Question about Staples TXC122ACC Cross-Cut Shredder; 12 Sheet
Won't shred in auto but works in rev
Won't' shred in auto, but works in reverse
  • Maka Taufaga
    Maka Taufaga Feb 13, 2014
    Yiu might need to wipe clean the phot sensor situated near the mouth of the machine where you input documents to be shredded. ENSURE THE POWER IS OFF and the power cable disconnected from the power outlet. This particlular sensor is probably situated in the very middle of the input slot and may look like a small circular bulb; on both sides of the slot.
Why doesn't OfficeMax OM99732 shredder work on Auto?
My shredder would not sense paper being inserted and the sensor could not be cleaned. So "Auto" no longer worked but the manual reverse DID work. I opened the thing up, reversed the polarity on the red and black wires on the connector for the main drive motor and VOILA!!! I can use my shredder in manual mode by switching it to REV. Be mindful that this keeps the motor running until it is switched off. This can heat the motor and cause failure so I limit my shredding to 60 seconds then give it a rest so it will cool down. Also there is no emergency reverse so watch your fingers and neck ties.
Dec 17, 2012 | Office Equipment & Supplies
Shredder doesn't shred.
Shreader wont cut will reverse ok
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Jammed in Auto, but works fine in reverse. How to unjam?
Continue to alternate between auto and reverse a number of times. Try to shred narrower pieces of paper at opposite ends to see if it can trigger the auto trigger wire. All else fails, carefully take the shredding part apart and you may find a hugh paper jam underneath.
Sep 02, 2010 | Aurora Electronics AS662C Shredder
Runs in reverse, but no on auto.
check and see if there is a jam of paper inside the unit or around the sensors
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Royal 10X Shredder
Will not shred will go in Rev
I just fixed a similar issue. My AS702MX shredder fell off my desk while I was emptying the basket. When I tried to use it after that it only ran in reverse, not in auto/forward (it was not jammed). This meant that the motor was still working. Since this shredder is so old, no longer under warranty, and not working anyway, I decided to open it up. I unscrewed the 5 screws on the bottom (that's all), then the plastic covering opened up. While looking at the shredder from the top (without the plastic cover) you will see a small black plastic trigger mechanism in the middle (this is what the paper hits to start the shred) this piece will push a copper filament onto the motor to complete the "auto" circuit. Well the fall had caused the plastic trigger to dislodge on one side... I popped it back into place and closed it up, and its working fine now. It was really simple to fix.
Aug 04, 2008 | Aurora Global AS702MX Shredder
Shredder won't shred any more.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Mar 27, 2008 | Office Equipment & Supplies
Staples TXC122ACC Cross-Cut Shredder; 12 Sheet Logo
162 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
