Question about Canon PowerShot A720 IS Digital Camera
SD Card will not 'seat' in camera - Canon PowerShot A720 IS Digital Camera
    Top Expert:
  • Canon Master
  • 6,702 Answers
Do you mean, it won't stay in place?
when you insert the card correct, it will lock in the correct position. When you want to remove the card, you have to push on the card till it says click and then release the card, it will come out because a spring is driving it.
If you managed to pull out the card, perhaps you damaged the locking system and you have a problem. Also chai if you did not try to put it in, the wrong way around. All efforts to put in a memory card other than the correct way, can end in a damaged card holder.
Success
Posted on Feb 13, 2014
My Dad, 91years old, received a Kodak Easyshare model z1285 from a friend for christmas. no manual. He lives 400 miles away and called to ask if I knew where the SD card goes. Since I can't see the camera...
The door to access the SD card slot is on end of the camera which is closest to the round knob on the top of the camera.
If you turn the camera on end and look at the door, it has small groove in it that is about an inch long. Holding your camera in your left hand with the lens toward your palm, take your finger nail of your right fore finger and slide the door toward the back of the camera.
The door will swing open, revealing the slot for the SD card. When you get the camera, there may be a "dummy" plastic SD card in the slot. Release it by gently pressing the edge of the SD card and quickly releasing it. The card should pop up about a half inch and you can grab it with your fingers and pull it out.
Replace it with a fresh SD card, making certain that it is oriented with the label facing the back of the camera and the contacts facing the front of the camera. Gently push it into the slot until it seats. Don't force it. The card should go in with a little resistance, but does not require a lot of force to seat. Pressing it too hard will cause it to pop back out again.
If it doesn't seat properly, the card may be flipped the wrong way. The card should go into the slot contacts edge first, contacts facing the front of the camera and the label facing the back of the camera.
I hope this helps,
Art
Jan 01, 2011 | Kodak EasyShare Z12851 Digital Camera
What memory card do I buy for my Kodak easyshare C530 camera.l The one I purchased was a SD card and it would not allow me to format.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=7551/7269&pq-locale=en_US&expression=sd
The above link goes to a site that describes how SD or SDHC cards can be used in newer C cameras such as yours.
Also, the following should be noted regarding sd cards:
Question : Why doesn't my camera recognize the SECURE DIGITAL (SD) or MultiMedia (MMC) memory card that is in the camera? Answer : Your camera may not recognize the memory card inside for one of the following reasons:
  • The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
  • The card may be corrupted. Reformat the memory card.
    CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
  • The card may not be a certified SD or MMC card. Purchase a certified SD or MMC memory card.
See your camera's user manuals for more information. Go to KODAK Product Manuals, and select the manuals you need.
Jul 26, 2010 | Kodak EasyShare C315 Digital Camera
The memory card cannot format rejects reformating
You card might be faulty or not supported by this model.
The memory card support for V610 is SD/MMC up to 2 Gigabyte
Format your SD card. NOTE this will delete all existing data on your SD card.
Do the following:
  1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  2. Turn on the camera.
  3. Press the Menu button, then go to the Setup Menu.
  4. Scroll up or down to the Format option, then press the OK button
Jan 25, 2010 | Kodak EasyShare V610 Digital Camera
When i take pictures rapidly the screen says ''processing'' , often for up to10 seconds or more. this happens with a 2 gig non hi def card and 8 gigHD card. regardless of pixel setting.this has just...
It could be caused by your SD card needing to be formatted.
Do the following:
Jan 25, 2010 | Kodak EASYSHARE Z1285 Digital Camera
When Im trying to deleate my pictures it says to reset the switch
Do the following:
Jan 19, 2010 | Kodak EasyShare M863 Digital Camera
Will not format memory card
How to format the memory card in my camera? NOTE this will delete all existing data on your card.
  1. Do the following:
  2. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  3. Turn on the camera.
  4. Press the Menu button, then go to the Setup Menu.
  5. Scroll up or down to the Format option, then press the OK button
If you still experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
    After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 16, 2010 | Kodak EasyShare C913 Digital Camera
    Out of memory on Nikon Coolpix L18 camera
    I noticed that, after dumping the full SD card onto my computer, I didn't seat it perfectly back in the camera (my finger bottomed out on the batteries before the memory card 'clicked' into place. With the camera unable to see the SD card, it defaulted to the internal memory, which is very small.
    I got the SD card seated fully and the "Out of Memory" message went away.
    Aug 14, 2009 | Nikon COOLPIX L18 Digital Camera
    Coolpix l5 - SD card won't seat
    The Nikon are very good about placing a sd symbol on the door of the memory compartment. The trick is to align the dog ear side of the memory stick with the picture on the door the push down until the stick bottoms out in the slot it should then lock in to place. Conversely to remove it push down again until it un locks.
    Dec 07, 2008 | Nikon COOLPIX L5 Digital Camera
    Cannot insert the memory card - push in, won't seat, springy feel
    Make sure that you insert the SD card in the correct orientation. If not, it will not lock into place. The SD card is push in to insert and push again to eject.
    There is a small diagram showing the correct way to insert the card just below the left hand side of the slot.
    Doug
    Nov 03, 2008 | Canon PowerShot A720 IS Digital Camera
    Camera doesnt recognize a Secure Digitalor MultiMediamemory card?
    The cause and solution may include one of the following: The card may not be certified SD or MMC. Purchase a certified SD or MMC memory card. The card may be corrupt. Reformat the memory card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
    Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
    Canon PowerShot A720 IS Digital Camera Logo
    29 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
