Question about 05 06 Silverado 2500HD 3500/ 06 1500/ 07 Classic Billet Grille Grill 6pc Combo 186858
Running lights not working - 05 06 Silverado 2500HD 3500/ 06 1500/ 07 Classic Billet Grille Grill 6pc Combo 186858
    Sergeant:
    Champion:
  • 242 Answers
Running lights only work when you have it in drive
Posted on Oct 10, 2014
I have brake lights but no running lights
You might want to che k the headlamp switch it controls the running lights and also the headlights i had same problem headlights work but no running lights
Mar 13, 2016 | Cars & Trucks
96 Dodge Durango all lights work running lights do not work it has a bad dimer switchcould that make the running lights stop working
running lights are not controlled by the dash dimmer switch. the problem will be either in the light switch ( first position is running lights) wires to the switch or fuses
Dec 27, 2014 | Dodge Cars & Trucks
I'm having brake light problems on my 1996 k 1500 pickup. My all my bulbs are working , but when I turn on running lights it causes my brake lights to go out and makes my signal lights to flash faste
this sounds like an earth problem , but with the faster flashing turnlights it could be the flasher relay , have you had any work done on the vehicle recently that may have dislodged something ?
Nov 05, 2014 | Cars & Trucks
Signial lights, daylight running lights dont work ocasionilly
short in wires or breaker going bad or just loose or bare wires...maybe shorts out when raining ?
Jul 22, 2014 | 1999 Dodge Caravan
Dash lights and running lights arent working?!?
Check your fuses, after replacing fuse make sure you reset.
Apr 10, 2017 | 1997 Chevrolet S-10 Pickup
Running light not working
1. check fuses for running lights
2. check for broken, corroded, damaged wires for running lights (sometimes brown colored wires).
3. If all lights work except headlight, check the starter switch contacts on the handlebar button
Jul 23, 2012 | 2009 Yamaha V Star 250
05 colorado, running lights in front work when swicth is on auto...no running lights in back, brake lights work and bulbs are brand new...the insturment cluster lights also are not working, once in a blue...
In the AUTO mode, the lights should only work when its dark. in the day light, the only lights that work are the DRL (daytime running lights) (Headlights) All the lights should work when turned on MANUAL, EVERYTIME. You may have a bad connection, but it needs to be checked on MANUAL when the problem is present.
Nov 15, 2010 | 2005 Chevrolet Colorado
Right side of trailer running lights does not work
Usually one of the holes in the marker light where screw goes in, has metal contact where screw meets light, but if not, and they are not push in wire connection type from behind, then just run your white wire up through hole in housing, and bare the end & tighten it up under screw holding light to body. White should be ground, brown should be power.
Jul 02, 2009 | 2004 Dodge Ram 2500
Rear running lights on 99 cherokke
It sounds like a bad connector (corroded, damaged) near the taillights. Take all of them loose and inspect. Clean dirty ones, replace unrepairable damaged connectors.
Apr 28, 2009 | 1996 Jeep Cherokee Country
05 06 Silverado 2500HD 3500/ 06 1500/ 07 Classic Billet Grille Grill 6pc Combo 186858 Logo
59 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
