Question about Toshiba e-Studio 232 Black and White Copier
Black line appears vertically on both copy paper and scan randomly
After several copies, a verticle black line will appear on the copy or the scanned copy. It does not do it all the time. Technician cleaned laser unit and optics, but it still happens.
disastertech
  • 62 Answers
SOURCE: FAULT WITH MY DP2570 PHOTOCOPY MACHINE
This means the corona wire is broken and only be repiared by the service tech
Posted on May 13, 2008
  • 58 Answers
SOURCE: black streaks appearing on copies
Well there is not to many things thst would cause that problem,try cleaning the corona wires ,all the mirrors,and check the upper fuser roller.
Posted on Dec 04, 2008
  • 990 Answers
SOURCE: random C21 in Toshiba 2060
Dear sir; the toshiba copier they store the desciption in the memory therefor you just press "8" and "clear/stop" key simultaneously, It might be resetable, just turn machine off and back on. if you need more help please let me know,
HAVE A HAPPY HOLIDAY!!!
Posted on Dec 17, 2008
  • 643 Answers
SOURCE: Toshiba 2860-changed Toner cartridge-black line on edge of copy
If drum no problem, then probably need to align the drawer alignment.
Posted on May 28, 2009
FixinFax
  • 3085 Answers
SOURCE: Dark black going down the center of the paper. I
Replace the DRUM UNIT
Posted on Mar 05, 2010
Black vertical lines come and go for scans to computer and copies
I suspect the Document Feeder is not aligned properly and light is leaking in. You will need to have a technician in to check the alignment of the scanner to see if it needs to be readjusted. random black lines on edges usually indicate light leaking into the scan area.
Aug 28, 2017 | Xerox WorkCentre 3220
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Black vertical lines when scanning on canon mx420
the ocr sensor in the ADF needs to be replaced, I would recommend replacing the whole ADF as a whole.
Aug 10, 2012 | Office Equipment & Supplies
Very crisp vertical grey line appears (glass clean)
I have the exact same problem. It was there since I first bought the MFC-7840W.
Vertical line appears in scans using the automatic document feeder (ADF).
Vertical line does not appear when scanning single page (placing it directly on the glass -- i.e. not using the ADF).
Cleaning the glass strip for the ADF (or the white pressure bar overhead) does not solve the problem.
The problem does not occur with copies using the ADF (using the COPY button which is basically a scan and print). This would suggest that dust and dirt is not to blame because that would also appear on the copies.
But since I believe a copy is basically a scan plus print, they should be using the same electronics -- a hardware problem on the scan would likely appear on a copy also -- there is some difference between how they accomplish this.
It's definitely not a software issue since it occurs on all versions of Windows and Mac OS X (and multiple computers). It also does not matter whether I "push" the scan to the computer by using the scan button on the MFC... or "pull" the scan from the MFC using the Brother Control Center software.
Aug 12, 2009 | Office Equipment & Supplies
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Jun 01, 2009 | Brother MFC-7820N All-In-One Laser Printer
Vertical black line when copy with Koda ESP 3
Some dust particle or something might have been stuck on the scanner. Try cleaning the scanning glass
May 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Black line appears on copies fed through automatic top loader
Clean the scan glass, there is lilely a spot or streak on the glass, use a good glass cleaner and soft cloth or paper towel.
Hope this is of some help.
Ed
Apr 21, 2009 | Konica Minolta DiALTA Di200 Copier
Two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Sep 01, 2008 | Lexmark X4270 All-in-One Multifunction...
Thick verticle line on copies and scans
Sounds like the issue is with the scanner bulb. May not be moving across or warming up to full capacity.
Make sure the scanner is plugged in directly to the wall and not into a surge protector or a power strip. If problem is still there and you are in warranty you will need to replace the unit. If OOW then you should call and see if you can repair or upgrade the unit at a discounted price. If you want to speak to someone in English tell them you want mac support - they are in Canada.
Jun 01, 2008 | HP OfficeJet 6310 All-in-One Printer...
Toshiba e-Studio 232 Black and White Copier Logo
37 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
