Question about Franklin Industries FBC360D Beverage Cooler
Fan on wine cooler is squealing very loudly - Franklin Industries FBC360D Beverage Cooler
My Danby has become loud and it sounds like maybe an issue with the fan. What should I do?
might be that the fan blades strike the casing. switch of your cooler. pull the plug out to prevent el-schock. turn fan blades manually and observe....
Mar 03, 2011 | Danby DWC283BLS Wine Cooler
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
Haier wine cooler produces intermittent loud "motor" noises.
Turn the unit around so you can hear the compressor (large black small basketball size unit lower left) if the sound is coming from that then it is probably lost lubrication or just failing. "These usually last forever but.... they do fail. I am not sure if this one (loke mine) has a samll fan. Clarify the noise for use and we can tell you what it is. a constant tapp tap tap fast paced is the compressor going out or out of lub etc. . A ting ting ting may be a fan... Robert-Aptos
Apr 28, 2009 | Haier BC112G Wine Cooler
Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 15, 2008 | Danby DWC283BLS Wine Cooler
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Franklin Industries FBC360D Beverage Cooler Logo
23 people viewed this question
Top Franklin Industries Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Franklin Industries Refrigerator Expert? Answer questions, earn points and help others
