Question about LG Flatron W2242TQ-BF 22" LCD Monitor - 4:3 - 2 ms
Monitor has gone to power saving mode
Tried moving mouse in circle pressed keys
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
Hello, The reason your monitor switched to power saving mode is because the operating system on your computer told it to. A computer left on and unattended is programed to sleep/hibernate after usually a short period of time. Without going to in depth, There are stages of sleep and after time the hibernation deepens. However, moving the mouse or pressing a key should take it out of sleep. Microsoft has a support page for this issue: http://support.microsoft.com/kb/266283 Good Day
Posted on Feb 13, 2014
5 Suggested Answers
  • 298 Answers
SOURCE: LG 194wt
Did you check the energy saving settings for the monitor
The display settings in control panel should have a tab
for screen saver that also has settings for the monitor
power saver setting. If there is a setting for Digital Power Saving mode adjust it or disable it.
If this does not solve the problem then you may have to
disable APM in the bios setup
Posted on Nov 13, 2007
LaptopExpert
  • 458 Answers
SOURCE: LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Posted on Jun 02, 2008
  • 110 Answers
SOURCE: my monitors sleepy
it may not be your monitor, it may be your PC or video card. Try restarting your PC, does your monitor work?....
or unplug the power from your monitor for a minute, then plug it back and try it.
Try a different monitor, if a different monitor works on your PC then it is definitely your monitor.. if a different monitor does the same thing, then it is your PC.... either your motherboard or your video card if you have one.
Posted on Sep 11, 2009
Testimonial: "thnx i spoke to a guy bout it he said it could be my graphics card so i tried the switch around with monis on comps and the moni on my comp didnt work"
  • 252 Answers
SOURCE: I have a LG W2361VG monitor and I can't get it off
These are just suggestions, not sure if it will fix your problem (not listed in any order but only do one at a time)
1. Change BIOS battery (reset BIOS)
2. Clean out machine (dust, reseat cables, cords etc...)
3. Try removing the power cord from the monitor, hold the power on button for ten seconds then put the power cord back on
4. Try reseating the video card.
Hope this helps.
Posted on Oct 21, 2009
How to fix screen says in power save mode press any key move mouse
Try turning the screen off and on again, if that does not help then did you try to move the mouse and please also say what monitor are you using?
Mar 05, 2013 | Computers & Internet
Power Save mode on, can not use computer
If your computer is indeed running, simply unplug your monitor from the wall, and then plug it back in. This will bring your monitor out of power save mode instantly.
Apr 22, 2010 | Dell Dimension 8400 PC Desktop
Screen is black and power button gone amber colour.if you press buttons on monitor it says,in power safe mode press any key or move mouse. when you do this nothing happens
Restart the computer and turn off power save mode. If this is vista the power save mode has a lot of problems and can cause things like this to happen.
Sep 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP stuck in power save mode
Good morning! kindly try to review/check the operations manual of your monitor as there might be proper set-up settings / compatibility requirements to a certain PC. best regards
May 09, 2009 | Dell Dimension E520 PC Desktop
In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Nov 17, 2008 | Dell E173FP 17" LCD Monitor
My screen has gone black
try to reseat the vga cable of the monitor,reseat at the back of the computer and on the monitor,if the cable is disconnected,make sure that you can see the power on self test with different colors in it,if you cant see it then your monitor went bad,try to connect another monitor to your computer,see what will happen,try using other cables as well
Jul 05, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
In power save mode
Try hitting the space bar on the keyboard. Does the mouse work normally?
Nov 30, 2007 | Dell E173FP 17" LCD Monitor
LG Flatron monitor remains in Power Saving Mode
Sounds like an issue with a memory card or pci card not properly in place. Try opening up the sytem, then make sure each card is properly inputted in it's slot. This may cause the the monitor to show power saving mode especially if the memory is not properly placed.
Thanks
Nov 21, 2007 | Computers & Internet
LG Flatron W2242TQ-BF 22" LCD Monitor - 4:3 - 2 ms Logo
160 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
