Question about Weider WESLO CADENCE M5 TREADMILL Console
Weslo cadence m6 treadmill
I have a weslo cadence m6 which keeps slipping when used, ive done as it says in the manual, turn rear roller bolts clockwise, but it's still happening, any other suggestions?
The belt on my treadmill keeps slipping and i wanted to know how to stop it ...
hi,
You have to adjust the treadmill belt. Just watch the following video to do the same.
OK
Sep 01, 2011 | Treadmill Doctor Weslo Cadence Dx10...
Weslo Cadence 830 ....Looking for a free online manual
my weslo 830 the belt seems to drag when you step on to it. should i oil it if so how?
Dec 18, 2010 | Treadmill Doctor Weslo Cadence 835...
My belt is slipping to one side and i no longer hav the manuel
hi
chek if it is level
and then turn rear roller bolt of treadmill to clockwise you should turn the side which is closer to the to the foot railing(i mean slipping to the side)
1 step
check if treadmill is level
2 put tread work on speed of 2-3 mph
3 turn rear roller bolt of slipping side 1/4 clockwise with small steps and you should see it going to center
Nov 25, 2010 | Cadence Weslo 927 Treadmill Walking Belt
The plank or wood running board of my cadence M6 Weslo treadmill is broken and i'd like to know where i can fin this spare part.
hi, walking platform is the name of the part you need, not worth buying costs £80,00+vat+delivery charge. you are better off buying one off ebay for £100 to £150 and keep yours as a spare. the motors tend to burnout pretty quick.hope i have helped
Oct 29, 2010 | Weslo Cadence CT 4.8 Treadmill
Belt slipping and moving
Here is a basic procedure that will work for the majority of treadmills out in the market:
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centred. b. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill
Jul 15, 2010 | Treadmill Doctor Weslo Cadence Dx10...
Require a users manual for a WESLO CADENCE 1000
Go to iconservice.com click on manual for your CADENCE 1000 (WETL4850)
May 12, 2010 | Treadmill Doctor Weslo Cadence 1000...
Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
Mar 22, 2009 | Cadence Exercise & Fitness
Adjusting the walking belt
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Jan 13, 2009 | Exercise & Fitness
Weider WESLO CADENCE M5 TREADMILL Console Logo
16 people viewed this question
Top Weider Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Weider Exercise and Fitnes Expert? Answer questions, earn points and help others
