Question about Kenmore Dryers
I have a kenmore dryer model 8904 and it runs fine but it wont heat up
My kenmore dryer model 8904 will spin and all of the displays on the front panel light up and work but it wont heat up
  • Kenmore Master
  • 2,636 Answers
These are several things that can cause this, I will list them in order of "most common" to "least common."
1) Most common: The heat element has failed, they break in two pieces, and must be replaced.
2) One of the thermostats or a fuse has failed, and must be replaced. If this is the problem, you must also clean the whole inside of the machine's ductwork of lint, or having replaced the part, it will fail again.
3) A wire has burned in two, often near the heating element. Rarely, it can also be near the electrical cord in the back of the machine.
Be blessed.
Posted on Feb 13, 2014
SOURCE: removing front panel on kenmore dryer
I was able to fix my dryer on my own. the problem was, i was instructed to access an area that wasn't correct for the needed repair.
Posted on Mar 10, 2008
  • 185 Answers
SOURCE: kenmore gas dryer wont heat, model #11074832400
check the igniter,thermal fuse,operating themastat there is a small plastic piece on the lower left hand corner pop that out and when you turn your dryer on it should be glowing red if not its the igniter
Posted on Mar 25, 2008
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
Illeagle
  • 525 Answers
SOURCE: LG Front loader Electric Dryer want heat but will run and spin
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This link will show teardown illustrations: Parts and more help available on other pages of the website.
http://www.repairclinic.com/0100_16.asp
Hope this helps.
Illeagle
Posted on Aug 27, 2008
ginko
  • 19396 Answers
SOURCE: kenmore electric dryer
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Model 8904
check ur fuses out
Aug 31, 2014 | Kenmore Dryers
Front panel wont light up, why?
I have the same issue. Dryer lights when door is opened, but no panel display, and no function.
Jul 26, 2014 | Kenmore Elite HE4 Electric Dryer
Whirlpool model 110.88752792 dryer runs but does not heat
Concerning the Kenmore 11088752792 model where the dryer spins but does not heat. I had that problem a few years ago with the same model.
I replaced the fuse (part No. 3399849 about $10.00) and the thermostat (part no 3398128 about $25.00). Dryer worked fine the first try.
FYI. Today, I'm searching for what makes the dryer squeak when I came across your issue (though 6 months since you posted, but I figure there are other Kenmore stack-able owners out there searching for a fix). I haven't taken the dryer apart yet but have ordered the dryer belt, rollers, pulley (a package deal with RepairClinic) and the felt bearing/seal. May as well do a full replacement of the likely components that are causing the squeaks and not spend any more time going through trial and error repairs.
If you haven't already, the dogs on your agitator are probably due for replacement as well. RepairClinic has an agitator package deal with replacement dogs and seals.
Jul 14, 2011 | Kenmore 94802 Front Load Stacked Washer /...
I have a kenmore dyer model #10070602990, the dryer spins, but it does not heat up. what could be the cause?
thermal fuse, heating element, timer, or thermostat:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Here is another website that is helpful:
http://www.applianceaid.com/general.html#timers
Feb 16, 2011 | Kenmore Dryers
Hello< My dryer is spinning no
The problem when the dryer runs but doesn't heat is usually caused by a failed high-limit thermostat and a blown thermal cut-off both located on the heater housing. Verify this by bypassing both parts for troubleshooting purposes then running the dryer.
Disconnect power then remove the screws attaching the bottom front panel to the bottom flange of the cabinet. Slide the panel down and off the cabinet to access the heater housing.
Remove the hex-head screw from the heater shield and remove the shield.
Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-off to the heater terminal where the red/white stripe wire is disconnected from.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards. Let us know should you need further advice.
Jan 11, 2011 | Kenmore Dryers
My dryer wont spin.It heats up and comes on but wont spin.Model # 96320100
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 07, 2010 | Kenmore Dryers
My dryer wont work. my kenmore elite wont turn on. the light in the dryer is working so I know there is power to the unit but the control panel wont turn on. The model number is 110 60092991
Kenmore by Sears,
DD
This is really a simple project
I believe your belt broke and Kenmore put a kill switch to protect your motor and heating element.
there are two screws when you remove your lint screen.
Remove those screws.(philips)
With a straight screwdriver, gently pry up the top of dryer.
When loose, open all the way to the back and rest on the wall,
On each inside,behind the door, at the top, is a 1/4" bolt. Use Socket to Remove both. Pull up and out on the front and put it to the side.
Remove the drum.
Now you can clean the inside with a vacumn. See the kill switch in front of motor.
The model is inside the door on the left
since you have it apart check the drum rollers for flat spots as well as freedom in movement DO NOT GREASE
Put it back together
Jul 24, 2010 | Kenmore 63942 Dryer
My Kenmore Dryer Model # 96551220 does not run. Heating coil is fine.
When u say it does'nt run do u mean it doesn't spin??? if so ur belt is probably broken..about a $10.00 part an easy fix with a handy friend...if u mean it does'nt heat then it could be a thermal switch if it not the element....the switch is pretty cheap also and is located behind the panel in the back of the dryer...is usually white and an easy replacement as well...
Apr 05, 2010 | Kenmore Dryers
Dryers Logo
350 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
