Question about Coleman Retro Rechargeable Battery Powered Lantern Family Size
Charge Time for 5312 Lantern - Coleman Retro Rechargeable Battery Powered Lantern Family Size
Where can I get a replacement battery for the trail tracker, emergency radio lantern, yellow?
Trail Tracker Sport Lantern/Weather Radio doesn't charge using the hand crank dynamo for my Power on Board Trail Tracker lantern/radio, You most likely need a new battery, you can purchase one from Black...
More information please open this link:-- Best Manuals
Jun 17, 2016 | Cars & Trucks
My lantern is not charging model 5312
Since the red led comes on it proves that the charger is working but since it is not able to charge the battery I would say that the battery is bad.
Nov 29, 2014 | Camping, Backpacking & Hiking
Charge Time for 5312 Lantern Battery?
Charge time is 18hrs. If you left it on and it was flat, imediately charge for 40hrs.
heres the manual.
http://r1.coleman.com/Manuals/5312R.pdf
Feb 12, 2014 | Coleman Retro Rechargeable Battery Powered...
I am trying to find a 120 Volt AC adaptor for my Swissgear lantern.
The adapter need to match the charge voltage requirements of the battery in the Swissgear lantern.
This voltage maybe written on a label on the lantern.
i suggest go to the shop where you purchased the lantern for the charge adapter.
Jun 02, 2012 | Computers & Internet
In the Coleman 5312 Retro Series Lamp is it supposed to work off the mains charger even if the battery will not charge. Battery is confirmed dead but lamp will not work on mains nor on 12v car lead. Don't...
Brentonb, In the event that you don't get a direct answer (which is likely, since this is a pretty obscure question) I suggest you troubleshoot it this way. Remove the bad battery. Use the charging device that came with the lantern and wire it temporarily to the device in place of the battery. This will supply the correct voltage, but takes the possibly shorted battery out of the circuit. If you are certain you have the polarity correct and you know that the charger works, then you have your answer. good luck.
Dec 03, 2010 | Coleman Retro Rechargeable Battery Powered...
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
Coleman lantern/fan/radio won't take a charge any more.
Yes there is, you can check out http://www.batteryinternational.com/lantern-battery.html to find a replacement, or call 1-877-28-BATTERY if you're having difficulty finding the battery you need. Hope that helps.
Jun 14, 2009 | Coleman Lantern Fan Radio (841.321) AM/FM
Coleman Retro Rechargeable Battery Powered Lantern Family Size Logo
74 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
yobo007
yobo007
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
