Question about Radio Communications
My jabra bt2010 doesn't turn on - I can't get an LED light from pressing the on off button, have tried various tap and/or hold lengths. It isn't just a faulty LED either as the unit has no function. I
This is a new unit.
  • 3 Answers
SOURCE: Jabra BT2010 Bluetooth Headset help
Hey guys, hold the button pressed for 6 sec. until led is solid. then search bluetooth devices on phone click on Bluetooth headset insert '0000' press OK now it should work, or check http://jabra.com for compatibility. Best wishes, htmlfreak.
Posted on Nov 14, 2008
SOURCE: Cannot Get Jabra BT150 into Pairing Mode
I had problem with my bluetooth not getting into pairing mode,and Now it working good.
Thank you for your best solution.
Posted on Nov 17, 2008
SOURCE: Bluetooth stopped connecting - solid light
I followed one of the solutions that I found on your website! I deleted and added the connection on my phone again and used 0000 as the pin number.
Worked great!
Posted on Apr 09, 2009
SOURCE: I need to find replacement earhooks for a Jabra BT2010
Posted on Jun 13, 2009
  • 5 Answers
SOURCE: new jabra A210 not charging
I had not used my A210 in a couple years, and when I needed it again now, I TOO GOT THIS SAME EXACT SYMPTOM: where it would light red (charging) only for 2 or 3 seconds, and then be off. Hours on the charger and no charging or difference. I tried plugging it in a few hundred times to see if it would "jump start" for the 3 seconds to add up, no luck. I WAS VERY GLAD to read MightyFrosty could change something inside and get it working. I followed his advice up to "removing the tiny circuitboard on the tiny battery and resoldering". Instead (got the case open with a razor blade, gently) I removed the amber tape that wraps the battery/circuitboard assembly and tried first "jumping" the red to the "+", nothing~ but then jumping the black to the "-" the RED LIGHT came on and STAYED ON! (but only while "jumped". Better yet after some 20 minutes of "jumpered" charging, the RED LIGHT STAYED ON even when I removed the tiny jumper~! (a tiny wire is all, bent to touch the black wire solder spot and the "-" battery lead). so IT APPEARS it CAN CHARGE PROPERLY on its own once the battery has a little juice in it! It is charging completely normally now (red light solid, no jumpers, and with no cuts or circuit removals!). I believe I can reassemble it all tomorrow and have a non-modified operational bluetooth Jabra! Thank you MightyFrosty and good luck to all!
Posted on Nov 12, 2009
I have a jumbo remote, lost my manual. I would like to program it to operate a sanyo tv. I need instructions please.
First, make sure the device you want to connect with your remote is turned on, whether that's the television, DVD player, VCR player, etc. Now aim the Innovage remote at the device. Press the button on the remote control that corresponds to the device (TV, DVD, etc.). Now, press and hold the SET button on the remote control until the LED light on the remote control holds a steady red.
Enter the 4-digit code for your device by pressing the number keys on the remote control (see list below). When you press the fourth digit, the LED light should turn off. This means the remote and the device are "speaking" to each other. Press the OK button to store the code.
If the LED light blinks three times and then remains a solid red, the Innovage remote doesn't recognize the code for your device. Verify the correct code, then go through the programming steps again.
Test the function by using your remote to cycle through all programmed devices (TV, VCR, etc.).
If your device code isn't listed, try the Code Search function:
Turn on the device you wish to match with your remote. Aim the remote at the device and press and hold the Code Search button in the upper left of your remote for at least 3 seconds until the LED light on the remote turns a solid red. Press the button on the remote for the item you want to program (TV, DVD, etc.). The LED light should blink once and then remain a solid red.
Press the On/Off button slowly until the device you want to program turns off. The LED light will blink once each time you depress the On/Off button. When the device you want to program turns off, press the ENTER button. The LED button will turn off and the code for that device will be stored in your remote.
The codes to various devices are listed at:
www.remotecentral.com
Please note that there are often several codes for one particular device. It may take several programming attempts until you find the code that works with your device.
May 20, 2011 | Innovage Jumbo Remote Control
Jabra BT2050 blinks three times; doesnot pair up
Hold round center button for 10 seconds, light will stay on and be in pairing mode.
