External microphone volume very low
Microphone detected, "working properly", but volume is very low.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
Hi there. Try Right clicking your speaker icon next to your clock and you will get a menu to adjust setting. Try Volume Mixer. Good Day
Posted on Feb 12, 2014
Hi, I have HT-1001 mic, the volume from the mic is low, any possibility increase the volume? do i need to use the external Amp?
The mike can be a mismatch with your CB A booster mike amplifier with a volume control will suffice.
Oct 25, 2012 | Hisonic Audio Players & Recorders
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
How to increasde the increase the voluem, whenever i shoot videos and while playing the videos the volume is very low. i check and increased the volume but its same volume is coming. and i dont know t
Recording volume on your camera is not controlled by the Volume setting on the camera. The volume setting is for playback volume.
If your recording volume is low, then it has to do with the microphone. Either move closer to what you are recording, or look into buying an external microphone (if your camera supports it).
Nov 29, 2011 | Sony Cyber-Shot DSC-HX7V Digital Camera
I can hear people on msn but people can not hear me
The Dell Inspiron 1501 has a set of internal speakers but doesn't have a built-in microphone. You need to plug an external microphone into the microphone jack on the right side of the notebook as shown below. You can open Messenger and click on the Tools tab then select Audio and video setup. (note as there is no built-in webcam, it will just be an audio setup). You may decide later to add a USB webcam with a built-in microphone in which case the plug-in external microphone will no longer be required.
Mar 26, 2011 | Dell Inspiron 1501 Notebook
Hi. i am a regular user of google talk..but since one week i cant talk properly thru google talk.i caould hear from the other end..but they can hear only my broken voice.my head phones work fine with...
Make sure the volume for your microphone is turned on. Here's how:
  1. Click the 'Start' menu in your taskbar, and highlight 'Settings.'
  2. Select 'Control Panel.'
  3. Locate 'Sounds and Audio Devices' in the Control Panel, and double-click the icon.
  4. Open the 'Volume' tab, and click 'Advanced...' in the 'Device volume' section.
  5. Look for 'Microphone' in the 'Volume Control' box that opens, and make sure your microphone is enabled and the volume is high enough.
  6. Close the 'Volume Control' box, and then click 'OK.'
If you're using an external microphone, and the volume is set properly, check that the device is securely connected to your computer.
And if that doesn't solve the problem, make sure your microphone of choice is selected in the 'Output - speakers or headset' drop-down menu in the 'Audio' section of your Google Talk Settings.
Cheers!!
Oct 18, 2010 | Google Talk
I cannot enable microphone on Nc6220
if the sound driver it is ok and working ..and the microphone do not have any damages..than the path to do it ..is double click on the volume icon in the right on the task bar ..after that it will open a volume manager ...click options in the left side and properties..in that list click on the microphone case to activate ..(if the mic is not present and you use an external click on the pink in) after that will be exposed on the list of volumes...be sure it is not muted..and have the volume on maximum ..
For to activate it in the yahoo messenger or skype..you have to choose call set-up and run it for to be detected..in yahoo messenger and for skype choose to open sound set-up and run detection also ..
May 20, 2010 | HP Compaq nc6220 Notebook
I skpe using my Asus, and my microphone does not work.The other party can't me...how do I solve this please
Hi
Are you sure that this laptop has a build in microphone? or are you using a external microphone?
in either case the most likely problem is that the skype sound settings on the input are wrong.
open skype, tools, options, then the audio settings page.
On the microphone, try all the possible options offered and see if it detects your voice, you can also try calling the skype test number / echo123.
When you see the volume bar light up green like this as you speak or tap the microphone its working.
If you are using a external microphone, are you sure you have it on the right slot? Try the other plugs on the laptop and then go over the options again and see if you get sound.
You should also check from volume control that the microphone is not muted.
To check that open up start -> control panel -> sounds -> recording -> select the microphone and click properties -> check the levels tap and make sure its not muted and its turned up to full volume.
also some microphones have a on off switch on the wire, make sure its turned on.
By now you should be able to talk on skype.
Let me know if you need further assistance.
Thanks,
Ekse
Aug 13, 2009 | ASUS m6n Notebook
External microphone not working
Check first if your sound card is working properly.
My Computer >> Right click...Properties >> hardware >> Device manager >> Sound
Then go to Start >> Control Panel >> Sound and Audio Devices .........hit ADVANCED
one dialog appears MASTER VOLUME >> Go to OPTIONS >> Then PROPERTIES..........
CHECK the MICROPHONE...........Hit OK.............
This will be fixing your problem (if your sound card is working well)
Oct 30, 2008 | Compaq Presario 700 470024-192 Notebook
External Microphone - Not working
good day
have you tried inserting the microphone plug to the red/pink socket in your sound card?
Sep 20, 2008 | Compaq Presario 700 470024-192 Notebook
Vista 64 microphone not working
hmmm did you try a different mic, and exure its jacked into the mic in of your sound card.. If you have dual sound devices, ensure its in the correct selected device...
1.)To see which device you have as the selected device, Click Start, All programs / accessories / entertainment, volume controll..
2.)Choose Options and then properties
3.)In the mixer device drop down list, ensure that the correct device is selected. Click on the drop down list to see all aviable devices..
4.) Now under the Adjust Volume For selection select recording
5.) In the Show Following Volume Controll Box, select Mic,(make sure its ticked)
6.) Click Ok
7.) The mic and aother controlls will show up, under mic ensure select is checked..
NOW TEST YOUR MIC..
1.)Start, All programs / accessories / entertainment / Sound Recorder
2.) Click Edit then Audio Properties
3.) Under Sound Recording Select the Appiorate device..
4.) Click Record and try it..
5.) Stop it and play it back..
IF THAT DONT WORK REPLY HERE AND WE WILL HAVE A LOOK AT THE DRIVERS..
Jan 13, 2008 | Creative Labs Sound Blaster Audigy LS...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
