Question about Vans Winter Sports
Kia code p2106
Would like to know what the code means KIAp2106
2 Suggested Answers
  • 29 Answers
SOURCE: codes p2106
I think you'll find it's a problem with your throttle you might need to talk to you local ford dealer but don't get talked into getting bit's replaced! I've been tld that you can put a recommended cleaner into your fuel tank and this can sometimes cure the problem - worth a go................
Posted on Jun 26, 2010
Ford f150 2005 4.2 v6 Showing codes p2106, p061b, p061c What's the deal with these codes am I about to be msf
code p2106 refers to intake manifold air control actuator position switch/sensor, bank1--circuit low===causes--wiring shirt to ground--position switch/ sensor faulty.
Sep 09, 2014 | Cars & Trucks
Need the name of the sensor code p2106
go to google input trouble code p2106 in the search bar. this code refers to the throttle control system. could be the throttle position sensor.
Oct 12, 2013 | 2008 Chevrolet Aveo
Wath is the code p2106 in the coputer in a 2006 ford 500
Replace all the Ignition Coils & the code will be gone
Forget the P2106--- no problem related to that code
Ignition coils are bad & spike the PCM (computer)
drivers ---eg:-- don't ground out correctly & you loose the
TPS Sensor signal,go into failsafe & get the P2106
Sep 20, 2013 | Cars & Trucks
P161
sounds like fuel built up inside your exhaust before the cat then it ignites creating a bang. insuficient spark or timing...
Feb 04, 2012 | 2006 Hyundai Sonata
My 2005 ford explorer 4x4 xlt (v8 4.6 ltr)has trouble code p2106. what does this trouble code mean?
P2106 is an informational code and is usually set by some other fault.
This DTC means is that the PCM detected a fault with the electronic throttle control and went into fail safe mode. It doesn't tell you specifically what system or component went haywire, just that something was wrong, the PCM didn't know what to do so it went to a known good operating parameter, in this case fail safe mode. Likely is a problem with the TPS sensor and will need to be replaced.
Hope this helps.
Oct 03, 2011 | 2005 Ford Explorer
Mutiple error codes P0101, P161B, P0441, P1295,and P2106. What do these mean, and/or where can I find a free table listing?
P0101 Mass Air Flow or Volume Air Flow Circuit Range/Performance problem.
P0441 Evaporative Control System - Improper Purge.
P2106 Throttle actuator control system - Forced Limited Power
P161B Manufacturer Control Auxiliary Inputs Auxiliary Outputs
P1295 Manufacturer Control Fuel Air Metering
Hope that helps out.
May 11, 2011 | 2006 Kia Sorento
Codes p2106
Jun 26, 2010 | 2006 Ford Five Hundred
I have an 03 Ram 1500, engine light is on, I had
p0440 - Evap. system performance (this could be something as simple as not turning the gas cap several times after you fill up.
p0456 - Evap leak monitor Small leak detected. - Could be related to the previous code.
p2106 - Throttle Actuator Control System - Forced limited power : This one you might have noticed the vehicle running rough, overdrive not working properly and cruise control will not set.
p2175 - Throttle Actuator Control System - Low airflow detected.
What you might want to try first is have the codes cleared which most auto parts stores offer this for nothing (unless you have a programmer then you can do it yourself). Pour in some fuel injector cleaner into your gas, put a new air filter on. And when you fill up your gas tank, crank the cap several times when you put it back on.
See if the codes come back on after that.
Nov 21, 2009 | 2004 Dodge Ram 1500
I need to know what these 2 codes mean that i got for my 98 kia sportage: p1700, p1300. And do some codes transfer to different cars the same because its hard to find any codes that are just kia.
Please let us know the exact error code.. there is no P1700 and P1300 are not an error codes on 90 kia sportage.
Thanks,
Jeep Brainy
Aug 13, 2009 | 1998 Kia Sportage
2001 Kia Optima
P1529 and P0720 does not seem to be understood.
P0715 means Input/Turbine Speed Sensor Circuit Malfunction.
P0118 means Engine Coolant Temperature Circuit High Input.
For more understanding visit:- http://www.troublecodes.net/Kia/
Cheers.
Aug 08, 2009 | 2001 Kia Optima
Winter Sports Logo
89 people viewed this question
Top Vans Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Vans Winter Sport Expert? Answer questions, earn points and help others
