Question about Precor 9.21 Treadmill
Where can I find a Precor 9.25 treadmill motor cover?
  • 6 Answers
SOURCE: Precor M9.21 Treadmill - Stops under load
This probably did not happened suddenly right? the problem is not the motor however you can easily check the blue capacitor for peace of mind. with the power disconnected, disconnect one side off the capacitor from the top. with a ohm meter put the 2 probes on the cap,you will ear a temporary beep sound from your meter, then reverse your probes on the capacitor and again a temporary sound that mean your capacitor is good and your motor will run OK.
Your problem is more then likely your run belt and bed assembly. When new, these are coated with a wax of some kind for slipping, has you use the machine wax wears off, and so is the belt. You can see a black rubber dust at the rear of the machine. And so resistance increase when pressure is applied on the running belt.
Just behind the on/off switch where the power cord goes in, there is a auto reset 15 amp breaker that trips when too must resistance against the motor increase the amperage over 15amps. At 7 min/m on your speed setting and if the belt is adjusted correctly with nobody on, the motor pull about 6amps, with someone like me 180lbs, the motor pulls an avg of 10amps with a new belt.
If you have a clamp amp meter you can test it yourself.
2 parts you will need to fix this; 50985-101 (bed assembly) and 36355-101 (run belt 17 X 110) This is real easy to install.
make sure these parts are for your machine model # as they did increased the width of their belt over the years
Since 1998 I had to replace these parts 2 times with an average of 3 people using the treadmill every day. This is a good machine and if everything else is good it's worth it. I paid $300 for these parts, i'm sure if you shoppe a little you can do better.
Have a good one
Ben
Posted on May 26, 2009
maxtreadmill
  • 832 Answers
SOURCE: Where can I order a plastic cover for the motor?
The only place that would possibly have the motor shroud would be Precor and they may say obsolete no longer available. This particular model # is not familiar to me since the common numbers on the older treadmills are 905e, 9.1, 9.17. 9.2 etc I assuming this was not intended to be sold in the USA.. I Suggest going to Precor's website and get the appropriate phone # to call.
Posted on May 31, 2010
  • 15 Answers
SOURCE: Just moved my precor c966i treadmill (we
it should be a cable that looks like an oversized telephone cable. I can't really tell by the description of the problem if you just can't remember where it plugs into or if you've lost it altogether. There will be a circuit board in the base of the treadmill that will have something that looks like a phone jack port on it. That's where it will plug into. There should only be one port on the lower board that will accept that style of plug.
Posted on Jul 09, 2010
Testimonial: "This is the exact answer to the problem--after much searching around, I finally found the little box it fit into. the treadmill is up and running. Thanks for your input."
  • 95 Answers
SOURCE: I am looking for a
Here is a motor cover for several versions of the Precor 9.21. Not sure if that's what you're looking for or not but maybe that will be useful.. you can click on any of the equipment models listed there to browse a complete parts list.
Posted on Jul 05, 2011
  • 95 Answers
SOURCE: Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
Posted on Jan 13, 2012
Where can I find a used lift motor for a Precor C966I treadmill? Part # on the motor is 6182A-1705080-01
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I am not sure where you can find a used one, but I can find a couple of new options for you. Depending on your machine, there are two different motors available. One is for a 220V machine and the other is for 110V machine. I will post links to both.
MOTOR LIFT ACTUATOR 120V PRECOR TREADMILL PPP000000044257107 SPORTSMITH net
Lift Motor 240V Precor PPP000000044257108 SPORTSMITH net
Dec 22, 2014 | Precor C966i Commercial Treadmill Used
Reviews on Precor 9.21Si
please read your owner manual. Diwnload freewww.fitnessmanualsonline.comGod bless you
Mar 16, 2013 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
Parts for a PreCor 9.1 treadmill
go www. precor.com or www. fitnessrepairparts.com or www. treadmillspartszone.com
God bless your
Jul 06, 2012 | Precor 9.1 Mode 1 Treadmill Repair Parts...
Jan 10, 2012 | Precor 9.21 Treadmill
I am looking for a shroud cover for my Precor M9.21 Treadmill #FSL17I0001
May 22, 2011 | Precor 9.21 Treadmill
Broken motor cover
There are a few different versions of the Precor 9.21 treadmill but FitnessRepairParts has a motor cover that it says is used for several of the models: http://www.fitnessrepairparts.com/cart/ViewItem/5005569
Oct 05, 2010 | Precor 9.21 Treadmill
May 31, 2010 | Precor 9.21 Treadmill
Need a new plastic cover for the motor/electronics part.
Hi Linda
Here is a telephone # for Precor Austria +43 64 52 3900 or you may directly email www.intlcustsupp@precor.com.
Mar 08, 2010 | Precor 9.21 Treadmill
Precor 9.21 Treadmill Logo
21 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
