Question about Science & Laboratory
I have fluke 789, now there is no display only at the left side have 3 led light on ,
Fluke 789, no display when change from Off to any point measurements, at the left of display have LED light (2 yellow and 1 amber), can repair?
    Master:
  • 683 Answers
You can try replacing lcd, if that does not fix problem then send it in for service
Posted on Dec 03, 2014
Fluke 789 process meter will not source power above 12 milliamps
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Feb 11, 2017 | Power Motorcycles
The display comes up with UnCal when the ambient temp drops below say 15 degrees celsius then when it warms up it works normally.
I'd try to locate the problem using freeze mist. Spray each component for a second or two to see if the unit acts up. Repeat with each component until you find the one that is causing the problem.
Apr 28, 2015 | Fluke 789 Process Meter loop Calibrator
Display light out on boston acoustic duo-I plus
In my case the blue LEDs were dead. It is pretty difficult to replace them by new SMD-LEDs but I managed it. Open the front, take out the board from the front part (5 screws). On one side of the LCD-screen you can see a white stripe with 3 resistors 101 (100 ohms). You must free this stripe form the plastic body on the left and right side (eg. by soldering iron). Solder out this stripe, on the other side you will find 3 very small smd-leds. Break them out and solder 3 new leds onto the board (left side = K). For control you can put 3 Volts to the Anode (A=+) and the Kathode (K=-) of this stripeboard before fixing it on the frontboard by soldering.
Jul 09, 2014 | Boston Acoustics Duo-i Horizon Clock Radio
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Fluke 789 error when reading AC voltage at 1000 Hz
specification is given up to 500Hz
this is a process meter - not made for frequencies above 500Hz, you need dmm to measure this frequency
Jan 31, 2014 | Fluke Networks Fluke Fluke 789
Need emachines t3306 motherboard connection diagram
The eMachines T3306 desktop computer, uses the FIC K8M-800M motherboard.
First International Computer, (Inc)
http://www.fic.com.tw/product/motherboard/amd/ficimages/k8m-800m.jpg
http://www.fic.com.tw/product/motherboard/amd/k8m-800m.aspx
Here's the download page for the motherboard manual,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
Column in middle, 3rd file from bottom.
This is a Zip file. A Zip file is a Compressed file. Used to send large amount of information more easily.
Has to be decompressed, or 'unzipped'.
After you click on the blue -> FIC K8M-800M file name, a small window will come up-
Opening K8M-800M_manual.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; click in the empty circle to the left of Save File.
No go below in the small window, and click on OK.
A small download window will come up.
Allow the file to fully download all the way, then DOUBLE-click right on the file name.
(Yellow folder icon with a zipper on it. K8M-800M_manual.zip is to the right)
In the next small window go to the far Left, and click on -
Extract all files.
At the bottom of the next 3 small windows click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name ->
K8M-800M_manual
(Next to the red Adobe PDF icon)
There is your motherboard manual in PDF file form.
For an example;
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
Motherboard installed in computer case, the Front Panel header is at the Bottom/Right.
The Front Panel header is Orange in color. (Page 20)
Two rows of contact pins.
5 pins across the Top row.
4 pins across the Bottom row.
The Top row is numbered ODD.
The Bottom row is numbered EVEN.
Starting on the RIGHT side going across to the Left; Top row,
Pins 1, 3, 5, 7, and 9.
Starting on the RIGHT side going across to the Left; Bottom row,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected.
Reserved for factory use. Probably a 5 Volt test point.
D) Pins 2 and 4 are for a Power On LED light.
These two pins are used for a Single color, Power On LED light.
Two wire LED light.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
There is ALSO a jumper used for this LED light. More on it at the end.
E) Pins 6 and 8 are for a Power On switch.
To the Right of the Orange Front Panel header, (F_PNL), is the PW_LED header.
[Page 20 to right of Front Panel header. -> PW_LED
(Power LED, 2/3 Pins) ]
3-pin Black header. Sits Vertically.
(The Orange - Front Panel header, sits Horizontally)
This is used for a 3-wire Power On LED light.
Used for a Dual Color - Power On LED light.
One example is if the computer has Turbo Mode, and Normal Mode.
Green color usually for the Turbo Mode, Yellow color of the LED for the Normal Mode.
Starting from the BOTTOM going UP;
Pins 1, 2, and 3. (3 at the Top)
A) Pin 1 is for the Positive ( + ) wire. [Signal]
B) Pins 2 and 3 are for the Ground wires.
