Question about Sony Vaio VPCEB16FD WXGA HD 15.6" LCD Panel
USB ports broken. Also no sound. Probably need to replace cards but don't know part numbers or where to buy. Also need repair manual with an exploded diagram
  • 72 Answers
Go to sony website search the item model number there you will get it
Posted on Mar 17, 2014
2 Suggested Answers
leonardle61498
  • 73 Answers
SOURCE: Vaio USB and Sound Problem
Hello, It sounds like you have multiple problems. Instead of replacing any parts on your lap top, may I suggest you have a tech look at it first? He/She will be able to SEE how the damaged usb ports are affecting the whole of your laptop. It may be no more then checking the mute on your speakers. Thank You
Posted on Feb 12, 2014
Feb 12, 2014 | Sony Vaio VPCEB16FD WXGA HD 15.6" LCD...
How can I send recordings to my laptop? I have a usb connector and i want to connect my portable grand to my laptop but the laptop does not detect the piano and i don't know what to press on the piano...
Hi mjaynneb,
I could be wrong here but I have a number of keyboards and the USB connection is usually for Midi control from software like Cubase and the like. If by recording you mean recording Audio then I think you'll find that it won't be possible using the USB port.
Midi is great and I use it a lot. It enables you to arrange music using your computer. Also you can record the music you play on the Keyboard on the computer as Midi. This means that the computer can play back through your arranger what you just played. Bear in mind though that Midi is purely numbers that represent notes, velocities and note duration so is not actually audio.
My keyboards have the ability to record to SD card or a Hard Drive, however if this is not a feature of your arranger then probably your best bet for recording audio from it is by using the Audio out ports of your arranger and using a connecting lead to a good low noise sound card on your computer. As you are using a laptop you can find external usb sound cards/interfaces so that should do fine. Then you could probably use something like Audacity which is free software, to record to a wav file.
I hope this helped.
Kind Regards
mparkyn
Jul 27, 2011 | Yamaha DGX 640 Keyboard Arranger
My usb port is broken can it be repaired ad how
There are few things to consider where it be repaired or not. If you can actually repair it then why not but for me I do need help to somebody fix that, call any technician to ask them were it be repair or not.
I have USB Port used now. Only I hate this device is when you load more devices on it get hang on system. Probably USB port have a maximum speed by 2.0 only. But if you want to buy or get higher speed then why not, but 4.0 version only.
If you to repaired it then why not but for me I'm sure it will not work.
Dec 23, 2009 | Toshiba 4030CDT (P000271450) Motherboard
Photo viewer device not found
I got a key ring for Christmas too ...when the keyring is on 'charge' mode it doesnt show on computer ...you have to remove the lead from key ring, switch off key ring then replace lead and switch to 'update' mode. Now if you double click on icon it should work!!!
Nov 22, 2009 | Fuji Electronics - Others
UBS port won't allow my memory stick to go in is there a lock on it???
Hello !
Be certain you are trying a USB port. It is rectangular in shape. The USB memory stick will only go in one way. Try flipping it over.
If still a problem ...
Either your USB memory stick is bad or your USB port on your notebook is bad.
Try another memory stick or try a different USB port on your notebook - should determine which is OK and which is bad.
Hope this helps.
Oct 28, 2009 | Acer Aspire One A150-1006 Notebook
Usb port broken on my dell 3000 inspiron laptop
Don't know if there is such a adapter, but you can get a PCMCIA USB card.
You can also get a PCMCIA wireless card and these are available from Netgear, DLink and others.
Mar 05, 2009 | Dell Inspiron 2200 Notebook
USB Flash drive broken
Have to be taken to either your local PC repair shop or sent back to the manufacturer. I would send it back to the manufacturer because they are more familiar with your system. There is nothing you can do to fix it has to be fixed on motherboard.
Don't forget to rate this solution..
Jan 11, 2009 | Computers & Internet
Bad USB Port in Camera
I think you CAN--there's a lovely site with specific instructions,,,, Do It Yourself Camera Repair --- for fabulous step by step instructions WITH pictures & simple explanations that a novice can follow!!!
In short, all you need to do is find another USB port (even from a broken camera or other device) to replace yours. It seems that you'll need to solder it in -? - that's the step I'm trying to research right now--I'd like to just glue mine back in because I don't know how to solder--- but the tricky part is getting the camera apart, not touching the flash capacitator nor any of it's power-holding chips, and not damaging any of the other components.
(ACF0EB8F)
Aug 18, 2008 | Kodak EasyShare DX7440 Digital Camera
Usb port defective
It looks like they are part of the motherboard.
If they are physically damaged a competent repair shop can replace them probably a couple hours of labor ($120-$200 depending on the place. If they dont work at all then I would just buy a USB PCMCIA card which plugs into the side instead ($20-40).
Dec 21, 2007 | Compaq Evo N610C Notebook
USB port broken on old IBM Thinkpads
Marite,
Thanks for providing the pictures. You don't know how much that kind of input helps!
In looking at the pictures you've sent, the only way to repair this is to replace the connector. It can be fixed, however you need to be aware that the cost to obtain a part as old as this plus the labor involved will probably be much more than the unit is worth.
One thing that you might want to try is to buy a USB hub and plug it into the working port. A USB hub is a kind of extention cord that will give you several USB ports.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thanks you, and have a super day!
Ron-
Nov 20, 2007 | Computers & Internet
Sony Vaio VPCEB16FD WXGA HD 15.6" LCD Panel Logo
52 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
