Question about Electrolux EL5020 Vacuum
Stopped and won't turn back on again, even once I changed the bag on my Electrolux EL5020 Vacuum
SOURCE: Won't start.
There is a reset button at the back of the powerhead. The user manual can be downloaded from the electrolux website, although I didn't find it very useful. There was some info on how to change the powerhead drive belt.
Posted on Jan 08, 2008
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Posted on Jun 20, 2008
  • 566 Answers
SOURCE: Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Posted on Mar 01, 2009
  • 73 Answers
SOURCE: Electrolux Vacuum keeps turning off and light looks like bag with
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
Posted on Aug 27, 2009
SOURCE: i have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Posted on Jan 30, 2010
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Oct 20, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
The red light on my electrolux vacuum comes on and cuts power.
Mar 26, 2010 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Harmony Not working
maybe it is clogged. does the light go out if you turn it on with no bag?(for testing)
is the roller spinning?
Jan 07, 2010 | Electrolux Harmony Canister Vacuum -...
What is the symbol above the "change bag" symbol?
When the bag is full, the "full bag" light will come on and will turn itself off. Replace bag (make sure there is no clog) and try again.
Hope this helps.
Aug 17, 2009 | Electrolux Epic 6500 Vacuum
Vacuum just stopped working.
is there a filter in it if so clean the filter.try it without the bag in it.make sure the bag is in correctly.does the bag expand when you turn it on.you might have something caught up in the hose.take the hose off and blow througfh it.if you can't its clogged.also check the inlet where the dirt goes into the bag.the inlet might be clogged.please leave feedback
May 04, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux upright bag light stays on even when bag is not full
Once you change the bag, be sure to turn the machine off and back on to clear the fault. If it is the full bag light that is on, and not the "?" light, and you have a new bag in place, then you probably have a bad control valve. I would suggest finding the closest Aerus (formerly Electrolux) dealer and having them change it. It shouldn't be too expensive. If you have the "?" light illuminated, the bag probably isn't pressing the actuator like it should. When placing the new bag into the machine, be sure the bag top presses the small button in the lower right hand corner. Good Luck!
Jan 02, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Brushes not turning Electrolux Intensity (EL5020)
it needs a new brush they get stripped out by hair and stuff
Nov 20, 2008 | Electrolux EL5020 Vacuum
Won't start.
Oct 01, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL5020 Vacuum Logo
82 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