Jumper block for the 2-wire Power On LED light, and 3-wire Power On LED light; Page 13 - Set System Jumpers
(Actually it starts on Page 12)
6-pin header to right, of 3-wire Power On LED header.
Has Blue jumper caps on it. Two of them.
(PL_LED1)
http://www.ebay.com/itm/NEW-FIC-uATX-Skt-754-AMD-Desktop-Motherboard-VIA-K8M800-AGP-4x-8x-DDR400-800FSB-/280923928691?pt=Motherboards&hash=item41685ef873
Two rows of 3 pins.
The bottom row is numbered EVEN.
Starting on the RIGHT side going towards the Left; Top row,
Pins 1, 3, and 5.
Starting on the RIGHT side going towards the Left; Bottom row,
Pins 2, 4, and 6.
A) With the jumper caps on Pins 3 and 5; plus 4 and 6; the Power On LED light works as a Single color LED.
B) With the jumper caps on Pins 1 and 3; plus 2 and 4; the Power On LED light works as a Dual color LED.
For additional questions please post in a Comment
Regards,
joecoolvette
Mar 07, 2013 | Computers & Internet
Power LED and other connection diagram for MSI 7142 motherboard
MSI Support > K8MM-V motherboard (ms-7142) > Main Support page,
http://www.msi.com/product/mb/K8MM-V.html
Hover your mouse cursor on the Download tab.
(Overview / Specifications / Download / Support / etc)
In the drop down list click on - Manual
Underneath the Download subheading click on the blue -
M7142v.1.0.zip (2005-09-07)
Click on the 'country' name nearest yours.
(U.S. is a country. Europe and Asia are continents)
A small window will come up -
Opening M7142v1.0.zip
Make SURE the small circle to the left of Save File, has a Green dot in it.
IF not; click in the small empty circle to the left of Save File.
Now go below in the small window, and click on - OK.
Allow the file to fully download, then DOUBLE-click right on the file name. ( M7142v1.0.zip)
In the next small window go to the far left, and click on -
Extract all files.
At the bottom of the next 3 small windows, click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name.
There is the motherboard manual in PDF file form.
The Adobe Reader page number box is at the Top, to the right of the Down Arrow.
You can go page by page, to the page you want, using the Down Arrow; or if you know the page you want you can do this,
1) Put your mouse cursor in the page number box at top.
Left-click once. Anything in the page number box, is now highlighted in blue.
2) Type the page number.
3) Press the Enter key.
A) Go to Page 5 - Layout.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
On your motherboard there are two.
JFP1 and JFP2.
Junction Front Panel 1 and Junction Front Panel 2.
JFP1 is on the Right side of the motherboard, down in the Bottom/Right corner.
It sits Vertically on the motherboard.
Two columns of contact pins.
5 on the Left side, 4 on the Right side.
Go to Page 14 - Front Panel Connectors: JFP1/JFP2
The pins on the Left side are numbered ODD.
The pins on the Right side are numbered EVEN.
Starting on the Top/Left side, coming down;
Pins 1, 3, 5, 7 and 9.
Starting on the Top/Right side coming down;
If the HDD LED is dim when the harddrive is active, switch the wires around.
This is reserved for the factory. Believe it is a 5 Volt (DC) test point.
D) Pins 2 and 4 are for the Power On LED light.
It is for a TWO wire Power On LED light.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10.
The JFP2 header is to the Left of JFP1.
It is situated Horizontally, and close to the bottom of the motherboard.
Two rows of pins.
3 pins on the Top row, 4 pins on the Bottom row.
Starting on the Right side, going towards the Left; Top row,
Pins 1, 3, and 5. There is NO Pin 7.
Starting on the Right side, going towards the Left; Bottom row,
A) Pins 1, 3, and 5 are for a THREE wire Power On LED light.
I assume Pin 1 is for the Negative wire ( - ), and Pins 2 and 3 are for the two Positive wires.
It's for a dual color Power On LED light.
Example: Turbo Mode has a Green light, Normal Mode has a Yellow light.
B) Pins 2, 4, 6, and 8 are for an internal speaker.
Internal speaker is used to hear the BIOS Beep Codes.
For additional questions please post in a Comment.
[Thought you may want the motherboard manual, too]
Regards,
joecoolvette
Mar 04, 2013 | MSI K8MM-V Motherboard
9VJL3 front panel
Do not have the Front Panel header pinout.
