Question about Linear Corporation Channel plus 5445 4 channel video modulator
Reset a channel 5445 modular
5445
I have power to the tiller, lights horn etc but when you push the wigwag nothing happens. Motor and brake work when I bypass everything else. Any ideas?
What is the model number of your unit? Here are the most common issues: If motor/gear are operational when bypass, then YOUR MODULAR is defective. Note: if the 1st led light is dimmer then rest, defective modular. You should obtain 24vdc output when throttle is pressed. on output terminals. No voltage? Modular will be contact me....CTM Direct 909-590-1388 x115
Aug 31, 2016 | Health & Beauty
I cannot get the unit to switch on, I have changed the fuse, removed all cables
Was the fuse you replaced blown? Has AC outlet on the wall been verified to be working properly? If outlet works, modular type AC power cable found to be properly seated and fuse was "OK" you've had a power supply failure that requires shop service.
Mar 27, 2015 | Pioneer VSX-921K 7.1 Channel A/V Receiver...
Assembly instructions for aspen Barolo 6 piece modular office
most modular desks have a groove around the top of the base unit that small clips lock and pull the top to the base when the screws are tightened
Jun 09, 2013 | AspenHome Aspen Barolo Modular Home Office...
On a 1988 GMC Safari there is a modular under the hood on the passenger side firewall that activates the heater fan. What is this modular called and how do I replace it?
You go to a Dealers Parts Dept & they will put up a diagram
on screen for you to point to
Auto Parts won't even follow your conversation or have it
Nov 25, 2012 | 1988 GMC Safari
I have a Dish receiver 322. TV1 is set on channel 3 and TV2 is set on channel 116. Everything worked. We moved the receiver and TV1 into another room (right next door to where it was). We triple checked...
Hi hartbettinaI see where your TV2 has a blue screen, there are a couple of things you can doyou can do. The first things you want to do is press the buttons of MENU-6-1-5and see if TV2 is set to channel 60 or 73 and make sure TV2 is on that channel.Once TV2 is on the channel on the Modular Setup page you will want to unplugthe receiver for 10 seconds and plug it back in and it will reset itself. Iwill send a link that will help with these steps. http://www.dishnetwork.com/SupportSection/black-blue-tv2
Feb 27, 2011 | DISH Network 322 DTV Receiver
I have a Raymarine 240 VHF from the USA and I need to get it switched for Australian use (VHF Channels - Frequencies) ?
Hi Michael
From the owner's manual (Page 14) you need to press "menu", then select "Frequency Group", then you have the choice of USA, Canada or International channels:
Here's the link to your owner's manual should you require it:
http://www.raymarine.com/ProductDetail.aspx?SITE=1&SECTION=2&PAGE=830&PRODUCT=1948
Hope this is helpful to you.
Sep 06, 2010 | Raymarine Ray 240 Modular Vhf System
I have an old motorola mobile 40 channel cb radio T4022A can you tell me wnere and specs on this unit?
Local-Distance switch for selective signal control. Modular filter board design for easier maintenence. LED Channel readout. Power Microphone. Automatic noise limiter. 3.5" speaker. Integrated antenna mismatch protection. Signal RF meter. 4W RF power. 12VDC.
Jul 10, 2010 | Car Audio & Video
I have a GARDENA Watering Controller 4040 modular. In the Watering Programs section it says that '' a maximum of 6 channels can be open at the same time ''. On the assumption that each channel is one...
You cannot run all channels at the same time you will not have enough water presure to do this . Check the manuel it might be saying that you have six station available there are 4 station timers 6,9,and 12 but each station has to run on its own and then move to the following station after water time is up for maxiumum water preasure.
Jul 06, 2010 | Garden
Lifebook T 4215 - modular replacemenet battery
just a thought, try to update your BIOS, or look in bios for errors
Jun 26, 2009 | Fujitsu LifeBook B2131 Notebook
Linear Corporation Channel plus 5445 4 channel video modulator Logo
32 people viewed this question
Top Linear Corporation Televison & Video Experts
Electro Med Services...
Are you a Linear Corporation Televison and Video Expert? Answer questions, earn points and help others
