Question about Samsung BIXOLON® SRP-275 Matrix Printer
Not printing correctly- numbers and symbols - Samsung BIXOLON® SRP-275 Matrix Printer
On the Reczone Password Safe model 595 I am not able to type the symbols associated with the number keys even when I use the "shift" key. How do I type the symbols?
Have you tried the orange button?
I mean the same way as the shift key function? Because, they are built the same with qwety keyboard. The hint is the orange printed symbols. Same as blue printed "Fn" button on PCs.
I haven't used it but it worth a try.
Aug 27, 2014 | Computers & Internet
CAN'T TYPE SYMBOLS
Make sure NumLK key is not on.
Mar 18, 2014 | Toshiba Computers & Internet
How to turn printing on and off?
PRINT KEY: To save paper you can only print what is displayed, even in non-print mode. Pressing after the entry of a number will print the entry with the symbol “#” even in non-print mode. Pressing will insert a separator into a number entry such as a code, date, etc. Separators are displayed as a period and dashes but printed as periods. MEMORY + KEY / PRINT ON / OFF KEY: Pressing selects print mode or non-print mode. Cause the calculator to operate in a display / print or display only mode, depending upon the calculator’s present state. “P” on the display: Print mode. “NP” on the display: Non-print mode. MEMORY – KEY / DECIMAL SELECTION KEY: Pressing sets the number of decimal places in the result. “F” on the display: The answer is displayed in the floating decimal system. “3, 2, 1, 0” on the display: Presets the number of decimal places in the answer. “A” on the display (Add mode): The decimal point in addition and subtraction entries is automatically positioned to the 2nd digit from the lowest digit of entry number. Use of the add mode permits addition and subtraction of numbers without entry of the decimal point. Use of , and will automatically override the add mode and decimally correct answers will be printed.
Aug 18, 2010 | Sharp EL-1611P Calculator
Our company has several Zebra printers that print out barcodes that are scanned using handheld scanners for many things including inventory management. The labels that come from ONE of these Zebras...
Power off printer. Press and hold pause button while power on. This will print dark black line across the entire label. Check for white vertical lines. If you see any in the area of the label where you are experiencing a problem then the printhead should be replaced. Power off and on to exit diagnostics.
Jun 25, 2010 | Zebra 105SL Thermal Label Printer
Epson Stylus T10 printer prints out random symbols from PDF file
When you attempt to print, make sure you are using the correct printer. If you had an old printer before, its name will be still in the printers' list.
and unknowingly you may be trying to print with that printer. To check this:
Goto the File Menu -> select Print-> Highlight the printer you are currently using, and then Print.
I am pretty sure this will solveyour problem.
If it does, give a rating to this answer.
Have a good day.
luciana44
Jan 06, 2010 | Epson Office Equipment & Supplies
Types funny symbols instead of the number I
The typewriter will print the incorrect letter, or the face of the hammer if it does not spin properly to the correct position. 1. Turn the machine offf for 15 seconds and turn ON, or Depress MODE RESET(the Q key). This will rehome the Daisywheel.I If it prints correctly for awhile then looses its' position, check for ribbon or correction tape interference with Daisywheel movement. If it does not print correctly as soon as you start typing, remove the Daisywheel and inspect the spokes to see if any are bent. Reinstall the Daisywheel and power ON. If the Daisywheel has a bent spoke or two, you can try to straighten them, howvever the cause of bent spokes is a concern. While typing, carefully watch the print hammer movement. It should always return to the same position and not move towards the paper until a letter is pressed. If it does not come to rest properly, the hammer is not in proper timing and may enter the Daisywheel while it is spinning to the character, thus causing damage to the Daisywheel or causing it to lose homing. .The hammer cams would require adjustment ore replacement. If bent spokes is a persistent problem, make sure to get the hammer problem repaired before buying a new daisywhel.
Dec 29, 2009 | Brother SX-4000 Typewriter
@ symbol is on number 2 key on keyboard how do you change to
Press SHIFT 2 to get @
It cant be shifted anywhere else Not sure if I have interpreted your question correctly
Thanks for using FIXYA
Sep 21, 2009 | Computers & Internet
Printing symbols and numbers instead of words
Delete print driver and reinstall it. Make sure you are using the correct print driver for that machine.
Aug 02, 2009 | HP DeskJet 1280 InkJet Printer
Euro Symbol Printing
0128 is not a recognisable sysmbol Go to the Toshiba web site and the tech Support team- evidently there has been an error in the printed instruct as to the symbol number.
May 21, 2007 | Toshiba TEC BSX5 Thermal Label Printer
Samsung BIXOLON® SRP-275 Matrix Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
