Question about Konica Minolta Office Equipment & Supplies
Crooked copies only on mixed orginials - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,168 Answers
Clean the rollers in the document feeder and check the paper path of the document feeder for a bent mylar or piece of paper etc
Posted on Jan 18, 2016
Printing copies crooked
prints ok from a different tray????????????????????
Feb 14, 2014 | Konica Minolta Bizhub C224 Color Copier /...
Crooked copies
Tighten the fences and guides that hold the paper in place. If the paper is not snug in the tray, it will not pull through straight.
May 27, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Everytime I try to download norton software online my internet explorer crashes and reboots.
it is not correct way of downloading the software in net because they are many types of software say orginial version and duplicate version or trial version etc . so i advise u to call the software people and ask them to download the orginial software
Jan 31, 2010 | Symantec Norton AntiVirus 2009 - 3 User...
Copies crooked
make sure back stop and side guides are against all edges of the paper in the drawers, ADF edge guides..same thing. does this happen out of all drawers? if so there is a registration roller (long and usually hard rubber) that has to be pressed evenly across to pull paper straight, usually has springs bent around both ends. If it is not drawers or ADF has to be in the path from drawer but before Fuser (hot area) best bet is reg roller.
Aug 04, 2009 | Konica Minolta bizhub C250 All-In-One...
Grinding noise crooked copies machine shakes
This won't be solved without a technician I'm afraid. It sounds to me like the fuser drive gears are worn ( it could be just about anywhere though), but this would account, in many cases, for the crooked , blurred print. whatever the case, there are gears worn, or seized, and in need of replacement. I would recommend calling for service asap, becuse this type of problem will only get worse and could cause further damage to the surrounding drive system the more it is used.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Paper feeder is not straight
Push the copy button with the cover up and no paper on the glass. Is the light bar straight up and down, or is it crooked? I can't imagine how paper could go thru the machine crooked, but check it out if you can. If the paper is too thin, it may not be getting grabbed by the rollers right.
Mar 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Crooked Cpoies
Pull all of the paper out of paper tray and reload. More than likely you will find some sheets on the bottom that are folded at the corners. This will cause crooked copies and also jams.
Jan 14, 2009 | Office Equipment & Supplies
Printing crooked from one drawer, and no option to print from another drawer
Try this spray on a little WD40 on the GLASS and wipe it off.
Yes, you heard me correctly, make sure you wipe it off leaving no residue, but it's still slippery.
the problem may be coming from the glass being too dry and the paper is getting stuckand shifting.
If the paper itself was going crooked it would get jammed or ripped. There is no room for the paper to go through the path crooked so the only way for it to copy crooked is somewhere in the optics.
try doing 1-2 on the glass itself and see if it copies crooked.
The envelope tray is a By-pass tray and can be used for any size paper.You can switch which tray it copies from on the panel tray button.
Aug 28, 2008 | Canon imageRUNNER 2200
2nd side crooked
I would have to say that there must be a same piece of paper touching the paper as it is being feed through the duplex ass'y. The best thing to do is to see if the copy gets tilted toward the front or rear of the copy/ copier. You will be able to find where the obstruction is in the dupex path.
Feb 23, 2008 | Canon D320 imageCLASS Digital Copier
Images coming out crooked when in copy mode. A hardware problem?
Ensure the guide for the plain paper onto which the image is printed, are pushed up fully. It is possible that the paper is being fed into the paper feed path at an angle if the guides are nut pushed up.
Jun 22, 2007 | Brother MFC-640CW All-In-One InkJet...
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
