Question about KitchenAid KGHS01PMT Electric Dryer
My dryer turns on but wont run
My dryer was working fine and all of a sudden the light bulb went off and from that point on the dryer stopped working. i replaced the bulb and it still dont turn on. so the dryer turns on but it wont run.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
There are several bimetallic heat sensor switches in a dryer. Check them first, then the continuity of the door switch, then the control unit ( I usually get mine rebuilt), finally the motor as a last resort.
Posted on Feb 13, 2014
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
Headlights wont work, just suddenly stopped!
recheck them fuses sometimes they dont look blown but they are if not there must be a loose connection somewhere i know you have checked but retry
Jul 28, 2010 | 2005 Suzuki SV 650 S
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
May 26, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Turning Lights Not Working
If you put a 2 element bulb in a single bulb elemet socket you would or could destroy the flasher unit. Especially if it is a electronic flasher try replaceing the flasher but get mechanicl flasher they last longer.
Jul 09, 2009 | 1998 Toyota Sienna
The light will not turn off and dryer wont run
CK,
There's a switch behind the dryer door. Push it in and out with your finger, you should here it "click, click, click" and the light should go on and off. If it doesn't, you'll need to replace the door switch.
If that's the case, I'll need the full model number. It's on a sticker on the front panel behind the door. (it should be like three digits, decimal point and about 7 more numbers... 110.*******) With that number, I'll be able to look up parts for you and guide you through this easy repair.
SG
Apr 08, 2009 | Kenmore 64952 Electric Dryer
Brake lights wont work! All others do!
I just had the same problem on my '04 Silverado. All it was was corrosion in the socket/bulb. Put some dialectic grease on both the bulbs and worked them in and out a couple of times and now they work fine. Was weird that they both went out suddenly and together but I guess they are made exactly the same.
Apr 05, 2009 | 2004 Chevrolet Silverado
Dryer wont run
Remove the rear cover and replace the skinny white fuse mounted on the blower housing after you have cleaned out the lint from the dryer. (unless you like to keep buying and replacing them)
Jan 27, 2009 | Kenmore 62602 Electric Dryer
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
KitchenAid KGHS01PMT Electric Dryer Logo
44 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
