Question about Hotpoint TDC32 Electric Dryer
Water not collecting in condenser - Hotpoint TDC32 Electric Dryer
    New Friend:
  • 108 Answers
Are aluminium plates clear of soggy fluff look at back see if you can see any fuff were tank connects if no look its blockage inside try cleaning filter duct
Posted on Feb 14, 2014
Toto air conditioner
I'm not sure if this unit has a condensate pump. If it's located below grade and drains to the outside it likely should have one. The condensate pump may be bad or the pressure switch that activates the pump is bad. The pressure switch measures the amount of water in the condensate collection tank. It serves the same purpose as the float in a toilet. Also, check the condensate hose at the inlet of the pump. It could be a bad pump, a leak in the the collection tank, or a clogged hose.
Aug 23, 2014 | Heating & Cooling
Trane xr90 leaking water from behind inducer
You have a condensing furnace, clean out the condensate drain line.
Nov 30, 2013 | Aprilaire Heating & Cooling
Kenmore dehumidifier compressor on but doesn't collect water
clean the condenser in the front or the filter if it has one. no air flow to cool it down will result in overheating and no condensation collection across the evaporator coil.
May 09, 2012 | Kenmore Dehumidifiers
Need to know if I can connect a drain hose/tube to my air conditioner model # FAX054-P7A1. I'm having a problem with water collecting in the window sill/track
Hello, the first thing is make sure the AC is tilted a bit in the window, if it is level the water will collect toward the front of the unit and drip inside. Second if there is a drain hole on tne unit then you can connect a hose to it and let it drain. However if there is no drain hole then the unit uses tne fan blade to splash the water on the condenser and since the condenser is warm/hot it will condense the water.
Jun 08, 2011 | Frigidaire FAX054P7A Wall/Window Air...
Collected water in evaporator pan does not
you obviously live in a high humidity area.(or you are putting warm/uncovered food inside) but the answer is yes,or you could collect the water to use on you indoor plants.........better than tap water...
Jul 08, 2010 | Frigidaire FRT18KB2CW Top Freezer...
Model 363.9668513 water collects under the fruit
this is because the plastic is shiny and attracts condensation,only "cure "is a piece of kitchen towel under drawer to mop up as/when.(when you open door all the cold air drops to the floor and is replaced with warm moist air from the kitchen.hence condensation.
Apr 13, 2010 | Refrigerators
CONDENSATE LOOP
Hi, A condensate loop in a refrigerator is any device that produce heat in certain areas, most commom is around refrigerator door, which are mullion heaters that produce mild heat, to prevent ice build up around doors, prevent door gasket from getting stuck, another type of condensate loop are found under or back of most refrigerator, hot gas line from compressor, sometimes are loop under ref. or other location of ref. before it is connect to ref. condenser, most ref. condensate loop are used to evaporate water collected from evaporator. to prevent clouding of glass on doors, etc, and it could be electrical, or mechanical, base on applications.
Aug 06, 2009 | Federal Industries CGR5042DZ Commercial...
Water running from under fridge. all water lines off
Condensate pan is gunked up and no where for condensate to collect. Clean the pan on top of the compressor and make sure there is no gunk or dirt collected there.
Jun 02, 2009 | Whirlpool ED5VHGXM Side by Side...
Unit Runs (fan and condenser) but no water?
can you feel the coils? if they aren't cold, then there might be a problem with the coolant circulating. if the coils are cold, then you should have condensation on them.
Nov 21, 2008 | Toshiba Satellite A135-S4527 Notebook
By condenser I assume you mean the compressor is running. Is there ice forming on the front coil?
Jan 08, 2008 | Comfort-Aire BHD-651 Dehumidifier
Hotpoint TDC32 Electric Dryer Logo
47 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
