not taking a full charge.......and lights r not bright,very dim
06 bug drains battery over night
On most 12v cars,the #1 cause is a light left on somewhere in the vehicle.#2 cause is a bad diode in the alternator and #3 is a bad battery which self discharges and is usually over 5 years old.
An easy first step is to disconnect the charged battery over night.If it still has a full charge the next morning,after you reconnect it and if the car starts,you can rule out the battery as the culprit.Now,if the battery passed the first test,now we go onto #2 test and disconnect the alternator output wire from the alternator overnight.If the battery still has a full charge the next day we will now know the alternator has a bad diode and will need to be repaired/replaced.If the battery was found to be low on charge the next morning with the alternator disconnected we will now have to go on to test #3 to find the drain in the vehicle. Disconnect the positive battery cable and place a 12v regular bulb type test light between the positive cable and the battery positive post.You should have a bright light on the test light if you have a drain in the vehicle from the battery.(don't worry about a dim light as electronics need a little memory voltage) We are looking only for a bright light.With the key off (as it would be overnight) you are now going to remove one fuse at a time while watching the brightness level of the test light.Take one fuse out, look at the light and if no change in brightness put the fuse back in and on to the next fuse,one by one until you see the light go out or dim.The fuse that dims or removes the bright test light will be the circuit that is draining your battery.Now you have your "battery drain" circuit identified and can inspect/repair the item/items on that circuit.
REMEMBER an open door,trunk or hood may cause a FALSE bright light on your test light because of courtesy light switches and alarm switches so manually close those switches if you need to keep one of the doors or hood/trunk open to gain access to the multiple fuse boxes in many vehicles.
DO NOT TURN ON THE KEY during this test, as all power to the vehicle is now going through the test light and things won't be happy if you do.
Apr 09, 2017 | 2006 Volkswagen New Beetle
Casio G'zOne Commando 4G LTE screen dims
Go to settings
Display
uncheck automatic brightness and slight the bar all the way right to the brightest setting
Ckick OK
Mar 31, 2014 | Cell Phones
2007 Yukon XL, 1500 SLT, 4WD, headlights randomly go bright to dim and back very quickly
Yes this can be a normal condition caused by load being applied to the headlights and that lowers the voltage, the lites dim, then the load is removed and the lights brighten. Typical loads that cause this are AC climate control related. Have the Alternator load tested to confirm there is no problem in the charging system. Also have the battery tested, a battery that is starting to fail can cause this problem as well, a failing battery takes a huge amount of charging system power to keep it up, so that makes the lighting see higher spikes in voltage
Sep 18, 2012 | Cars & Trucks
Alternator tests good, but lights flicker dim, and wont charge battery
take a test light and check your fuses , make sure both sides of the fuse is hot ! check power at alternator if no power gos in no power will come out.
Sep 12, 2012 | 2000 Mercury Cougar
Dodge caravan dashboard lights are dim
something wrong with your car lead to the dashboard light are dim,
you can get a car diagnostic tool to check your car.
this tool can do your car, a little expensive.
May 13, 2012 | 2007 Dodge Caravan SXT Minivan New Cars
Vectorlite 1.5 candlepower shines a dim light instead of a bright white light.
Either the battery is not fully charged or it is time to replace it. Try charging the battery. If that doesn't work you will need to dissemble the light to obtain the replacement battery numbers. It should take (2) Model CA645 Batteries. They are 6 volt 4.5 amp hr.
Jul 16, 2010 | Camping, Backpacking & Hiking
How long does it take to charge metz 45-50 battery
it will take 4 to5 hr to charge the neon will be bright when the battery are weak the neon will be Dim when the battery are charge
Oct 27, 2009 | Metz 45 CL-1 Flash
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
DreamGear Dgps3-3812 Power Up Rechargeable Battery Pack For Ps3 Logo
89 people viewed this question
Top DreamGear Computers & Internet Experts
David Payne
David Payne
Are you a DreamGear Computer and Internet Expert? Answer questions, earn points and help others
