Question about HEWLETT-PACKARD Pavilion Slimline Desktop / AMD Athlon II Processor / 3GB Memory (S5610Y)
Power supply was shuting down after a while and now it will only power up for a few seconds. If i unplug the power cord for about 5-10 minutes system will come on for about 5-10 seconds.
    Master:
  • 269 Answers
This may be a bad power supply or an overheating problem. be sure the cpu cooling fan is spinning and you don't get, possibly, a siren tone from the computer (usual warning of over heating) Make sure the heat sink cooling fins aren't clogged with dust and that the heat sink is attached to the CPU correctly. sometimes a clip breaks and the sink loses contact with the chip. if this happens, the chip will overheat almost immediately.
good luck
Posted on Aug 04, 2015
I just reset my dell computer back to factory setting. How do I now reset up for internet connection. My provider is verizon and I am using internet explorer
You want to reset your internet connection???
If yes then follow the given steps....
Step 1
Turn the modem so that the back of it is facing you. Locate the power supply cord connected to the back of the device.
Step 2
Gently unplug the power supply cord and leave it unplugged for about 10 seconds. If you also have a router connected to the modem, disconnect the power cord of the router as well.
Step 3
After about 10 seconds reconnect the DSL modem power cord. Wait for the status lights on the front of the unit to come on. They may blink at first before turning solid green, or they may first illuminate as orange, then turn green, depending on the modem model. The "Internet" and "Incoming" lights may continue to flicker, this is normal operation for modems.
Step 4
After the modem is reset, reconnect the router power supply if you have a router. Wait a few minutes before resuming normal Internet use.
If you need any kind of technical assistance you can contact support cell
Jan 19, 2013 | Computers & Internet
Install power supply
No Power on an HP Pavilion PC Desktop b> Desktop computers are simultaneously more complex and easier than laptops when it comes to troubleshooting. There are more physical components on a desktop, so locating a specific troublesome part can be tricky, but working inside of a desktop computer is straightforward compared to opening and fiddling with a laptop. Power problems are always hardware problems. There are a few simple, preliminary steps to troubleshooting, but power problems often require opening your computer and having a look inside.
The Basics
Unplug everything from your PC except for the power cord. Try turning on the system and look for lights on the front, then on the back. When the power supply is on (receiving power), the small light beneath the plug turns green. If this light doesn't come on, the problem is either connected to the cord or the power supply. Try swapping power cords with the monitor cord to isolate the cord as the source of the problem. Look closely at the voltage selector and make sure it's set appropriately for your country -- 110 in North America and 220 for most other regions. b> The Socket b> Unplug the power cord and switch the voltage selector to the opposite setting. Wait five seconds, then flip it back. This ensures that the switch is engaged. Plug in the power cord again and try turning on the PC. Check the outlet to make sure it's working, and plug your computer direction into the wall socket (remove it from any surge protectors or power bars). Check the power button. If it sticks when you push it, it may not be making contact to engage the system power and will need to be replaced. If the button is going in and out freely, you've done about everything you can do from the outside of the computer. It's time to go inside. b> Open it Up b> Unplug the power cord and hold down the power button for five seconds. This clears all electrical charges from the circuitry and makes it safe to open the computer. Remove the side panel from your system. This process varies a bit from model to model -- some have one or two captive screws on the back of the system, some have an easy release button. Check your manual. b> Power Button b> Locate the power button from the inside and trace the cables to where they plug into the motherboard. Lift up on the connector and then push it firmly back down. Plug the PC back in to its power source and try to power it on. Unplug the computer immediately if the system doesn't power up, and continue troubleshooting. b> Hardware Components b> Disconnect each of the devices in your computer one at a time to locate a faulty piece of hardware. Power cables run from the power supply connect to your optical drive, hard drive, floppy drive (if one exists) and into several places on the system board. This step takes some trial and error detective work and a few minutes: unplug one device, reconnect the power, and try turning on the system. Then disconnect the AC power, plug the device back in and try the next one. If the system powers up at any stage, the device you are unhooking is shorting out the power and needs to be replaced.
http://www.youtube.com/watch?v=HJvYGtbwmh8 To Replace HP Pavilion Desktop Power Supply http://www.youtube.com/watch?v=VcEFUpZSmI4 Hp Pavilion 750n desktop computer basics on this computer b> http://www.youtube.com/watch?v=D8Y2PPMiiB0 HP Pavilion Slimline PSU Upgrade Guide This guide compares the Sparkle SPI270LE - 270 watt PSU against the Shuttle PC50 -300 watt as possible power supply upgrade for a HP Slimline. The s3600t Slimline I used for this video has a Intel Hope this helps.
Jan 03, 2013 | HP Pavilion 761n PC Desktop
The tv is stuck on standby. I unplugged it and left it sit for 20 minutes and replugged the power. It turns on like normal and after a few seconds it goes back to standby
The power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 28, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
HELP!
i think the problem is of the power supply the board did not get enough power to stay on
Dec 21, 2009 | ASUS P7P55D PRO Motherboard
Lg lrm-519 went into demo mode. Can't get it back
follow directions from the owners manual. while unit is powered up, unplug power cord from back of unit - wait 5-seconds. Depress the DVD open/close button while re-plugging the power supply cord to the unit. LG splash appears onscreen and unit goes into re-set. you do not loose any of you programing or settings.
Jul 18, 2009 | LG Electronics LRM-519 Digital Media...
My dishwasher completed a wash today but when I turned it on to do a second wash it will not come on. There is no problem with the power supply as the on light is green.
Try unplugging the power cord or switching off the circuit breaker that feeds power to it for a few minutes and see if that clears the control logic after reapplying power.
Sep 23, 2008 | Dishwashers
My rt2280
the quick answer is turn it off from the power button, then press the dvd button or whatever button you are using.Do it twice if it needs it.
Mar 13, 2008 | RCA RT2250 System
HEWLETT-PACKARD Pavilion Slimline Desktop / AMD Athlon II Processor / 3GB Memory (S5610Y) Logo
48 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
