Question about Toshiba SD-2800 DVD Player
Toshiba 2800 constant loading, but doesnt read disc
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
Doesnt read disc
Check the discs and make sure there are no scratches on the readable side. This might be stopping it from reading them the first time.
Jan 26, 2010 | Microsoft Xbox 360 Elite Console
Disc not reading. toshiba dr420 dvd recorder.
Multiple problems with the DVD recorder one of them could be the lasers not reading correctly its software is messed up or there something wrong with this but to me it sounds more like the DVD recorder has a problem I've experienced this problem before not with this particular type of DVD recorder I fix the problem by unplugging the DVD player for about 20 seconds to a minute to give it a good reset.
Quick tip: most high Tech Device problems or unknown errors can be fixed by simple restart or reset hope this helps
Jul 28, 2009 | Toshiba DR420 DVD Recorder
Xbox 360 wont load...
cleaning the lens usually helps with this. If you don't have the tools to do it, try using a can of compressed air. If that doesn't work the laser may need to be replaced.
Dec 03, 2008 | Microsoft Xbox® 360 Core System Console
Loud clunking when loading & playing....
Same problem. Took mine apart, and it appears that shaft of the motor that spins the CD/DVD has gotten wobbly - probably due to a worn bearing. This would explain
Not worth fixing - even if you could find a replacement motor. DVD players are so cheap and feature-rich now, that it would not be worth the time and money to replace just the motor.
I would not continue to use the player in this condition. I noticed some white dust around the rim of the tray when it is open - that tells me that the DVD is scraping on the tray. There is a serious risk of damaging your media. And considering that you can get a brand-new DVD player for the price of 2-3 DVDs...
Mar 30, 2008 | Toshiba SD-2800 DVD Player
Toshiba Sd2800
I have the same problem with my SD-2800 that Ruska has. Any suggestion how the unit can be fixed?
Dec 09, 2007 | Toshiba SD-2800 DVD Player
Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Jun 25, 2007 | Philips DVP642 DVD Player
Cd's are ok but no dvd's...
Had similar problem. Found the disk was not rotating. Adjusted the torque on the hold down screws of the drive unit allowed the disk to spin. Still had some motor noise, but DVD would load.
Apr 09, 2007 | Toshiba SD-2800 DVD Player
Toshiba SD-2800 DVD Player Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
