Question about Zenith Z50P3 50 in. Plasma TV
Z50p3 no power or sound i repaced 10 amp fuse but blows again
97 chey blazer alernator overcharging, blowing fuses
Sounds like the 10 amp fuse was too small to begin with. Possibly the old alternator was too weak to blow it. 20 amp sounds more like it. Someone probably stuck the wrong fuse in at some time.
Jul 12, 2014 | Chevy S-10 Blazer 90-97 BT-1858
Amp fuse keeps blowing when car is turned off
It sounds like that fuse is supplying power to more than just the amp and is being shorted out in the START mode. Normally I would think the power to the sound system would be cut off by the ignition switch in the START mode. Try to find out what else that fuse supplies power to. You can disconnect suspected trouble areas to see if that helps locate the source of the fault.
Feb 16, 2013 | GMC Cars & Trucks
My kenwood reciever kr-a4070 keeps blowing a fuse
have you tried a different outlet? something my be wrong internally
Jul 31, 2012 | Kenwood Audio Players & Recorders
My jbl pb 10 has a noise and it burn the fuse... changing the fuse it burn the fuse again..so it might have som other defective part that is causin the noise and the fuse burning... any sugestion?
It blows the fuse because a semiconductor device has developed a short (in otherwords acting like it was just a piece of wire). Because of the noise I would suspect the main amp device is the cause. It will be most likely on a heatsink.
Feb 06, 2010 | JBL PB10 Subwoofer
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
1999 Chevy Venture 40 amp fuse keeps blowing when I try to start the van. This happened on three seperate days. I drove 150 miles and stopped the van. The could not start the van again. When I try to...
make sure of two things one is any wires touching at the starter to ground or melted and or is the starter drawing too much amperage causing the fuse to blow.starter may have a dead short in it.
Aug 16, 2009 | 1999 Chevrolet Venture
SONY KV-32S25 TV SHUT OFF...NO POWER NO SOUND
You have a blown fuse. It should be a GMA7 amp or a 5 amp. You could try to replace it and see if your TV works again. If it blows the fuse again, then there is something shorted causing the fuse to blow. Then call a good TV Tech.
Aug 03, 2009 | Televison & Video
Power Light, Pulsating Level Control, Blows Fuses
you may of caused a short in the connections or it got moisture why in storge if so the hole subwoofer is screwed
Jun 07, 2009 | Infinity BASSLINK Car Subwoofer
Radio quit working
does your system have power amplifier aside from your built in amp on radio? if yes, disconnect all supply then put new fuse. try this time, should not blow the fuse. then one by one, connect the supply fo your radio only, if ok, then next is the amplifier, if it blow the fuse, your power amplifier has an issue.
Apr 03, 2009 | 2001 Mitsubishi Eclipse
Amp blowing fuses
The amplifier probably has shorted output transistors.
Disconnect the speakers and RCA cables. Replace the fuses with two 10 amp fuses or a single 20 amp fuse. If the amp blows the fuse when it powers up, the outputs are almost certainly the problem. Don't try it with the two 30 amp fuses. The smaller fuses will provide more protection for the power supply. If the amp powers up with the smaller fuses and they don't blow, check the speakers and the wiring (for shorts to ground or shorts between wires).
Nov 22, 2007 | Rockford Fosgate p-450.4 Car Audio...
Zenith Z50P3 50 in. Plasma TV Logo
18 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
