Question about Toshiba Satellite Pro L300 Notebook
How to remove keyboard in the toshiba satellite P875-s7200
    Master:
  • Toshiba Master
  • 752 Answers
joecoolvette
  • 5660 Answers
SOURCE: Replace keyboard on Toshiba Satellite 1410-s173
First remove the AC adapter (Charger) if plugged in. Then remove the battery.
Next step is removing the Keypad Securing Strip. This is a plastic cover right Above the keypad, and below the LCD screen. Looking at it, you'll notice on the Left and Right sides of it, that it has a U-shape.
This U-shape covers the LCD screen hinges.
Take a small flat tip jewelers screwdriver, and come from the right side of this plastic strip. You will see a thin parting line, where this plastic strip meets the laptop body. Your flat tip goes in this parting line. You have to use finesse. It's doubtful you'll break the plastic strip, as it's REAL tough! But if you slip, you could scratch the plastic. (Actually, it's pretty hard to scratch that plastic! Just thought I would caution you. The plastic strip is made of a spaceage plastic. Pretty tough stuff!)
The plastic strip has tabs around the edges, every so often. These
plastic tabs snap into place, and hold the Keypad Securing Strip on. When you begin, it's a little tough to get that flat tip down in there. (Remember ->Jewelers screwdriver!)
Plus, you may be at one of the points that there is a tab. Usually there is a 'dimpled' flat place, that looks like a flat tip should go there.
With the flat tip jewelers screwdriver inserted a little, ease back on the screwdriver, and lift the plastic strip up.
It will look like it's bending. If you have another flat tip Jewelers screwdriver, or a small butterknife, you can insert it, and hold this part up. Then take the other flat tip, move over a little, and start lifting up.
Once this Keypad Securing Strip starts coming up, it will come to one of those tabs, and the tab will come up and out. You'll hear a POP, and think you broke it! You didn't.
Go along the edge, and keep popping this strip up. Use caution, as to how far you insert that flat tip screwdriver!
There are tiny little wires under there, and you don't want to pinch one, or tear it loose. Keep the flat tip, about a half a fingernail length in, and you won't.
Once you get towards the other side enough, the strip will let loose, and come up.
Without disconnecting the wires, see if you can lay the strip towards the back, and lay it out of the way. Towards the LCD screen. You are trying to get to the screws, that secure the keypad. They will be in a metal strip for the keypad, and towards the LCD screen.
I can't remember at this point if there are two, three, or four screws. You'll be able to see, and you'll know.
(Use Caution! You can easily drop these screws! They might go right into the body of the laptop. You MAY be lucky enough, to pick the laptop up, turn it over, and gently shake the laptop, to have them fall on the table. You MAY not be so lucky, and have to disassemble the entire laptop, to get to them!)
IF, the Keypad Securing Strip will not lay out of the way, so that you can get to the keypad screws, you'll have to remove it.
It isn't tough, but it looks daunting the first time.
You will see small White connectors in the middle of the cables.
Two wire cables, if memory serves. These connectors are small White rectangular blocks. There is a Female and a Male. You just take your fingernails, and ease the connectors apart.
Don't worry about how they go back together. They are different sizes. You just match up the size.
Now with the keypad securing screws removed, ease the keypad forward a little, and bring the front of it up to a tilted position. (Towards the LCD screen is the front of the keypad) You don't want to bring it straight up, as there is a flat ribbon cable you need to disconnect. The flat ribbon cable attaches at the back of the keypad. (Towards you) It has a White connector.
This connector is different, from the ones you have disconnected already. The connector itself has a locking 'bar'.
This thin rectangular piece of plastic, goes across the length of the connector.
It is positioned at the front of the connector. It comes forward, towards the flat ribbon cable end, that is connected to the keypad.
It slides. It only slides so far, then stops. It is at this point, that you remove the flat ribbon cable itself. The one towards the keypad. There will be No connector on that flat ribbon cable. It will be just the ribbon cable itself.
When you reattach it, you just slide the flat ribbon cable back into the White connector. Then you ease that locking bar back into position. The position that it started from.
