Question about Olympus SP800UZ Digital Camera
What are best settings to copy papers and documents?
I want to use this in archival research and need some basic details re above
Hats a biblyograhy
A bibliography is a list of where you got your information, usually occurs at the end of a research paper
Oct 09, 2014 | Clothing Accessories
I cannot copy and print a document on 8"X14" plain paper. No problem with 8"X11 1/2" plain paper
Scanner: dot2.gif optical resolution: 2400 x 4800 dpi /19,200 x 19,200 dpi interpolated dot2.gif 48 bit color depth
maximum document size: 8 1/2 in x 11/11/16 in dot2.gif Copier: dot2.gif copy speed for text documents: up to 30 copies per minute in black; up to 20 copies per minute color dot2.gif reduction/enlargement: 25/400 percent dot2.gif Fax: dot2.gif color or black and white faxing dot2.gif stores up to 40 numbers in speed dial dot2.gif built in memory for up to 100 incoming fax pages General Features: dot2.gif automatic document feeder holds up to 30 originals for copying, scanning, or faxing multiple documents dot2.gif Ethernet port for connecting multiple users in a computer network dot2.gif 2 picoliter sized ink droplets for fine detail 4 individually replaceable ink tanks dot2.gif ChromaLife 100 inks for long lasting photos dot2.gif Full photolithography Inkjet Nozzle Engineering /FINE 1,600 nozzle print head dot2.gif paper sizes: letter /8 1/2 in x 11 in, legal, credit card /2/ 1/8 in x 3 3/8 in, 4 x 6, 5 x 7 in, envelope, photo stickers dot2.gif high speed USB interface dot2.gif 18 15/16 in W x 9/ 7/16 in H x 18/ 1/4 inD dot2.gif weight: 22.3 lbs. dot2.gif Part Number: 2186B002
you have to select the paper size from the computer while giving printout from computer and apply the changes you make.and while copying the page from the scanner you have to change the printersettings by clicking the menu button in the printer.
Oct 04, 2008 | Office Equipment & Supplies
Tip
How to Write Thesis in One Week
Writing a thesis is very necessary for students because getting their degrees is impossible without it. If the student have not worked out a top quality and custom thesis on their own to be presented to their teacher at the year end, they will face problems in getting their degrees on the right time and passing out with distinction. It is because a thesis is a document submitted in support of a candidate for an academic degree or professional qualification and it represents the candidate's findings and research on a particular subject.
While some students are given to write a thesis during their bachelor's degree program, others are required to do it for their masters or even PhD degrees. They are required to come up with the best paper on their own so that the teachers can judge them for their writing, research and editing skills and understand how well the students have been able to do learn during their academic years. Writing a thesis is no easy task for many students because first of all it is a long and highly complex piece of document that requires a lot of research and hard work. Secondly, it also requires a lot of time as there is too much to do and when students are already burdened with so much of routine working, making time to write a thesis is no easy task.
There are so many students who end up suffering from bad results or just manage to get passing marks because they are unable to write a good paper in the given time. This article is a guide for all those students who do not understand what writing a thesis is all about and how they can manage their time and efforts in such a manner that they come up with a thesis in one week and enjoy best results in class too. Here are the 10 necessary steps that will guide students how they can write their thesis in just one week and make sure they do a good job on their assignment.
Planning to Write a Thesis:
Students need to understand that when it comes to writing a thesis, they must have a main point, a central idea or a message that they want to convey to the readers. They must know what they are working on and how they want to present their thoughts and ideas to the readers. This can only be done if they plan to write their thesis and understand how to move forward. They must study the subject and the given topic really well because this is the only way they will be able to start planning their thesis.
Collecting Information and Conducting Research:
Collecting information and conducting research is the most key step when it comes to writing a thesis or PhD dissertation. The faster the students conduct research, the quicker they will be able to write the paper. It is important to know that when they have only one week to write the paper, they should only spend a day or two on research and not more because this will not leave them much time to write the paper or edit it which are also very important.
Compiling the Research:
After collecting the research material, it is necessary that students know how to compile that research together. They will find too many details and while some of them will be important and worthy, others will not be relevant to their subject or topic. They must learn how to compile the research and only use the relevant and important details for their thesis. They should take only a few hours to do this as they have limited time and must begin the writing process.
Starting the Writing Process:
Once the students are done with the research and compilation process, it is time to start the writing process and they need to make sure that they write the best way without making any mistakes about what information they are imparting to their readers. They must only provide the most relevant and authentic details as the teachers would be checking the papers out thoroughly.
Organization of Content:
Organization of content is very important because if it is not arranged the right way, it will not make sense to the readers and they will only end up getting concluded about what the paper is all about. They must structure the paper rightly by starting with introduction and ending with conclusion and placing main body of discussion and arguments in between.
Checking Out Facts and Details:
It is necessary that students check out the facts and details they are using in their paper as they are very important and play a key role in their success. They need to check out the dates and facts to make sure they have the accurate details in their paper.
Editing and Proofreading:
After they are done with writing, it is time to edit and proofread their paper so that they can point out any mistakes or errors that they have made while writing the paper. They must get rid of all the spelling, typing, grammatical and sentence structure mistakes in order to achieve good marks.
