Question about Car Audio & Video
How many watts can it handle or how many watts does it put out
What does 50wx4 mean? i am trying to find speakers for the rear deck and don't know what wattage the radio puts out
There are four outputs rated at 50 watts each. You will need speakers rated at 50 watts or more to handle maximum output without distortion.
Dec 12, 2016 | Cars & Trucks
Capabilities of the Robin 2400is generator
no
ac units are 2000 watts minimum, washing machines are 1500 watts minimum, microwave is what is on the plate and start at 650 watts but most are 2000 watts
the 2400 is the peak out put for start up of fridge , washer etc and the running wattage will be 2000 watts or less ( duty cycle )
to run more than one of the nominated items at once you will be needing a 5500 to-6500 watts unit
they handle a start up surge of 6500 watts ( larger one) and will comfortably handle 5500 watts run full load
it works like this , the plate on the gen set is the surge short time load capacity of the genset and not the duty load which is 500 to 750 watts less than that plate wattage
for example your 2400 is is surge rated at 2400 watts but duty load is less than the 2000 watts
many people make the mistake of buying a gen set that looks big enough but do not calculate the maximum load capable on being put on the gen set
fully loaded uses more fuel /hr
wears out faster
has power surges as the extra load cuts in and the motor struggles to get back to required rpms for voltage and cycles
will not cover extras like lights ,
a much large gen set will take it all in it's stride , no power surges, better economy, less stress
talk with an electrician , do your maths on everything you wish to run and that which you forgot about then add 1000 watts to the duty cycle and that will be close to the gen set you require
Oct 17, 2016 | Electrical Supplies
I have a100 amp alternator and putting 4-130 watt off road lights and the vehicle on it 98 Chevy blazer
Do the maths and talk to an accredited auto electrician but I am sure that the alternator will be too small for what you want to do
the formula is I(amps)= P(watts) divided by volts
4 lights at 130 watts each =520 watts divided by 12 volts =43.3
amps extra for the alternator to handle. AS most alternators currently run at 90% capacity with normal vehicle operations you will need a bigger alternator. I would consider using a band of LED lights as they have more light than the 130 watts will provide and use just a few amps thereby not requiring a new alternator. Do your home work .the price of a new alternator and wiring ,relays etc against the LED lights. More light , lighter bracketry and no relays.
Dec 20, 2014 | Cars & Trucks
Hello again. Sorry to say my knowledge is lil... I want to replace stock deck. Here is the stuff i want to put in it. Could you take a look and give an opinion if maybe i cant get away without putting a...
ok as for the deck just get the wiring harness for your car so you dont have to cut the old one out and that would eliminate the need for a wireing diagram with that done you should be able to hook all speakers you want to the stock spot so for a tweeter just hook it up with the door speaker there arnt any extra cords....you will only need a amp for a subwoofer unless you choose to put your mids and highs on one and if you didnt want to change your deck hook up the tweeters would be the same way hope this helped
Mar 30, 2010 | Car Audio & Video
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
I replaced my mini component stereo (360 watt) speakers with new speakers that apparently can handle up to 600 watts. If the volume is too high on the receiver, the power cuts out. I think this is because...
probably you are right due to high impedance of the speaker the receiver cant handle it, the mini component can handle 80 to 100 watts only. you need a high watts amplifier to used your 360 watts speaker, just connect it to the audio output of the mini component. thanks
Aug 30, 2009 | Sharp CD-E99 CD Shelf System
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
Same exact problem
Hello phatjay_31,
It's likely that the sub has been damaged by too much power. The Type R's in both 10" and 12" versions can only handle up to 500 watts RMS. The 15" version can handle up to 750 watts. The Rockford-Fosgate T3000bd1 amp puts out 3000 watts RMS into a 1 ohm load.
I'd check the voice coils. They are probably melted.
Hope this helps.
Jul 19, 2009 | Alpine SWR-1222D 12" Type-R Series...
Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Jun 03, 2009 | Infinity Reference 1211a Car Audio...
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
