My maytag front loader is staining my clothes green
  • 276 Answers
SOURCE: front loading washer leaves stains
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Posted on Nov 18, 2008
  • 113 Answers
SOURCE: maytag neptune front loader washer has NF error code
Does it agitate and does the door lock light come on? Theres a panel on the back you can take off via 4 screws. Here you can check the belt and watch to see if it spins or moves at all. If the door lock light comes on, and you here the door click. Than chances are your motor control board is bad. Seen this many times. Im actually replacing one tomorrow on the exact washer.I believe the part # is 22004045. Heres a diagram. If the door doesnt lock than you need either a lock assy or a new computer for it. The computer is in the top panel where the timer is. If you look at it you should see a burnt resistor. If no burnt resistor than its more likely th lock assy. Ill try and find the part # for the lock and computer, and a digram. Hope this helps. Dave www.washermd.com
Posted on Dec 19, 2008
  • 219 Answers
SOURCE: Blue streak stain appears on clothes when washed
u may have a bad tub bearing and seal
Posted on May 21, 2009
woobie dog
  • 1273 Answers
SOURCE: my clothes is wrinkles by my front loader washer
The previous poster was right, the spin speeds on front loaders are incredible. You almost don't have to dry! This is most noticable with heavier clothes, like jeans, especially new ones! This will help a lot: When you take your clothes out of the washer, pop, shake or fluff the wrinkled garment pretty good before you toss it in the dryer. Using a dryer softener sheet will lessen the effect as well. You can also select a lower spin speed, and make up the moisture difference in the dryer. Try shaking the clothes first as this is less expensive than operating the dryer, then back off of the spin speeds as your pocketbook allows!
Regards, --WoobieDog--
Posted on Jul 08, 2009
ginko
  • 19396 Answers
SOURCE: I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Posted on Jun 13, 2010
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
www.fixya.com/.../t14582529-maytag_washing_machine_gets_grease
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
Orange stains on clothing
I had detergent with oxy-cleaners do this.
murf427
Aug 01, 2012 | Maytag Washing Machines
My clothings get grease like stains sfter I wash them with Kenmore washer.
Don't know if this is a front or top loader since you did not supply the model number. But if the stains are grease, it could only mean that the bearing seal has been compromised. Water is getting into the bearings and the bearing grease is what is on your clothes. You need to have the bearing and the seal replaced on your machine.
It is not to bad on a top loader in terms of cost to repair. But, if you have a front loader, that is a different story, since the entire machine needs to be torn apart to get to the bearings and the replacement parts and labor can be as much as a new washer. In either case, get a few estimates before deciding whether to repair or replace the washer. Hope this helps you.
Jan 08, 2011 | Kenmore Washing Machines
I have a Maytag washing machine (top loader) 24yrs old. Recently it has been leaving black oil stains on some of my clothing. The oil is next to impossible to remove and is ruining my clothing. What...
The mounting stem needs to be replaced. This page shows how to replace the mounting stem and the tub seal. http://appliance-repair-it.com/Maytag-tub-seal.html
You only have to replace teh mounting stem for your problem but the page will help all the same.
Sep 23, 2010 | Washing Machines
Have had numerous items ruined due to brown stain
My Maytag Front Loader also has periodically caused rust stains on clothes. After investigating it I determined the cause.
The top of the machine is rusting around the opening under the lid where you add the detergent, fabric softener, and bleach. Water apparently splashes up on the bottom of the lid and it rusts. The flakes of rust then flake off and fall into the plastic reservoir and are washed into the machine. The only fix is to replace the top of the machine, or take it off, physically clean off the rust and apply a coating of rust resistant paint to the inside. A quick fix is to remove the plastic cover (4 phillips screws) and clean as much rust off around the edges as you can. Be sure and keep the rust from falling down the hole where the water flows into the machine.
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
OIl stains on clothes with front loading LG washer
ftr loader washers do not have any oil, my guess would be you are using fabric softner . that can stain clothes. dilute with water, they are very concentraded. or your dispenser may not be working properly and not releasing softner at the proper time.i would run a clean cycle through it. meaning set on a hot wash- regular cycle no clothes and run wirth bleach in bleach disenser. do this every other month to keep washer clean hope this helps. make sure its not happening in the dryer , the dryer has frt and rear seals that go bad and start leaving marks on clothes and catching them in beteween the tub.
Sep 16, 2009 | LG WM-2032H Front Load Washer
Front loading washer leaves stains
Nov 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
Clothes come out oily after wash
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said,you have a Eurotech front loader. Lately you have observed that your cotton materials come out with oily spots after wash. What can one use to address this problem.
In most front loaders when this happens it is usually either of two things.
1.Front loaders must have HE detergent for their use and if you do not use HE detergent you must cut your detergent and bleach in half.
Because to much detergent destroys your seal and eventually your bearings! And any other rubber seals like the rubber door seal in the front opening.
These degrade and get into the wash and depending on the color of the rubber (Black or gray) are found to stain your clothing or leave a residue in those colors.!
Those washers with Grey rubber like Maytag's have gray stains and or residues!
I have people asking me about this problem every day!
Call the manufacturer and ask if they have any cleaner that you can run once with out clothes to put an end to this!
And then use HE detergent and or half the dose of bleach form now on!
I hope this brings some lihgt to your problem. Please let me know what the Eurotech proplr tell you to use to clean it out of your washer!
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | EuroTech EWC177 Front Load Washer / Dryer
Stained clothes
there no grease in ft loading washer possible cause fabric softner
Feb 03, 2008 | Kenmore 44102 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