Nov 20, 2009 | Jabra BT2050 Bluetooth Headset
Worked great!
Apr 09, 2009 | British Telecom Jabra BT2010 Wireless...
Problem pairing my Jabra vbt 2050 with my blackberry storm
Hold the volume up (+) button down along with the call button for 5-10 seconds (until the led lis solid). Then, while the led is lit up, initiate the pairing on your phone. It should pair this time. It worked for my phone, which was having the same problem you described.
Mar 04, 2009 | Jabra Bluetooth Headset with Adjustable...
LED light is inconsistent
To pair the device you need to press it long so the LED is constantly lit ...
Make sure that you have turn the headset off first to enable pairing ...
The pass key at default is 0000
Jan 07, 2009 | British Telecom Jabra BT2010 Wireless...
Jabra bt125 won't pair to motorola razor v3
I had the same problem and found the user: Splut wrote in another problem the following solution: If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. I tried that to connect my Blackberry phone to my Jabra BT2010 headset and it worked!! I had tried everything prior without success. I hope this works for you. DIVA08
Dec 15, 2008 | Jabra BT125 Headset
I do not have manual for jabra bt160 how do i connect to phone
Wear it how you like it 4
5
English
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2 )
For optimal performance,wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight.In general,you will get better performance when
there are no obstructions between your headset and your mobile phone.(See fig.5 )
Answer a call
Tap the answer/eend button on your headset to answer a call
End a call
Tap the answer/eend button to end an active call
Reject a call (DDependent on your phone supporting this feature)
Press the answer/eend button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (ssubject to phone
settings) automatically transfer to your headset
Activate voice dialing (DDependent on your phone supporting this feature)
Tap the answer/eend button. For best results, record the voice-dialing tag through
your headset. Please consult your phone ’ s user manual for more information about
using this feature
Redial last number (DDependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+or – ) to adjust the volume (See fig. 1 )
How to...5
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing 2 mode
Make sure that the headset is on.
Press the answer/eend button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘ discover ’ the Jabra BT160
Follow your phone ’ s instruction guide. This usually involves going to a ‘ setup,’
‘ connect ’ or ‘B luetooth ’ menu on your phone and selecting the option to ‘ discover ’
or ‘ add ’ a Bluetooth device.** (See example from a typical mobile phone in fig. 4 )
Pair it with your phone 3
English
Turn on your headset 2
Press the answer/eend button to turn on your headset
Press and hold the answer/eend button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
The Jabra BT160 is easy to operate. The answer/eend button on the headset performs
different functions depending on how long you press it.
Instruction:Duration of press:
Tap Press briefly
Press Approx: 1 second
Press and hold Approx: 5 seconds
Getting started
3. Your phone will find the Jabra BT160
Your phone then asks if you want to pair with it. Accept by pressing ‘ Yes ’ or ‘ OK ’ on
the phone and confirm with the passkey or PIN 3 = 0000 (44 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
repeat steps 1 to 3.
http://www.jabra.com/Sites/Jabra/UK-uk/support/Pages/JabraBT160.aspx
It is all in there www.jabra.com
ARTGIRL
Jul 18, 2008 | Lands Phones
Jan 03, 2008 | Radio Communications
Jabra vbt185z, light stays on, won't connect to phone
My head set had another pin code other than 0000 when I recieved the unit which made it dificult to connect. I learned how to reset it to the default pin of 0000 which allowed me to sync it with my phone. After using it for a month or so my phone requested the pin again.I entered 0000 and once again would not accept the pin. I had to retore the default pin again and it works just fine. Here are the instructions. Plug your vbt185z into the wall charger and while connected press down and hold the center blue button untill the light comes on.(about 30 seconds)Unplug the the ear piece and turn the unit on.Now enter pin 0000 and your phone should accept the pin.
Dec 29, 2007 | Nokia 1600 Cellular Phone
Jabra bt160
hold the button down for a long time
Apr 17, 2007 | Jabra COMMUNICATIONS BT160 Bluetooth...
Radio Communications Logo
47 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
