Question about Coleman 2 Burner Propane Stove 5430E700
How to start gas stove
Need instructons on stove operation
How do I turn my oven on? I have never had a gas stove, but I cant get the stove to start except if I turn right to grill in other words I can get it to ignite for 180 degrees etc only grill
normal operation is to push the oven knob in and turn
pushing in sets the igniter off and turning opens the gas flow to ignite
always light an oven with the oven door open
stop s an explosion if there is a problem
down load an operators manual bu going google and typing in --- user manual for ( make and model ) gas stove --- find a pdf version and download it
Aug 13, 2016 | Ovens
How to regulate flame on a gas oven stove
On a gas stove, you simply choose the desired temperature. If the stove is operating normally, it will automatically adjust the flame.
Aug 05, 2014 | Amana ACS3350AS Gas Kitchen Range
What is a liquid gas stove?
A liquid gas stove is a type of stove that uses a fuel tank in order to operate. Liquid gas stoves are capable of burning different types of fuels like alcohol, white gas, automobile gas, and kerosene.
Oct 25, 2012 | Camping, Backpacking & Hiking
My stoves 500sldm needs a manual. Gas does not shut off when i close the safety lid
the Knobs need to be replaced as there is a tag which operates the shut off. These often get brittle and break off. You can buy the whole set from Espares, very easy to fit.
Oct 02, 2011 | Stoves 500SIDL Gas Kitchen Range
Stoves precision 1100 operators manual
I need to change the bulb in the fan part of my Precision 1100 Stoves oven but I have lost the manual. How do I get access to change the bulb?
Sep 15, 2009 | Stoves 1000DFDLm Gas Kitchen Range
Kenmore gas stove Gas leak
I had this problem with my stove and had the regulator changed coming off the PROPANE tank.
Apr 04, 2017 | Kenmore Kitchen Ranges
My new gas stove (propane) is releasing black soothe when lit. All the pots are covered in this black powdery like substance. Whats the problem and how can i fix it. It's really costing me a lot to clean .
All gas stoves are set up for natural gas. Before using on propane, the oven and burners need to be converted for propane operation. Refer to the installation manual for conversion requirements for your particular stove.
Dec 25, 2008 | Kitchen Ranges
Smelling gas at when stove is in prelight then going away
Welcome tkrogers,
You said,smelling gas at when stove is in Pre-light then going away.
In some stoves this is normal as long as it is a slight smell and it goes away when the stove or oven ignites.
You know gas really has no smell, but this smell is added for our safety!!
What is the Make,year ,and Model number of your range?
The gas must start somewhere until the flame ignites it.
So we smell a slight smell of gas until it burns.
Thanks,
Huuum
Please remember to lave a solved rating before you leave.
Oct 11, 2008 | Frigidaire Kitchen Ranges
Gas stove top burners
Make sure nothing is blocking burner tubes and burner tops. All holes need to be free and clear. If that dont work replace your inlet valve were your gas lin goes in.
Nov 26, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Coleman 2 Burner Propane Stove 5430E700 Logo
14 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
