Sylvania TV model srt2220f
I need to tell this TV to change my input to my DVD player. It is "stuck" on just receiving the cable signal. The IR sensor is burned out, haven't found replacement, so can't use remote. I want to use the menu buttons on TV set but on this model the only options are: Picture, Channel Set, English/Espanol, V-Chip and Caption. I can't find a trail to what I need under any of these headings. Any suggestions for maybe going deeper into the menu and finding a way? (Pls, I know all about remotes, coding, etc. I'm sure my problem is a non-functioning IR sensor and it doesn't appear accessible.)
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Posted on Apr 05, 2008
crayzeetrayn
  • 837 Answers
SOURCE: LOST MY INSTRUCTION MANUAL FOR MY RCA DIRECTV UNIVERSAL REMOTE
Here's an on-line guide
Here's a codes page (Sylvania 10054, 10030, 10171,10020, 10096, 10381)
Posted on Jan 04, 2009
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
SOURCE: Set TV Code for Yamaha Remote RAV-290
Do any experts know the answer to this question? It has been posted multiple times, but I dont' see any answers! It is a pitiful manual that is provided by Yamaha for this purpose and nothing is intuitive about making this work. If anyone know the answer, PLEASE POST IT!
Posted on Oct 13, 2009
SOURCE: I have a 19" Genesis LCD TV and I need the Remote Control Code
I have a 22" genesis LCD and can not get my Direct tv remote to work?
Posted on Nov 14, 2009
Why can't I get the DVD player to work? I have it hooked up to a cable box.
im wondering why you did not connect it to the tv ?? but instead to cable box , does it have a pass thru capability ?? does it need to be off to pass thru ?? as most dvd player don't have a rf output but instead use a hdmi or composite signal output , would it not be easier to connect one of these to a spare input on tv then when u want to use dvd you only need to select the proper input from tvs source button to view the dvd ??
Jan 10, 2017 | Sylvania Televison & Video
How do I hook up a HD satallite dvr to a av reciever dvd player and HDTV using HDMI cables
Things You’ll Need:
  • HD television
  • HD satellite or cable receiver
  • DVD player
  • Stereo receiver
  • AV cables
  • Cable connector
  • HDMI cables
Step1Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar). Step2Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV. Step3Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row. Step4Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV. Step5Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will). Step6Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal. Hope that helps..........
Jul 15, 2008 | Televison & Video
Trying to hook a dvd player up how do i do that
There are three ways subject to what your DVD player and receiver can support.
1. Connect the stereo output of the player using a pair of analogue interconnects. The outputs are usually color coded red and white (for left and right). Simply plug in the interconnect and connect the other ends to a matching pair of inputs on the Receiver. Then make sure you select the correct input on the Receiver for the sound to come through.
2. The second method is to take advantage of surround sound audio (Dolby 5.1 for example) on the DVD. You will of course need a surround sound speaker system connected to your Receiver to take advantage of this. You'll need 'either' an Optical or Coaxial cable. These are both single cables that carry the digital audio form the player to the Receiver. Check your manual to see which ones your equipment has. Alternatively look on the back of the DVD player, the digital output is usually marked quite clearly. Obtain a suitable cable, and plug into the DVD player and the other end into the Receiver. Again make sure select the correct input on the Receiver. You 'may' need to go in to the menu settings of the DVD player in order to tell it to output the digital signal.
3. HDMI - If you DVD player, Receiver AND TV all have HDMI connections then this is by far the easiest. You'll need 2 HDMI cables. The first one goes from the DVD player into the Receiver, the second goes from the Receiver to the TV. Again make sure you select the correct HDMI input on the Receiver and the correct HDMI input on the TV and that should get you going!
Hope this helps?
Jun 13, 2011 | Audio Players & Recorders
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
Connect AV receiver to a Dish receiver model VIP722 DVR
Your DVD player should connect to your TV, not the DISH DVR. Is the Yamaha some sort of receiver or something similar? If so, it should plug into the TV as well. The DVR just provides a signal to your TV, just like the other two components. On the back of your TV there should be other connections to plug into like HDMI1, HDMI2, AUX1, etc. You select which input you want to view using your TV remote. For example, if you were watching a DVD, you turn on the DVD player. Say it was plugged into AV1 or something similar on the back of the TV. With your TV remote, select which input you are using...that way your TV receives the signal from your DVD player and nothing else.
Nov 16, 2017 | Onkyo HTR500 Receiver
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
I have a 30 year old tv w/cable. I want to install a dvd/vcr combo player. What kind do I need? I've tried one and it didn't have the right connection.
If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
- Jim
Jul 03, 2008 | Televison & Video
MY DMR-EH55 has problems repsonding to the supplied remote control
Firstly, check you do not have bright light shining across the IR sensor.This can degrade the signal to noise ratio of the IR receiver.
Second, check you do not have a noisy mains electricity supply, arcing plug block or running from square wave inverter supply. Either of these can cause problems with IR receiver in the DVD player.
Feb 25, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