Going Through the Paper for Coherence and Comprehension:
Going through their paper to check out its coherence and comprehension is also a necessary step as it gets students the idea if the paper is complete and ready for presentation to the teacher.
Formatting the Paper:
Students need to format the paper according to the guidelines given by the teacher as it is necessary for submission. If the paper has not been formatted the right way, it will not get them good results because teachers expect the paper to be written on a given format which makes understanding and comprehension better.
Presentation:
Presentation of the paper is a key step and it should be done exactly as the teachers have asked for. If they want a hard copy, students must get the paper printed on an A4 size paper and get it them but if they are asking for a soft copy, email is the best option. All these steps will help students write the best thesis in just a week and attain success in class.
on Feb 14, 2017 | Higher Education (University)
How can I make copies?
The 7760 isn't a copier. You can make multiple copies of whatever you're printing, but but it can't make a copy of a paper document.
The paper loading instructions begin on page 8 of the basics guide. If you need the manuals, you may download them from here.
Oct 26, 2012 | HP PhotoSmart 7760 InkJet Printer
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
How to scan legal documents on Canon MF5770?
This information is available on CANON WEBSITE
Unfortunately, they imbed the text in javascript, and there is no way to link or c/p the information here. Try THIS HYPERLINK to take you to the exact page.
Enter your model # in "search knowledgebase" at the above link.
Type PAPER SIZE
You will have a clickable link that says How do I specify paper Size and Type.
Instructions will appear.... starting like this... (i used C/P, and it may not come out slearly after I submit this answer)
Issue: How do I specify the paper size and type?
Solution: Specifying the Paper Size and Type
  • When making copies on LTR-size paper after having continuously copied on paper smaller than LTR-size paper, the copies may be dirty. To prevent copies from being dirty, wait about 1 minute before making copies.
  • The paper in the multi-purpose feeder is fed prior to the paper in the cassette.
  • The settings changed in the Menu do not return automatically to the settings you set previously. Change to the previous settings again if necessary.
  • When making copies of a small size or heavy paper*, etc., the copy speed may be slightly slower than usual.
    *The paper type should be selected in the Menu.
  • If you intend to make a copy and print with a thermal transfer printer using the same sheet of paper, make the copy first. Failure to do so may make copies dirty or cause a paper jam.
  • When copying onto transparencies, remove each transparency from the output tray as it is output.
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
How do I get a fax off memory recall? It kept saying load paper and I had paper in it. I unplugged the machine and then re-tried and cannot find it.
Welcome to FixYa. I'm the expert that chose your problem to fix.
First, let's get rid of the offending document:
  1. Print a list of documents stored in memory like this:
  2. Press function, then
  3. Press memory reference, then
  4. Press set to print.
  5. Find the document you want to delete, then
  6. Press function, then
  7. Press memory reference, then
  8. Find the document to delete by using the up/down arrows to select the transaction to be deleted. Hint: refer to your printed list to see detail, it will help you identify the document.
  9. To delete: press set, then confirm the deletion by pressing the * (star) key.
Relative to the paper issue you described, let's try the above then if it persists, I'll research it further.
Thanks for using FixYa!
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further. I am at your service.
Jan 09, 2009 | Canon FAXPHONE L80 Laser
HP Officejet J5740 all-in-one. Paper continues to jam even though we clear the jam and align again and again. When we try to copy again, it says paper jam. If we push OK, the paper will feed through, but...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00829028&lc=en&cc=us&lang=en&rule=18697&product=3301742&dlc=en
Try the link above. I researched your problem. It seems to me that you may either :
a) Have some small paper stuck in the rollers, or
b) need to clean your rollers,or
c) just need to reset the paper jam message.
Either way, the link above should take you right to where you need to go. If it doesn't , just go to HP.com and then their support section , type in your printer's model, and it will take you there.
Good luck !
Aug 02, 2008 | Office Equipment & Supplies
When I try to print to my laser printer MF4150, it prints one copy and the error light comes on and ithas LOAD CORRECT PAPER CASSETTE :A4 I pulled the paper out and reloaded. I Looked in my BASIC GUIDE...
Go in (win xp)
control panel
printers and fax
right click on the printer giving problems
click on properties (down the list)
click on printing preferences
on page size, switch from A4 to letter
click OK
Have a nice day
May 01, 2008 | Olympus P-11 Thermal Photo Printer
Unusual paper size
Load the custom size paper in Paper Tray 5 (Bypass Tray). The Tray 5 screen will be displayed on the Touch Screen. Select [Non Standard Size] from the column on the left. Select the [Up] or [Down] arrow button to modify the X dimension of the custom paper size. The value range is from 147.32 to 457.2 mm (5.8 to 18.0 inches). Select the [Right] or [Left] arrow button to modify the Y dimension of the custom paper size. The value range is from 147.32 to 297.2 mm (5.8 to 11.7 inches). Select the appropriate paper type from the Paper Type column on the left. Select [Save]. Select [Tray5] from the paper supply section under the [Basic Copying] tab. Make any other required selections for the job from the Basic Copying tab on the Touch Screen. Place the original(s) in the Document Feeder or a single original on the Document Glass. Press the [Start] button on the Control Panel to copy hope this helps!!!
Jul 29, 2007 | Xerox DocuColor 12 Printer
Olympus SP800UZ Digital Camera Logo
55 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
