Question about Maytag Neptune Washer
Nd error code, won't spin
Model MAH6700AWW, S/N 14027969JT
4 Suggested Answers
  • 298 Answers
SOURCE: Washer will not spin; displays nd error
(nd) stands for no drain check the pump,and drain hose
for clogs
Posted on Dec 24, 2007
  • 219 Answers
SOURCE: washer will not drain or run. It gives a code nd
pull back off washer and check your waterpump
Posted on Apr 17, 2009
SOURCE: We replaced pump on our Maytag neptune MAh6700AWW but we still got a nd code and it din't go into spin cycle?
cdmcdm5, did you ever figure out the solution to this problem? I currently have same issue. Have checked for obstructions multiple times and also ended up replacing pump. Still have same ND (no drain) code issue.
Posted on Nov 19, 2012
Code nd
Don't know if this is your problem but sometimes ours will appear to drain, but there is still a lot of suds that remains and trips the nd (no drain) indicator/lockout. We had to pour water in from a bucket to beat down the suds, then repeat several times to get all the suds out. First time I took off the back of the washer, disconnected the pump, then let the suds out. To much work.
Nov 11, 2013 | Maytag MAH6700AWW Neptune Front-Load...
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Jul 10, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked. The nd error code indicates "no drain". If the unit can't drain it won't spin. You're going to have to slide the washer out far enough to remove the rear panel; be careful not to damage the floor. Once you get the rear panel off you will see the pump. Be sure to have plenty of towels & a small container to catch water. I am sending you instructions from the service manual to remove and replace the pump. Another possibility is the drain line is blocked or something is stuck in the tub to pump hose.
Nov 05, 2011 | Amana Washing Machines
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Error code nD, won't go into spin cycle
Is the Machine a FAV6800A or a FAV9800A?
Do you want to DIY the fix?
The nd error code = No Drain error code.
You could have drain line clog, an issue with the drain pump or a stuck pressure switch. Do you hear the machines drain pump turn on and pump out water before entering lnto the spin cycle? Is there water left in the tub with the nd error code? If you can provide feedback on the questions above I will help guide through the troubleshooting steps.
You will need the Service Manual to troubleshoot.
The FAV6800AW/FAV9800AW Service Manual for reference. Sears Parts Direct for reference.
Rich
Dec 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My washer displays a ND Error Code. Will not finish a wash cycle
just have the same thing now! cal maytag! we did the parts have had a recall on them they are repairing ours as sonn as we get the parts they ordered! the truth is the stuff is just junk!
Jun 26, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
13 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
