Extending the reach of youir wireless internet
  • 7,733 Answers
To significantly increase your Wi-Fi coverage (often by up to 40 percent) is to add a wireless repeater or range extender. You should place this repeater at the outer (but good) range of your existing router's coverage and it should repeat the network signals between the existing router and any Wi-Fi computers and devices that wirelessly connect to the repeater.
Posted on Apr 07, 2014
Expand range extender
You can install a wireless range extender. Try a Netgear Dual Band WiFi Range Extender, this device extends the wireless range of your existing wireless router, it connects to your wireless router using a wireless connection without the need of a LAN cable.
May 19, 2013 | TP-LINK TL-WR1043ND Router
Tip
Using a network extender at home
Network extenders and repeaters work to extended the range of your wireless network. You don't have to live in a big house to need an extender, where I live houses are made of concrete which makes the wireless signals a little weak when you're not in the same room as the router. I had played with the idea of getting another router to put upstairs since the signal wasn't reaching from the office on the first floor to the bedrooms on the second floor. But setting up the router and the network was going to be time consuming and I was just trying to make the signal reach a little farther. That's when I discovered repeaters, I set up one repeater at the top of the stairs in my house where the signal began to weaken and ta da! The network now reaches the whole house at full strength and I didn't have to set up a new network.
on Sep 17, 2013 | Computers & Internet
Why Can't I connect my belkin wireless range extender with apple time capsule?
Its very simple just follow these steps -
  • Restart Your Modem First than Restart your Router And Extender
  • Please Your Extender With in 30-35 Yards Of Your Main Wireless Router .
  • Make Sure All Lights Are Blinking On Router And You Have Internet to your Router
  • Try Connecting The Extender Again See if That Works
For more Details kindly visit
Belkin Range Extender Won Connect to Internet Belkin Range
Jul 05, 2012 | Belkin Computers & Internet
How To Use a Belkin Wireless G Router as a range extender? I'm trying to hook my Xbox to the internet, the problem is that the xbox isn't wireless and internet comes from a wireless modem and is...
You can Convert the Router as an Access Point But your Wireless Modem Should Be Hard wired to router. But if your Router has an wireless Bridge Option in it you can Convert it as an Range Extender. Check For the Wireless Bridging Feature on your Router or Please Post your Router's Model Number Here. I Will Be Glad to Help you out... :)
Mar 12, 2011 | Belkin N1 Vision Wireless Router
How do I extend wireless coverage?
Extend the range of WiFi signals with Hardware If your router is placed on the ground floor of your home, the Wi-Fi signals will be very weak or may not even reach the basement computer or the printer upstairs. The situation will be no different if you work in a fairly large premises or if there are too many walls in the area.
In that case, here are some hardware device that you can consider to extend the reach of your Wi-Fi network:
wifi_repeater_thumb.jpgOption #1. You can attach a WiFi Repeater (also known as Wireless Range Expander) to your router and quickly expand the coverage of your wireless network without using any cables.
The Repeater should be placed within the range of your existing router and it will reflect the signals to other areas where the wireless reception was earlier poor (or totally absent). The Repeater can connect wirelessly to both routers and access points (see #3 below).
Option #2. (This is my current setup) You can get another wireless router and connect it to your existing router using an Ethernet cable. The advantage is that this setup comes pretty cheap and the Internet speed stays almost the same even for computers that are accessing the web via the new router.
You can get a 100 feet long Ethernet Cable (also known as Cat5 or LAN or RJ45 cable) for less than $10 and wireless routers start at $20. Here's a detailed guide on how you can connect two routers together.
Option #3. You also have the option to use an Access Point instead of a router to extend the WiFi range but that's often not required because Wireless Access Points can be more expensive than equivalent routers.
The other advantage with a router is that is has extra LAN ports so, in future, you can connect more wired computers for sharing files or you Internet connection.
Option #4. If you have an old desktop or laptop computer, you should consider adding an external (USB based) wireless adapter or upgrade the internal network card to improve the wireless reception (and thus Internet speed).
Jan 04, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I have about 300 meters distance and I would like to connect my internet connection to the end. I'm using smart bro connection, is it possible using router to spread signal of internet on wireless with...
Wireless-g router can only extend it's wireless signal up to 50 to 75 feet. You can use a wireless signal extender to be able to extend the signal further. And yes, you may have password on the wireless network.
Jun 07, 2010 | Linksys Wireless-G WRT54G Router
Extending the range of my neatgear draft n with an apple
according to theory,,it shud work absolute fine,,but it seldom works or even if it starts working it creates probs,,if u hav it in ur house then try it,,but if u dnt hav it ,,i will suggest to go with netgear only,,,i am a wireless technician...i know,,how much probs it creates and call up netgear support to configure ur accesspoint {there are netgear wireless access points}
best of luck,,giv a good rating and keep me posted
May 19, 2009 | Computers & Internet
Range Extender
Both router and range extender must be setup with the same SSID, encryption key and same FIXED channel assignment.
Jan 22, 2009 | D-Link AirPlus G Wireless Range Extender...
Extend Range ?
The best way to extend a wireless signal is to get a wireless range expander/extender , because a high gain antenna really give the needed boost of wireless signal.....
Don't forget to rate the solution FIXYA thank you............
Oct 16, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
