Ipad mini 1432 jumped the backlight fillter now screen blank
Hi' im new to this forum' and so glad i found this place, my problem is i purchased a ipad mini 1432 off of ebay for my wife' that was damaged that needed to be put back together with new parts. i had to purchase new digitizer new ic complete and new screen as well as battery. everything was working and lighting up without the digitizer conected' so all i had to do was solder in new ic and digitizer and put back together. the thing is where i had the ipad was on my workshop table' and this was working but the charge was not that good hence the new battery. our disabled daughter came into my workshop and moved it' not knowing it was connected up, thus when i came home it was not working, and i did not know why' untill my wife told me, you could hear it connect to itunes but nothing on screen. so from reading on this excellent site' i jumped the fuse' with very carefull soldering' and a antex very tiny tip. now to get to my point' sorry the backlight comes on pressing the top button' but the screen still stays black' i can here a voice that says no siri connect to itunes' . my background is tv and video repair so ANY HELP ON THIS PLEASE// i would be very greatfull indeed. FANTASTIC SITE rgds brian
4 Suggested Answers
  • 196 Answers
SOURCE: gateway fpd2185w capacitor fix question
to take solder off you can get some cross wire called DESOLDER this copper wire soaks up the old solder, by heating this new desolder the old solder will jump into it and clear your way. I like the Techspray #3 no-clean model 1822-5f
and its made in the USA!
Posted on Jan 24, 2009
SOURCE: 19'' Dynex TV does not come up as a Computer Monitor.
Follow these steps on the remote :
Press Input,
scroll down and select VGA.
Posted on Jan 03, 2010
  • 505 Answers
SOURCE: I purchased my Vizio VP322 HDTV10A just about 1.5
its bad capacitors on the power board
if you can solder, you can fix it.
look for caps that are bulged up, theyre supposed to be flat on the top. google bulged caps and youll see pictures
replace with same value parts to solve, all are solder in
Posted on May 21, 2010
Testimonial: "Hi, I forwarded your response to my big brother to see if this is something he can do. I will let you know his response. In the meantime, do you have suggestions where I can get the needed capacitors? Thank you so much for such a quick reply! I really appreciate it. :o)"
How to replace I pad 2 broken screen
Is the screen broken or is it just the digitiser? There are many excellent videos available which take you through the process of replacing all parts of your iPad.
However, it is not something that can be fixed easily and you need to exercise great patience in dismantling your broken iPad and replacing the damaged parts.
Make sure you have plenty of space in which to work and place all the parts of the iPad around your working area so they are easy to reach.
Good Luck.
Mar 01, 2015 | Apple iPad 2
Dropped my iPad screen now jumping how do I fix it
There are many places to get it fixed. The most expensive will be the Apple Store. You can search Yelp or other rated service sites to find the best and/or cheapest place to repair a screen in your area. It is a delicate repair, and even experienced places can get it wrong.
Feb 14, 2015 | Apple iPad Mini
Mini ipad screen is jumping and zooming in and out
Time to visit the folks at the Apple store.
Jun 02, 2014 | Apple iPad Mini
Cracked screen
Usually it's just the "Digitizer" that needs to get replaced. If you can read everything on the screen (no LARGE areas of just black) then the LCD panel is still OK.
Jan 07, 2014 | Apple iPad Mini
Ipad mini jumps from screen to screen
Did trigger the screen features some how???? Check the settings and disable the multi touch gestures
Nov 06, 2013 | Apple iPad Mini
Disabled ipad 3
What wrong with your iPad 3? Maybe you can reply on the tablet replacement repair parts for iPad 3 to make your iPad return back new and health. Nowdays, there are more repair parts for fixing the unflexible and scracked.
Oct 04, 2013 | Apple iPad 64 GB WiFi
Iv got a disco 1.And when im towing and need more power, it wont rev above 4000 revs. checeked all the hoses, cleaned the intercooler, replaced fuel/oil fillter, give it oil change.Its got a KnN air...
Are you getting a lot of black smoke?
If so your egr is more than likely goosed.
Easy fix in a 300.
Mine suffered from this a few years ago and I blanked off the egr. You can make a blank yourself or buy one with instructions for a few quid of eBay.
Well worth it and you will certainly notice the difference.
hope this helps.
Oct 11, 2009 | 1995 Land Rover Discovery
My acer 4520's screen is blank when i'm turning it on.
There are approx 4 reasons why this might happen:
  1. The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  2. The panel has died - Need a new panel
  3. A cable has worked itself loose or is broken
  4. The inverter has gone - Need new inverter
  5. Long shot, the bios has got corrupted - Engineer could re-flash the bios
  6. Long shot, Mainboard onboard graphics has gone - Need new mainboard
My personal opinion is that the backlight or inverter has gone - Either way it needs to be opened up to repair it, consult a service centre and get a quote or repair it yourself if your up for it.
Sep 05, 2009 | Acer Aspire 4520-5582 Notebook
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
