Question about Martin Thinline 332 Plus Piezo Acoustic Guitar Pickup
How to fix ground buzz
Ground buzz except when touching the jack
    New Friend:
  • 35 Answers
Try using a di box with ground lift switch
Posted on Feb 20, 2014
I have roland cube20x. I makes a loud buzz when plugged a cable on the input jack but it goes down when i touch the jack. Thanks
You have a ground problem. I suspect your cord. Replace it, being sure you use an instrument cable, and see it that doesn't help.
May 01, 2017 | Roland Music
Why does my carvin sx-300 amp buzz
Most Amps will buzz or hum when there is a bad ground. It could be because you're plugged into an outlet with some other piece of equipment on it like a motor. if it buzzes on every outlet then there's probably a ground issue in the amp. You can try cleaning your 1/4 jacks with cleaner cause sometimes they'll get cruddy and make for a bad connection. I wouldn't recommend opening the amp and messing around with anything since you could zap yourself. If the amp buzzes withouth even having anything plugged in, then yeah, it's probably the amp with the bad ground. If it buzzes with instrument plugged in, then maybe it's a plug on your instrument since they have to deal with movement and can go faulty after a while. Good luck!
Oct 21, 2014 | Music
Gibson 6 string maestro I took back off re soldered only works when I touch outside guitar jack plug all th way in jack an don't work
Looks like you need a new jack or you have a loose ground. That is why it works when you touch it - because you are grounding it. Check solder connections before you plug it in, and ungrounded instrument is potentially dangerous while using an amplifier
Mar 17, 2014 | Music
Buzz coming from elec. guitar pickups only when using Aviom and headphones
It is a definite pickup grounding issue causing hum/"buzz" which diminishes when touching strings. Check the impedance of cable jack inputs and cable which should be 1/4"mono input/output jacks) . A personal preference but effective is to NOT run guitar direct into mixer but through an external amp w/ a headphone out jack . Noise gating/preamp filter also will help eliminate the "buzz"/noise from pickups. It is unfortunately the nature of the "electro-magnetic" beast when it comes to electric guitar pickups .Hope this helps.
Feb 23, 2014 | Aviom A16ii Personal Monitor Mixer 16...
Ephiphone guitar pickup wiring
Or a bad solder connection on the ground wire on the jack, or shell/sheild on the guitar.
Here is the list you seek.
http://www.gibson.com/en-us/Support/TechSupport/Wiring Diagrams/
Feb 03, 2012 | Epiphone Les Paul Studio Electric Guitar
This is on a 15 watt Peavey Vypyr. I have a buzzing at the bottom end of my amp, when playing on the low E string. I plugged in my headphones and the buzzing went away while playing. I have also raised my...
The voice coil on the cube speakers must be scraping against the magnet.Or the speaker cone must be damaged causing it to flutter at low frequency where there will be large cone movement. Try removing the phono jack from your musical instrument/ guitar and touch the tip of the jack with your finger. You will hear a hum, now turn down the volume and listen to the speakers very closely and see if you can identify the flutter. All the same you will have to fix the speaker or replace it. Have you ever dropped the speakers, if so the speaker frame could have warped causing the scraping noise.
Aug 08, 2011 | Peavey Vypyr 100 Guitar Combo Amplifier...
My bass buzzes when im trying to record. I plug it straight into the back of my 8 track and it buzzes. When I touch the metal conection were the jack goes or touch the jack the buzzing stops. This is also...
The cause is a lack of proper earth grounding in the 8 track so your jack-lead is acting like a radio aerial. The solution is simple - buy a Direct Injection (DI) box to place between the guitar and recorder.
Feb 09, 2011 | Epiphone Thunderbird IV Electric Bass...
Whenever I touch anything metal on my guitar it buzzes, including the metal part of the 3-way switch, I have a Dean Vendetta, how do I fix this?
You have a grounding problem ! You need to BOND (electrically connect) all the metal parts including the cases and shafts of the volume controls and switches. OFTEN the cavity with the controls are painted with a conductive paint such as Aquadag or NicklePrint which is then bonded to the barrel part of the jack you plug into. Note, while this helps the buzzing due to touching the metaal parts, it will not eliminate hum if you get your guitar pickups into a magnetic field from transformers, etc.
Jan 22, 2011 | Dean Vendetta Revenge Electric Guitar
Generates buzzing noise even when only cable is connected to it. No cable - no noise.
If you are saying that you are plugging a guitar cord into an input on an amp without the guitar on the other end and you are getting a hum or buzz with the volume turned up ; that is normal. If you are getting the same results with a guitar plugged in it means the ground wire to your output jack on your guitar is broken. Check your cord with a volt ohm meter for continuity on the tip on one end to the tip on the other end. Do this for the sleeve on one end to the other. If you were getting the buzz without a cable it would mean that your input jack in your amp has a broken ground connection. Hope this helps.
Jul 04, 2009 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Amplifier is buzzing when i plug in my les paul but ok with other
Several things to try:
- Probably already have, but another guitar cord.
- Ground switch on the amp?
- I had an older guitar that buzzed due to the pickups. While touching the strings, all was well - I was acting as the ground then. The ground wire broke, so it buzzed no matter what. The ground wire ran to the metal bridge.
- Play louder than the buzz! :)
Mar 23, 2009 | Epiphone Les Paul 100 Electric Guitar
Martin Thinline 332 Plus Piezo Acoustic Guitar Pickup Logo
35 people viewed this question
Top Martin Music Experts
David Baisa
freddybrass
Level 1 Expert
Are you a Martin Music Expert? Answer questions, earn points and help others
