Question about Hotpoint TDC32 Electric Dryer
No water to pull out condenser tray
No water going to pull out water tray
  • pauhughes
    pauhughes Feb 13, 2014
    condenser box clean
  • 108 Answers
Hi is condensor box clean thats the aluminium one with about with plates if clogged up this will cause that problem
Posted on Feb 13, 2014
Testimonial: "it is the aluminium one but is not blocked or damaged. the problem is that the water is not going into the pull out tray you empty at the bottom and there is no water on the floor"
  • 1 more comment
  • wallycarl86774
    wallycarl86774 Feb 13, 2014
    hi i take it clothes stay wet if condensor is clear ur dryer as a blockage
  • wallycarl86774
    take box out if lucky you might see some some fluff causing it at the back if not u will have to strip it down
  • pauhughes
    condenser box is clean. the problem is there is no water collecting in water tray!!!
Where should the drip trays be? Condensation dripping into fan housing.
I've seen systems that pull air through the condenser coil into the "squirrel cage" fan and use the heat from the condenser coil to evaporate the water dripped into the fan housing. They're designed to operate that way...
Nov 06, 2015 | Heating & Cooling
Does a bosch fridge freezer always have water in the evaporation tray?
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
It is normal to have water in your evaporator drain pan.
Your refrigerator goes through a defrost cycle every 8-10 hours, where your refrigerator will shut down for about 20 minutes and your defrost heater turns on.
You do not need to clean your drain pan. You have a condenser fan that blows across the drain pan to evaporate the condensate.
You drain pan will fill during the defrost cycles. the condenser fan blow across the drain pan and will evaporate the water.
The amount of water in your drain pan will depend on conditions such as high frost in the freezer.
Mary, you had just happened up the drain pan not completely evaporating the condensate.
Sounds to me like you are in good shape.
Peter, Baltimore, MD, USA
Nov 02, 2014 | Bosch KAN60A45G Inox 510 l Fridge Freezer...
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
My frigidaire air conditioner is spitting water out the side and the drain hole is clear is there a secondary drain hole?
The tray that holds the condensed water from the evaporator
may be clogged, it may be clogged before the cleanout hole,
where the tray joins the pvc, if this is the case you may have to
power down your ac unit, there is a panel on your heater unit
that you will have to access to expose the evaporator coils and
you will see the tray where the condensation builds up and flows
thru a pvc pipe to go outside. also make sure that the pipe going
outside is at a slope so that the condensation can flow and not
clog the pipe. make sure that water can flow from the tray thru
the cleanout hole. once you correct the problem. you need to reseal all the seams with duct tape or metalic tape, you can purchase at most hardware stores, to make sure their are no ac
cool air leaks other than thru your ac vents. good luck!
Jul 30, 2011 | Frigidaire Heating & Cooling
Water building up in colling coil tray fan throwing water in side house
When the condensation flow in the tray that connects to the pipe going outside,
gets clogged up, it will overfill and start leaking inside because it has nowhere
to go. you need to make sure that the condensed water can flow easily outside.
good luck!
Jul 30, 2011 | Heating & Cooling
Condensation is forming on the glass door and dripping onto floor boards. How do we stop the condensation. It does say to empty drain tray but we cannot find it and instruction manual does not tell you...
The drain tray is under the fridge often times set back a little bit. Remove the kick plate by pulling from one side then the other side, strait forward till it pops off. The kick plate is a plate as close to the floor as you can get on the front side of the fridge going the entire width of the bottom of the fridge. Now get eye level with the underneath of the fridge. Center your view on the underneath of the fridge. The drain tray is right there. Pull it out, carefully as it is probably full of water, and dump the water out of it. Replace the drain tray and then replace the kick plate. Check the drain pan once a week or so and you should have no more water leaking on your floor. Hope this helps.
Mar 22, 2011 | Refrigerators
Lg split type leaking water from bottom seams
There is a drain tray under the fins in the wall unit which collects condensed water and and drain it out through a outlet. Sometime the tray gets clogged wit the dust and thus water instead of going towards outlet gets accumulated at one place and spill over. You can remove the front cover and see this water out let and the tray. Clean it and ensure that it is connected to outlet properly. Also check your water out let pipe which throws the water out is not clogged with the muck/dirt as this the most common cause for water leakage in the machine. The condensed water has no get away,
Aug 26, 2010 | LG Heating & Cooling
Water/condensation in both dairy tray and bottom of fridge
My guess is you have a blocked defrost drain. The water instead of going down its drain goes down the backside of the frig and pools up under the crispers. Blow out the defrost drain. The only other thing to look for is bad door gaskets.
Dec 16, 2008 | Refrigerators
Amana refrigerator 20 condensation water in fridge
moisture in the freezer is condensed at the back in a tray that has a drain with a tube that drains to a tray at the bottom of the unit. In our case the drain was clogged and water froze in it. We removed the back panel and pulled out the tube from the drain spout. We then used a hair dryer to defrost the ice clog and a wire to route out the drain and the tube. This worked and we replaced the tube and sealed it with tape. It now drains properly into the tray.
Sep 13, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
Hotpoint TDC32 Electric Dryer Logo
75 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
