Question about Sharpe 16111 - Air Cap for Model 775 Non-HVLP Spray Gun
Why is the paint gun pulsing - Sharpe 16111 - Air Cap for Model 775 Non-HVLP Spray Gun
  • 50 Answers
It could be that air is leaking in through the gland around the needle. You could try putting a drop of oil on the needle where it enters the front part of the body, and tightening the packing nut just a touch
Posted on Aug 13, 2014
Paint gun splatters paint on car
The needle valve in the spray head needs to be cleaned or replaced.
Nov 21, 2013 | Binks Paint Spray Gun Repair/rebuild Kit...
Spray is pulsing
this is usually caused by:
1. water in pressure tank of the compressor - clean the compressor holding tank
2. faulty valve in direct drive compressor (rare!)
3. dirty needle/gasket in the piece.
4. insufficient air flow
regarding 1:
stop the compressor,
open drain on separator and let all liquid out
allow pressure to drop to atmospheric
open drain valve on the tank and drain the content
on the compressor body find oil drain and drain oil
fill with new oil according to instruction on your compressor
close drain valve on the tank and separator
start compressor and check if problem is solved
re 2:
return valve is too difficult to change without specific model knowledge
re 3:
fill 1/3 (pint/500ml or less container)gun container with paint stripper and spray it directly to the sink or other container on full blast - WEAR SAFETY MASK, GOGGLES AND GLOVES! STRIPPER WILL BURN YOUR SKIN!
fill same level with water or solvent and run again, this operation should remove most of residual paints in nozzles and pipes.
check now nozzle for cleanliness and needle assembly, clean what necessary, use bit of vaseline when you will put it back together.
check for consistency of spray on piece of butcher paper with your usual paint. if problem solved - you are fine!
re4;
increase air flow... this actually should be done first.
for better instruction - please provide with model of the gun and paint used.
your comment and rating will be appreciated.
Oct 15, 2013 | Air Tools & Compressors
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
Spray is pulsing
You most likely have a leak at the seal for the neddle try tightening the nut at the trigger if that dosn't work take it apart and check the seal replace if required .This should stop the surgeing at the tip
Apr 25, 2011 | Binks Paint Spray Gun Repair/rebuild Kit...
Pulsing
What kind of system are running the gun off conventional airless or air asstied airless
Dec 24, 2010 | Binks Paint Spray Gun Repair/rebuild Kit...
Why does my gun keep spitting
Spitting is usually caused by not filtering the paint through a strainer (made for the purpose by the paint manufacturer). The paint debris blocks the paint for just a moment, then spits it out. Easy fix!
Jun 09, 2010 | Wagner GX10 Airless Spray Gun
Problem spray painting water based paint
I spoke to a friend who was a spraypainter in his last job, apparently due to the thickness of the paint, I needed a larger nozzle on the gun. I couldnt get a nozzle to suit this gun so I purchased another gun with a cuple of different size nozzles. All seems to be working fine now.
Nov 19, 2008 | Air Tools & Compressors
Sharpe 16111 - Air Cap for Model 775 Non-HVLP Spray Gun Logo
115 people viewed this question
Top Sharpe Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Sharpe Tool and Hardware - Other Expert? Answer questions, earn points and help others
