I have a new CS7000 pvr. I hooked this up to my preexisting bell expressview dish which has: 2 LNBs legacy i believe connected to 1 sw21 switch then wired to the reciever.
Plugged into my expressview I have 95% signal of nimiq satalites 82 & 91 Plugging into my CS7000 I recieve no signal at all on these sats. some others sats give me 35% & one 40% no channels though
Plug back into expressview reciever and bang 95%
What I need to know is am I doing something wrong?
Clean installed Windows 7 on my HP m9350f computer and it works fine except when trying to run a...
(More)
Clean installed Windows 7 on my HP m9350f computer and it works fine except when trying to run a backup on my HP HD5000s personal media drive. Neither Window 7, Norton 360, or GFI will perform a successful backup. Only get error codes 0x80070002; 0x80070006 and 0x81000002. Had to download and install sp26942.exe to change the HP PMD file format from RAW to NTFS. Ran Windows 7 Action Center maintenance which said sp26942.exe is incompatible with Windows 7. I think a new HP driver is needed, but I do not received an answer from HP or Microsoft on when they will have a new driver for the HP PMD. Any ideas other than waiting for Windows 7 SP1 or a new HP driver?
Have gateway pv with vista. For no apparent reason the motor races and the pc turns off only to...
(More)
Have gateway pv with vista. For no apparent reason the motor races and the pc turns off only to reboot. It does this several times daily.
when i open the appleworks program it goes to the starting point menu and then tells me to relaunch...
(More)
WHEN I OPEN THE APPLEWORKS PROGRAM IT GOES TO THE STARTING POINT MENU AND THEN TELLS ME TO RELAUNCH THE PROGRAM
THIS IS APPLEWORKS 6.2.4