Do have;
Take an LED (Light), with two wires, and check the pins with it.
There is a Top row of pins, and a Bottom row.
Touch the first two pins in the Top row, left side. Does it light up?
No? Go to the next two pins. No? Go to the next two pins.
Keep going until the Power Supply comes on. (It is a BRIEF touch. The Power On switch is a Momentary Contact Switch )
Now you have the Power On switch pins.
LED light blinks? You have the Harddrive activity LED. (Light)
LED light stays on? You have the Power On LED. (Light)
Computer restarts? The Restart switch pins.
Short something out? NOPE. You can't hurt a thing using this method.
4 of those pins are for an internal speaker. (To hear BIOS Beep Codes with)
That's 12 of those 18 pins. (Probably less. It is two rows of 9 pins, that are stated for the Front Panel header)
4 of those pins probably won't be used.
You won't be using IR. (Infra Remote) (Only uses 2 pins, though)
Most of the time with an 18-pin Front Panel header;
Top Row:
Starting at Left side, going towards Right;
Pins 2, 4, 6, 8, 10, 12, 14, 16, and 18.
May be a pin missing in this row, or two.
Borrom row:
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
Same thing here. May be 1 or 2 pins missing.
Pins 2 and 4 are usually for the Power On LED. (Light Emitting Diode)
Pins 6 and 8 - Power On switch.
Pins 10, 12, 14, and 16 may be for the Internal speaker.
Pins 18, and 20 are usually not used.
Pin 1 and 3 for the HarDDrive activity LED.
Pins 5 and 7 for the Reset switch.
Pin 9 is usually reserved for the factory, and is a 5 Volt test point.
Pins 11, 13, 15, 17 for speaker; or not used. Same with pin 19.
(So speaker pins may be top row, or bottom row. Dunno )
Another thing. This motherboard is old enough to be using a 3 wire LED, or dual color; for the Power On LED.
LED usually had the colors Green and Yellow.
Yellow for 'Normal' mode, Green for 'Turbo' mode.
(Which is a bunch of cr@p.
Green LED, or Turbo Mode; was actually NORMAL.
Normal mode was the computer operating BELOW the Normal mode)
So pins 2, 4, and 6, may be for a 3 wire Power On LED.
Regards,
joecoolvette
Dec 22, 2012 | Chaintech 9VJL3 P4(478)/VIA Motherboard
Front panel configuration
Motherboard installed in computer case;
Processor to the Top, 3 Ram Memory slots to the Right, 5 white PCI slots to the Bottom;
Down in the Bottom/Right corner, is JFP1, and JFP2.
The Front Panel header is JFP1. (Junction Front Panel 1)
The header with two rows of pins, and is positioned Horizontal. It is parallel to the bottom of the motherboard.
(The other Front Panel header is JFP2. It is positioned Vertical, and is above JFP1. You may be using it also. Read on)
There are two rows of pins for JFP1.
5 across the Top, 4 across the Bottom.
The pins on the Top row are numbered ODD.
The pins on the Bottom row are numbered EVEN.
Top row, starting from the Right side, going towards the Left;
Bottom row, starting from the Right side, going towards the Left;
Pins 2, 4, 6, and 8. There is NO pin 10.
If the Harddrive activity LED light is dim, when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for the Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. It is/was for the factory.
D) Pins 2 and 4 are for the Power On LED light. A Power On LED light that has 2 wires.
If the Power On LED is dim when the computer is on, switch the wires around.
Looking at JFP2. (Junction Front Panel 2)
Vertical with two columns of pins.
3 on the Right side, 4 on the Left side.
The Right side is numbered EVEN.
The Left side is numbered ODD.
Starting at the Bottom on the Right side, going Up;
Pins 1, 3, and 5.
Starting at the Bottom on the Left side, going Up:
A) Pins 1, 3, and 5, are for a Power On LED light, that has 3 wires.
Pin 1 is for the Positive wire. (Dual color LED )
B) Pins 2, 4, 6, and 8 are for a Speaker. The speaker for BIOS Beep Codes.
Pin 8 is for the Negative ( - ) wire.
Regards,
joecoolvette
Jun 24, 2012 | MSI MS-6580 Motherboard
Science & Laboratory Logo
466 people viewed this question
Top Science & Laboratory Experts
ray gallant
Andrew Taylor
Andrew Taylor
S J Parkin
S J Parkin
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