Now reverse your steps.
Posted on Apr 18, 2009
sams_trix
  • 93 Answers
SOURCE: How to remove the keyboard from a toshiba satellite a100
Usually they are snap-in type,you must use thin edge or cutter or flat screw driver not to leave a mark on plastics.After removing cover the screws will welcome you.file:///C:/Documents%20and%20Settings/All%20Users/Documents/Removing%20keyboard%20from%20Toshiba%20Satellite%20A55%20laptop.rar
Posted on Aug 31, 2009
leecom72
  • 4806 Answers
SOURCE: How to remove keyboard on Tosh A60?
Above the keyboard you should find the thin cover which you have to remove. This is called the keyboard bezel.
Get a fine flat headed screwdriver and gently lift the bezel up from the right hand side of the laptop above the keyboard. Once you have lifted one side gently pull the bezel off with your fingers.
Under this cover you will find two screws which secure the keyboard. Remove these screws and lift the keyboard up.
Please be careful. The keyboard is connected to the motherboard with the flat ribbon cable.
Regards.
Posted on Nov 11, 2009
  • 6 Answers
SOURCE: How to remove and replace the keyboard on a Toshiba notebook
Manual at Here (http://uk.computers.toshiba-europe.com/innovation/download_manuals.jsp?service=UK)
it should tell you in there, you may need a positive screw driver as well
Posted on Feb 12, 2010
matt_g_walke
  • 62 Answers
SOURCE: Toshiba C675-S7200 Manual Download
The manual can be located at: http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su3131314/GMAD00278010_Sat-SatProC600_11Mar15_updated06272011.pdf
Hope that helps!
Posted on Nov 29, 2011
How do I remove the bezel from the screen of a Toshiba SATELLITE LAPTOP p875-s7102
Hi
I haven't found anything specific to the model given, but the link below takes you to a movie showing how to replace the screen on a p870, which may be similar to yours
http://www.laptopscreen.com/English/video/Toshiba/satellite/p870/
This link below takes you to a website where there are many, many models of Toshiba laptops with disassembly instructions. Again I couldn't find your model but you may be able to find a similar one
http://repair4laptop.org/disassembly_toshiba.html
Good Luck
Oct 18, 2014 | Toshiba Computers & Internet
How to disassemble a p875-s7200
https://www.youtube.com/watch?v=B-vA_jkqHDY
Aug 05, 2014 | Toshiba Satellite P875 Laptop Computer -...
Convert windows 7 32 bit to windows 7 64 bit
Only way to convert a computer from 32-bit to 64-bit is by buying a new motherboard and processor that are 64-bit compatible.
Now for your issue of finding ethernet drivers, that could be done by using your Device Manager. If you could provide more information as to what is displayed in your Device Manager, I could better assist you.
Mar 31, 2014 | Toshiba Satellite P875-S7200, P875-S7310...
Broken screen replacement
A quick search on Ebay using the model number of the laptop will bring up quite a few screens for it. There are two designs you will have to decide on. Glossy or Matte finish. Glossy gives a more rich detail but have a horrible mirroring issue. Matte is a flatter detail but helps resolve the mirroring issue. I myself prefer matte finish on laptops due to sun glare and mirroring issues.
Mar 21, 2014 | Toshiba Satellite P875-S7200, P875-S7310...
Screen damaged
take the screen out look at the of the screen the shoud be a long asz number on the back, use that number to order a new screen from the manufactur
Mar 15, 2014 | Toshiba Satellite P875-S7200, P875-S7310...
P875-s7200 lcd backlight
Repost under PC for an answer
Jul 24, 2013 | Computers & Internet
Satellite c675 repair manual
THE MOST YOU CAN GET IS THIS, INSIDE WILL GIVE YOU IDEA.
http://www.manualgadgets.net/download/notebook/toshiba/satellite-c675-s7200
Oct 17, 2012 | Toshiba Satellite C675-S7200 Intel B940...
Toshiba Satellite Pro L300 Notebook Logo
149 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
