Question about Home
Hot tub jet wont stay put
My hot tub main jet, supposedly adjustable wont stay where I want it, centered and keeps returning to it's direction of least resistance, off to one side of the tub.... of course i always run it full blast like a fire-hose.
  • umright Feb 12, 2014
    I was able to use plastic wine bottle corks to hold it centered... I've used these to solve numerous problems, but this is my favorite.
    Master:
  • 574 Answers
The jets should have a nut on the back to tighten .
Posted on Jun 14, 2014
4 Suggested Answers
  • 62 Answers
SOURCE: Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Posted on Jul 11, 2009
picker5strin
  • 28 Answers
SOURCE: housing for jet is broken on spurlin tub
You can probably get one at your local pool and spa supply. If you do not have an acess door or access panells to that side of the tub, then you may have to take the tub out of its frame. You will first have to TURN OFF ANY POWER SUPPLY to the pump and any other device such as an optional heater etc. Then turn the water supply valves off and disconnect them where they exit the valve.Disconnect the drain by unscrewing the inner drain strainer where the water runs out of the tub and the screws from the trip lever (that works the stopper) and pull it completely out. Remove any caulking around the tubs rim and lift the tub from its frame. Make repairs and replace in this same order.
Posted on Jun 12, 2012
itcinc1
  • 9 Answers
SOURCE: hot tub wont stay hot
Contact Maryland Hot Tub Repair - Pool and Spa Service and set up a Diagnostic service call. Here is there contact info: Maryland Hot Tub Repair - Maryland Pool Service - Maryland Spa Repair Pool Parts - Spa Parts - Hot Tub , Pool and Spa Repair - Pool Opening - Pool Closing - Pool Service 410-304-2463 http://www.maryland-hottub-pool-spa-repa... or see them on http://marylandhottubrepair.blogspot.com...
Posted on Sep 12, 2012
My hot tub has an issue. Only half the display is working, there's no heat and the jets wont turn on. If I trip the curcit, I can get the hot tub jets for 10-30 seconds and that's it. HELp
Almost all hot tubs use 230 volt AC power which comes from the power company in two power wires plus one common common wire. You get common 115 volts between a common and either other wire. "Half way" working could well be an attempt to run on only one of the wires. There is also likely to be a ground fault circuit breaker in the wiring which makes sure current going out to the tub is all returned via the wires and not through someone's legs to ground. If you're comfortable with an AC voltmeter check some voltages but understand that 230 volts is way into the killing range. Two people present and well insulated probes are important.
Apr 15, 2016 | Pool & Spa
Why wont hot tub heat with jets on losing temperature on 110 volt
My first question would be about the outside temperature. What is the outside temperature?
Hot tubs that are designed to operate on 115v only have 1.5kw heaters and if the outside temperature is below 50 deg F they tend to not keep up to 103 deg water while being used. They are also designed to not heat while the high speed pump is operating.
Does it stay up to temperature on a normal basis?
ROD
US Parts Center
Jun 08, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
Purge line
The breaker the manual is referring to will be the main circuit breaker at the panel.
If the system is not running the purge cycle as it is supposed to and turning the power on and off does not reset the control box then it is likely that the control box has a bad part in the circuity and should be replaced.
Rod
US Parts Center
Apr 13, 2014 | Maax Home
Seat wont stay upright, now keeps reclining
Hi Sam,
We would recommend you contact Silver Cross directly for assistance
Feb 06, 2014 | Silver Cross POP Jet Umbrella Stroller
Can I simply silicone jets in a tub to seal them completely, so the jets don't leak? It's for a rental unit I own, bathroom on 2nd floor. Don't want to tear out the bath tub or ceiling on Main floor.
In order to properly seal the jet in place with silicone you must remove the wall fitting from the inside of the tub. The wall fitting is threaded into the jet body from the inside of the tub.
Once the wall fitting has been removed you can put a small bead of silicone around the underside of the flange and thread it back into the jet body. Clean up the excess silicone after it squishes out with DeNatured Alcohol.
If you plan on just putting a bead of silicone around the outside edge of the jet body behind the tub, do not waste the silicone or your time as it will not solve the leak in the tub.
US Parts Center
Sep 12, 2013 | Jacuzzi - Bathtub - Alcove - Navona -...
How to clean mold from jets on Kohler Spa tub
Mold on your jets can come from a variety of places but due mostly to the bacteria in the tub.
There are several kinds of cleaners to use in the meantime once you get your trim clean so you can prevent what you are experiencing.
Take the trim off and clean them in your sink. DO NOT put them in the dishwasher as it is too hot and will ruin your trim.
Here is a link to our site that has different options for cleaning the pipes and keeping the jets from getting yucky.
Maintenance Products
Rod
US Parts Center
888-521-6183
Jan 08, 2013 | Kohler Home
I have an american standard jet tub, but i lost
You can adjust the jets by moving the center of the jet around, if the center does not move, it is not adjustable, some jets have a pressure adjustment by twisting the center of the jet left to right. No manual necessary for this.
Mar 13, 2010 | Home
Froze the jacuzzi.
You'll need to start electrical troubleshooting from a point where you have power and then keep testing further into the unit to find out where the power stops. Is there a local 'ground fault' reset button inside the hot tub control area (under the tub?)
Jul 11, 2009 | Home
Hot tub will not stay warm
You must keep your circulator pump running if you want the water to stay hot. The water is being heated inside the pipes but it isn't getting circulated until you turn on the jets pump.
Jan 14, 2009 | Heating & Cooling
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
